Monitor Audio Silver RX1 with Sonos Connect:Amp - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-15-2012, 11:00 AM - Thread Starter
dreamer81's Avatar
Hi all.. will the above combination work fine? And will the speakers be large enough to fill a 8 x 5 meter room???
I will consider adding a sub if the speakers are too small for this purpose.
dreamer81 is offline
post #2 of 3 Old 07-15-2012, 11:41 AM
commsysman's Avatar
Quoted: 980 Post(s)
Liked: 526
I would strongly recommend the Silver RX-2 speakers rather than the RX-1 for that size room; the RX-1 is way too too small. Adding a sub is not going to make up for the overall lack of audio output power capability from the RX-1.
The 8-inch driver of the RX-2 will do a much better job down to 50 Hz, and then the sub can take over below that. It has nearly twice the cone area of the RX-1, which you definitely need.
Neither of those speakers has much output below 50 Hz, so to produce that bass below 50 Hz you will definitely need a large 12-inch subwoofer with considerable power (300+ RMS watts) for that room; I suggest the Rythmic FV-12 or Klipsch RW-12D.
I personally doubt whether that amplifier has the sound quality or power needed for your application, but if you don't want it to play anything very loud or demanding, it might be OK. In general, the sound quality of Class D amplifiers is poor, and they misbehave when driven hard.
The Music Hall 15.2 is a MUCH better amplifier in terms of sound quality and has more usable power reserves for music peaks.
commsysman is offline
post #3 of 3 Old 07-15-2012, 12:30 PM
laughalot's Avatar
100% agree Had the RX1 and upgraded to the RX2's. Far better speaker in every respect. However on Friday upgraded again to gthe Focal Electra 1008 BE Much more e xpensive but a scary good speaker
"I know you for what you are not- for thats really all you are"-Don Mclean
laughalot is offline
Reply Speakers
