Wharfedale Diamond 10.7 Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-09-2012, 06:40 AM - Thread Starter
Phillip6414's Avatar
I am in the market to purchase the Wharfedale Diamond 10.7 Towers. While shopping online I noticed a pair for sale that is labeled "UK Version". I emailed Wharfedale and have not gotten a response. Does anyone know if there is a difference between these speakers and the ones that are not the UK Version? I will also be purchasing the 10CM (center) and the Diamond DFS (surrounds) separately from somewhere else, so they need to be compatible if you will. Thank you.
Phillip6414 is offline
post #2 of 3 Old 07-24-2012, 10:54 PM - Thread Starter
I got a response from Wharfedale about my question asking if there is a difference between the British version of the Wharfedale speaks and non-British versions and they say there is no electrical difference, the only difference is the packaging. I hope this helps anyone asking the same question.
post #3 of 3 Old 07-25-2012, 12:00 AM
nxcuongvn's Avatar
I believe that you will happy with this pair of speaker, very good bass and detail at the mid. I can say that Wharfedale Diamond 10.7 is the best when comparing with B&W684/Monitor Audio RX6/Jamo C8xx...
nxcuongvn is offline
Reply Speakers
