New to home theater... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 07-09-2012, 02:57 PM - Thread Starter
Huckhgh11's Avatar
Good afternoon, I'm completely new to projectors and have a question for you pros. I bought the LG HW300T projector this past week and love the picture. I was wondering if there's any way that I can hook up a surround sound system to it? I noticed that there's not an Audio Out component but thought I could use the Headphone outlet and rig something up. I hope there's a simple solution but can't find it myself. Anyway, any guidance/advice is greatly appreciated. Thanks!
Huckhgh11 is offline
post #2 of 19 Old 07-09-2012, 08:37 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
Easiest way is to find a speaker system (home theater in a box) that supports HDMI in and out. Even many soundbars will support. If you like audio the best solution is to buy a dedicated AV receiver that supports HDMI and then buy your speakers and subwoofer separately.
ack_bk is online now
post #3 of 19 Old 07-10-2012, 07:03 AM - Thread Starter
Huckhgh11's Avatar
Thanks! Do you have one that you would recommend for under $100?
post #4 of 19 Old 07-10-2012, 07:17 AM
GuitarStv's Avatar
If you only have a headphone out and 100$ to spare, try looking for a set of computer speakers. They take headphone levels with an 8th inch jack and can be had for pretty cheap on sale.
GuitarStv is offline
post #5 of 19 Old 07-10-2012, 07:48 AM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
Yeah, if your budget is only $100 this is probably your best bet.
post #6 of 19 Old 07-10-2012, 09:02 AM - Thread Starter
Huckhgh11's Avatar
Thanks guys! Will the computer speakers have decent quality?
post #7 of 19 Old 07-10-2012, 10:16 AM
Elihawk's Avatar
Quoted: 1030 Post(s)
Liked: 869
Decent at best quality...100 dollars isn't even a lot for computer speakers!
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is online now
post #8 of 19 Old 07-10-2012, 10:23 AM
commsysman's Avatar
Quoted: 987 Post(s)
Liked: 526
You need an HT receiver and 5 speakers plus a subwoofer. The receiver will process the sound, amplify it and drive the speakers, and send the video to the projector, probably via an HDMI connection.
The Denon 1612 will be a good receiver for you, and it is remarkably inexpensive at only $250 or so. I would start by getting it.
The next step is a set of speakers. That will require a budget of somewhere between $500, for some pretty basic speakers, to $1500-2000 for some speakers that will actually sound pretty decent.
For $100 you can get a pair of Behringer MS16 powered speakers from Amazon that will connect to your projector and give you some basic 2-channel sound; they have built-in amplifiers and will connect to your projector. This is about 100 miles away from a decent surround-sound system, but it will get some sound in the room for start-up.
commsysman is offline
post #9 of 19 Old 07-10-2012, 10:27 AM
WagBoss's Avatar
with a $100.00 budget your only option would be computer speakers, or possibly some cheap "studio monitors". I don't think you would be impressed at all with the sound, especially if your room is big, which is assume it is because you have a projector.
These are much better then computer speakers in every way, http://www.amazon.com/M-Audio-Studiophile-Powered-Monitor-Speakers/dp/B0051WAM64/ref=pd_cp_MI_0 and would be your best bet if you can't change your budget to $500+ :P
WagBoss is offline
post #10 of 19 Old 07-10-2012, 10:34 AM
Elihawk's Avatar
Liked: 869
Notice the audioengine ad at the top of the page? those are pretty good powered speakers and would sound good. They (the A2s at least) will run you 200 dollars/pair. A sound bar might be the way to go, although don't expect surround sound!
post #11 of 19 Old 07-10-2012, 10:41 AM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
It is what it is for the budget. I agree with the audioengine recommendation. It will give you decent sound (better than any built in TV speakers), but if you want true 5.1 sound you are going to need to spend more money.
post #12 of 19 Old 07-10-2012, 10:42 AM - Thread Starter
Huckhgh11's Avatar
post #13 of 19 Old 07-10-2012, 12:45 PM
WagBoss's Avatar
What about something like this: http://usabcp.com/index.php?main_page=advanced_search_result&search_in_description=1&keyword=SAMSUNG+HT-X70&x=0&y=0
Would it work for me and my low budget?
that seems insanely cheap for what it says. too many features for that cheap.
WagBoss is offline
post #14 of 19 Old 07-10-2012, 12:48 PM - Thread Starter
Huckhgh11's Avatar
So you think there's something wrong with it? Could it just be a great deal that I stumbled upon? Haha
post #15 of 19 Old 07-11-2012, 06:35 AM
GuitarStv's Avatar
That looks like a decent deal for the price. If you check CNET and Amazon user reviews you'll hear a lot of complaints about the system failing, which I'd be a little concerned about.
post #16 of 19 Old 07-11-2012, 06:39 AM
WagBoss's Avatar
its possible but most likely its a piece of garbage
WagBoss is offline
post #17 of 19 Old 07-11-2012, 06:42 AM
wlcohen's Avatar
You would use the audio out on your sources - cable box, dvd, and hook them up to a receiver for surround sound
wlcohen is offline
post #18 of 19 Old 07-11-2012, 07:27 AM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
That store seems very shady... No phone number and their customer service is a hotmail address... I would stay away.
post #19 of 19 Old 07-11-2012, 08:51 AM - Thread Starter
Huckhgh11's Avatar
I noticed the same things...
Reply Speakers
