Need recommendation. Mirage speakers that are on sale? - AVS Forum | Home Theater Discussions And Reviews
Old 07-23-2012, 06:17 PM - Thread Starter
projecte36's Avatar
These mirage speakers and sub are on sale at wwstereo.com. What do you think about the setup? My living room size is about 24x13x8 (2496 cubic feet) and is open to a kitchen that is about (1,232 cubic feet). This setup is paired with a samsung 60 inch (UN60D6000). I will be using it for watching cable tv and movies. My budget is less than $1000 for receiver and a 5.1 sound system. Thanks.
Mirage OS3-FS (floorstanding speakers) $190
http://www.wwstereo.com/Mirage/OS3-FSHGBL
Mirage Omni S8 (sub) $141
http://www.wwstereo.com/Mirage/OMNI-S8
Mirage NANOSAT-PR-B (rear speakers) $76
http://www.wwstereo.com/Mirage/NANOSAT-PR-B
projecte36 is offline
Old 07-23-2012, 06:27 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
The subwoofer is way too small for that size room.
Afro GT
afrogt is offline
Old 07-23-2012, 06:31 PM - Thread Starter
projecte36's Avatar
Thanks I will remove the sub from my list. What size do you recommend?
Old 07-23-2012, 06:38 PM - Thread Starter
projecte36's Avatar
I don't know if this helps but here is the room layout.
room.jpg 505k .jpg file
Old 07-23-2012, 08:07 PM
wizard8873's Avatar
Every room is different so hard to say. Your choices for a 5.1 with receiver are limited with a budget of only $1000. Newegg has the Klipsch RW-12D subwoofer on sale for $300 currently. There's better subs out there of course but not for the money. If that puts you over your budget, you can look at the BIC F12 as that's a highly recommended sub for those on a budget.
Did you have an idea on the center channel and the receiver that you want?
Because great sound fills the room, shakes the house, breaks hearts, stirs souls, and always will
wizard8873 is offline
Old 07-23-2012, 08:15 PM - Thread Starter
projecte36's Avatar
I actually have the Pioneer VSX-1022-K receiver that I have never used yet ($315 on sale). I have no idea about the center channel yet. At this point, I'm not looking for the best speakers but hopefully something that sounds great for around $1000. Do you think the mirage speakers above are good enough? Thanks for your input. I will look into those subswoofers.
Old 07-30-2012, 02:38 PM
sumbadhatharry's Avatar
For your budget those speakers in my opinion are good speakers. For the longest time I used a V2CC and 2 nano CC for my front stage with 4 nanos and a S8 in a 20x25 room with hardwood floors and vaulted ceilings. I was happy until I made HT my hobby and then there was poison in the well.
If you can get the OS3-Sat by expanding your budget then do that but if not the OS3-fs will not overpower the nanos for Movies but you may not like the mix if you plan to use multichannel stereo. Also you should get a Mirage center, if you can get that now by taking a hit in the subwoofer then do that since you can use any subwoofer really but you shouldnt mix and match Mirage fronts with other centers. If not then you may want to seek other brands that you can mix and match with.
If you choose to go with the Mirage and you like the omnipolar sound then I think you will enjoy them. Just take some time to stash some money for a sub at a later date, since you are really wanting to stay within a budget the subs you can get for a low price won't go down as low as you will want anyway. You will probably need to spend between 300-500 to find a sub that is 24hz and below anyway. Heck if anything get the S8 and call it a day, despite what some may say the S8 served me well for years. If it means a full set-up then I say go for it.
sumbadhatharry is offline
