Backer box for 6.5" ceiling speakers? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 07-13-2012, 07:55 PM - Thread Starter
onorio56's Avatar
Can someone give me the size for a backer box for monoprice 4103 ceiling speakers
Unfortunetly getting any information out of monoprice is like pulling teeth
thanks
onorio56 is offline
post #2 of 18 Old 07-14-2012, 06:24 AM
Bill Fitzmaurice's Avatar
Liked: 5682
That requires T/S specs for the drivers in question.
Bill Fitzmaurice is offline
post #3 of 18 Old 07-14-2012, 08:26 PM - Thread Starter
onorio56's Avatar
thats what I thought, no idea where to even find those
onorio56 is offline
post #4 of 18 Old 07-15-2012, 05:41 AM
Liked: 5682
If they exist Monoprice would have them. If they don't go elsewhere. It's not like you can't find plenty of drivers that do have specs posted.
post #5 of 18 Old 07-16-2012, 02:33 PM - Thread Starter
onorio56's Avatar
Unfortunetly I already own these.
Will try customer support again but I'm not holding my breath.
onorio56 is offline
post #6 of 18 Old 07-16-2012, 02:37 PM
Liked: 5682
I doubt they make them, so they may not have the specs. They should be able to get them from whomever they source the drivers from if they want to, but I guess as they already have your money that might not be high on their list of priorities. mad.gif
post #7 of 18 Old 07-16-2012, 02:44 PM - Thread Starter
onorio56's Avatar
yes, exactly....let you know what happens
thanks
onorio56 is offline
post #8 of 18 Old 07-19-2012, 11:15 AM - Thread Starter
onorio56's Avatar
reply back from monoprice:
In regards to your inquiry, unfortunately we dont have a box size specification for our speakers as many of our customers install them with out a box and in rare occasions such as yours might need one. We would recommend that as long as you do have 1/2 clearance from side to side around the back of the speaker that would be enough clearance for the speaker to have proper sound. We have included speaker stats for the item PID 4103 and is in PDF format.
Bill, can I email you the speaker stats to see if you can understand them...I know I certainly don't
onorio56 is offline
post #9 of 18 Old 07-19-2012, 11:26 AM
Liked: 5682
Post them here.
post #10 of 18 Old 07-19-2012, 11:51 PM - Thread Starter
onorio56's Avatar
I can't/don't know how its a PDF document
onorio56 is offline
post #11 of 18 Old 07-20-2012, 05:11 AM
Liked: 5682
Use the 'insert image' tool.
post #12 of 18 Old 07-20-2012, 05:24 PM - Thread Starter
onorio56's Avatar
onorio56 is offline
post #13 of 18 Old 07-20-2012, 07:00 PM
Liked: 5682
You'll get best results full range in a 1 cu ft (net of driver and duct) box with a 2" ID duct 2" long. Used with subs crossed over at 100hz use a 1/2 cu ft net sealed box.
post #14 of 18 Old 07-20-2012, 07:48 PM - Thread Starter
onorio56's Avatar
LOL
Bill, I'm still laughing
Unfortunetly like the specs I posted that means absolutely nothing to me...
Would you please simplify your last post for me
and just to clarify the speakers are 6.5" ceiling.
If I having said so already, thanks for all your help it is much appreciated
onorio56 is offline
post #15 of 18 Old 07-21-2012, 05:36 AM
Liked: 5682
That's as simple as it gets. If none of it makes sense to you some time spent here will help:
http://techtalk.parts-express.com/showthread.php?219617-The-Speaker-Building-Bible
post #16 of 18 Old 07-22-2012, 04:45 PM - Thread Starter
onorio56's Avatar
okay...got it
last question...
Insulation in the box or not? the box will be sealed
onorio56 is offline
post #17 of 18 Old 07-22-2012, 07:16 PM
Liked: 5682
okay...got it
last question...
Line it with an inch of polyester batting or open cell urethane foam. Stuffing is not required as the box Q is a perfect 0.7.
post #18 of 18 Old 07-25-2012, 07:01 PM - Thread Starter
onorio56's Avatar
All done, filled it with polyester batting
Thanks again for all the help
onorio56 is offline
Reply Speakers
