Been bitten by the upgrade bug :) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 07-16-2012, 02:08 PM - Thread Starter
nucl3arboNg's Avatar
Hey all just wanted to get some feedback to help me make the best decision for my situation. I am currently renting a small (1000 sqft) house but will be looking to buy my own in the next few years. My current HT is already going through an upgrade and am thinking maybe speakers next. As it stood past week my HT consisted of...
Panny 50" pz77u/Yamaha rxv-863/Energy CF-50 mains (bi-amped)/Energy CC-10 center/Energy CR-10 surrounds/paradigm dsp-3400 sub/Sony PS3
Just ordered a Panny 65" GT50 and replaced the Yamaha avr with a Pioneer svx-1122. What I've been looking at is replacing the Energy's with klipsch's (ya I know same make), some Paradigm monitors, a single or duel SVS subs, or wait a year or two to afford Paradigm studios. The system is pretty much used for everything....movies, cable, gaming, and music. Also will be playing a lot of Sirius through my AVR, and using a new WIDI laptop for music as well.
nucl3arboNg is offline
post #2 of 10 Old 07-16-2012, 03:09 PM
josh6113's Avatar
Quoted: 28 Post(s)
Liked: 26
What is your budget?
Doing what I do best...LIVIN!
josh6113 is offline
post #3 of 10 Old 07-16-2012, 03:39 PM - Thread Starter
Haven't really set a budget but right now it wouldn't be to high. I would probably have to do it in pieces and would like it to be a noticeable improvment on what I currently have. I've always dreamed of having Paradigms so would love some of the studios, but that is way outta my range ATM. I'm thinking the best possible choice would be to just upgrade the sub for now to either an SVS Ultra, a PB12 plus, or 2 pb12 nsd's. I do live in small town Canada so my options are limited if that helps any.
post #4 of 10 Old 07-16-2012, 05:50 PM
pronghorn/az's Avatar
Quoted: 20 Post(s)
Liked: 31
Your better off going to a Paradigm dealer and give a listen to the Monitor series, the Studio series and the Signature series. Get yourself a max budget with a sub. Your just might like the Monitor series and with the money saved over the others get yourself a quality ID sub.
Jeff
pronghorn/az is offline
post #5 of 10 Old 07-16-2012, 07:04 PM
aquaphile's Avatar
Originally Posted by nucl3arboNg View Post
I am renting a small (1000 sqft) house.... Just ordered a Panny 65"
2.0 > 7.1
aquaphile is offline
post #6 of 10 Old 07-16-2012, 08:02 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
No point in buying now if your funds are limited, and your living situation temporary. I know it's easier said then done, but the wisest thing would be to setup a savings account just for an audio budget, and put something like $100 month in it until you do move. You would then know exactly what your speaker needs are after moving, and have around $3k in the bank.
Jay1 is offline
post #7 of 10 Old 07-16-2012, 08:05 PM
ack_bk's Avatar
Quoted: 601 Post(s)
Liked: 686
I was going to say the same thing. You also don't know the space in your next place, and room can influence speaker choice.
You have a decent speaker setup now, so it is not like you are slumming.
ack_bk is offline
post #8 of 10 Old 07-17-2012, 11:06 AM - Thread Starter
Lol ya great points think I just needed convincing cause the lil devil inside me is trying to make me spend smile.gif. I can't really get a good listen because I have no Paradigm dealers locally.
post #9 of 10 Old 07-17-2012, 12:06 PM
Nuance's Avatar
Quoted: 22 Post(s)
Liked: 79
Originally Posted by aquaphile View Post
My journey to find the "perfect" speaker
No matter what measurements tell us, a loudspeaker isn’t good until it
sounds good. - Dr. Floyd Toole
Nuance is offline
post #10 of 10 Old 07-17-2012, 12:42 PM - Thread Starter
Originally Posted by Nuance View Post
Lol agreed......go big or go home! I will have like 10" between me and the tv so plenty of room.
Reply Speakers
