Center Channel Advice....Which one?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 07-11-2012, 07:51 PM - Thread Starter
NoviceSoundGuy's Avatar
Hi everyone,
I am new to AVS. I am having some trouble deciding on a center channel for my system and am hoping to get your adivce. My front L and R speakers are Speakercraft MT6 Threes, my rear speakers are Speakercraft AIM 7 Threes and I have yet to get subwoofer. My TV is Panasonic VIERA TC-P55VT50.
I am trying to get a center channel that will be sound matched and produce a nice even flow within the system above. I was originally thinking about the Bowers & Wilkins HTM61 or the HTM62. What do you think about those? Any others that you think are comparable or better? My max price for the center channel is right at $650. Also, if you have any thoughts on a matching sub, I'd be curious to know that as well.
Many thanks to those that take the time to respond....greatly appreciated.
NoviceSoundGuy is offline
post #2 of 18 Old 07-12-2012, 05:07 PM
JimWilson's Avatar
Quoted: 1268 Post(s)
Liked: 1567
I'd probably call Speakercraft and see what they recommend. It's a bad idea to go with different manufacturers for the front 3 channels, so sticking with Speakercraft is probably your best option.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is online now
post #3 of 18 Old 07-13-2012, 08:07 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
^ What he said.
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
post #4 of 18 Old 07-13-2012, 08:19 AM
cel4145's Avatar
Quoted: 2658 Post(s)
Liked: 2990
Agreed. Plus, the HTM61 does not have a great reputation as a center channel.
For subs, look at Internet direct brands like HSU, SVS, Outlaw Audio, and Rythmik. They are always a good value for a subwoofer purchase, and typically much better than most traditional brick and mortar store speaker brands because they don't have to pay a middleman or spend as much on marketing. Research on the AVS subwoofer forum, and you'll see that these brands are the most often recommended.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #5 of 18 Old 07-13-2012, 08:43 AM
Jindrak's Avatar
Quoted: 51 Post(s)
Liked: 122
As I currently own and use a B&W HTM61 as my center channel, I will have to disagree. It is quite excellent for a center. Reproduces dialogue very clearly and is easily driven to loud levels. However, I do agree that you should not mix and match the LCR, as that is arguably the most important part of the system besides the sub. However, you CAN get a different sub than your LCR (or speakercrafts, or whatever.) What would help narrow down Sub suggestions (as others have already suggested, you will get the typical "everything" answer) is a specific price you want for a sub and your expectations.
If one is going to make a simplistic assessment of the value of different alignments, it would be that sealed/IB goes the lowest, at the highest cost per dB; horns have the lowest cost per dB at the expense of size, and vented box characteristics lie in between the other two. None is inherently superior across the board, neither is any inherently inferior across the board. The one to use is the one that fits your response and output needs, available space and bank account. -BFM
Jindrak is offline
post #6 of 18 Old 07-13-2012, 08:46 AM - Thread Starter
Thanks for the advice. This helps. The reason I was going to go with a spearate center channel is that when the Front L and R were installed there was not a cut out for the center channel. I was hoping to just get one that matched closely, but as you say, that might not be best. Thanks for the advice on the Subwoofer as well.
post #7 of 18 Old 07-13-2012, 10:49 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 522
I suggest the Mordaunt-Short Carnival 5 Center speaker, which is only $250 and is very good.
Do not make the mistake of getting a center speaker with drivers that are 5" or larger; that is too big.
A center speaker should give maximum clarity between 100 and 3 Khz. It should NOT put out any bass, so larger speakers are counter-productive. Smaller is better. 3 to 4 inches is ideal.
commsysman is offline
post #8 of 18 Old 07-13-2012, 11:13 AM
bfreedma's Avatar
Liked: 51
Why do you keep posting this fallacy?
bfreedma is offline
post #9 of 18 Old 07-13-2012, 12:12 PM
jproy13's Avatar
Liked: 26
jproy13 is offline
post #10 of 18 Old 07-13-2012, 12:34 PM
Scottyb09's Avatar
Quoted: 35 Post(s)
The only reason I would explore using a center channel different from your fronts is if you plan to also upgrade your fronts in the near future as well. If you don't, then go with the same brand. Ideally, it is best to get the exact same speaker as your fronts. The next best option is to get a center that is properly 'matched' to the fronts.
Scottyb09 is offline
post #11 of 18 Old 07-13-2012, 12:35 PM
Scottyb09's Avatar
Quoted: 35 Post(s)
Originally Posted by jproy13 View Post
Can't say I'd agree with this, and neither would my M&K S150AC center channel (which has 5 1/4" drivers). In fact, my next speaker purchase (whenever that is) will have 6 1/2" drivers across all three front speakers...
post #12 of 18 Old 07-13-2012, 10:44 PM
skiman24's Avatar
To meet the THX specs it must go down to 80HZ which kills your idea. I have the Definitive Technology Mythos Eight center which has 5.25" speakers; are you saying that my center is not good for maximum clarity?!?!? The center speaker should be the biggest investment in the system for the mere fact that if you are watching movies all the dialouge comes from the center speaker. If you skimp on the center speaker it will sound weak and will be overshadowed from the towers and sub. A good movie to test out the center is any of the Transformers movie and listen to Optimus Prime Voice.
skiman24 is offline
post #13 of 18 Old 07-14-2012, 09:22 AM
destiny 21's Avatar
Quoted: 12 Post(s)
ENERGY RCL
destiny 21 is offline
post #14 of 18 Old 07-14-2012, 01:10 PM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
Senior clueless strikes again. You really need to stop trying to give advice because all that I have seen you provide is bad advice.
post #15 of 18 Old 07-14-2012, 01:18 PM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
Just make your own cutout for it, it's not that hard. If there is a stud in the way all you have to do is cut a small bit of it out of the way and then build a frame around like you would a door or a window.
500
post #16 of 18 Old 07-14-2012, 07:15 PM
ccotenj's Avatar
Liked: 101
- chris
ccotenj is offline
post #17 of 18 Old 07-14-2012, 07:40 PM
Mike Garrett's Avatar
Quoted: 5575 Post(s)
Liked: 3554
500
No wider than the opening needed for a typical center speaker, the header could be a couple of 2x4's with some 1/2" plywood in between.
mjgarrett100@gmail.com
Mike Garrett is online now
post #18 of 18 Old 07-14-2012, 07:58 PM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
True, I was just trying to give him an idea of what I was talking about.
Reply Speakers
