need small rear surrounds for my 7.1 - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 53 Old 07-31-2012, 09:53 PM
losservatore's Avatar
Quoted: 2673 Post(s)
Liked: 2444
here is the list of authorized dealers for the mirage speakers
http://www.miragespeakers.com/where-to-buy/online/
This is the info about the OS3-Sat Bookshelf Speaker
http://www.miragespeakers.com/surround-speakers/?sku=OS3-SAT
losservatore is offline
post #32 of 53 Old 07-31-2012, 10:45 PM - Thread Starter
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
thanks for the links.
given that i can get the smaller nanosats for about 50$ each and the larger ones for 250$ each, do you feel the upgrade is worth it or should i get just get the smaller ones?
mgrotel is offline
post #33 of 53 Old 08-01-2012, 06:46 AM
Skylinestar's Avatar
Quoted: 1214 Post(s)
Liked: 227
I have a question regarding rear speaker distance. My rear wall is about 12 feet behind my main listening position. I'm planning to add rear speakers to complete my 7.1 setup. Is 12 feet too far away? FYI, my front mains are about 9 feet away from MLP.
Skylinestar is offline
post #34 of 53 Old 08-01-2012, 09:09 AM
Liked: 2444
I recommend the os3 as they can go around 90hz to 80hz. you can get then for lower than to $250. I had see then many times for $150 brand new and around $120 used ones.
this store have then for $150
http://www.sounddistributors.com/buynow.asp?action=detail&prid=541&crid=269&cat_name=Mirage+Speakers
vanns last week they had around 7 open item in excellent condition for $120 each.
or check at ebay for used ones.
if you prefer vanns they do price match just tell then that sounddistribution an authorized dealer have then for $150.
post #35 of 53 Old 08-01-2012, 09:16 AM - Thread Starter
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
ok, thanks. does it make sense though to spend more on just my rear surrounds than i did on my entire LCR and side surrounds?
i spent 135$ for those 5 speakers total.
mgrotel is offline
post #36 of 53 Old 08-01-2012, 10:13 AM
Liked: 2444
honestly not.,it will be nice as a side surrounds and back surrounds together , but for just back surround no.
post #37 of 53 Old 08-01-2012, 10:17 AM - Thread Starter
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
and should i be worried about matching the rear speakers' sensitivity with the pioneers i have as fronts and surrounds? or is that not going to matter as much?
mgrotel is offline
post #38 of 53 Old 08-01-2012, 10:23 AM - Thread Starter
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
sorry to bombard with questions, but maybe i should replace my pioneer bs-21 side surrounds with some mirages so all 4 surrounds match??? what would you do?
mgrotel is offline
post #39 of 53 Old 08-01-2012, 02:53 PM - Thread Starter
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
REAR.pdf 36k .pdf file
ok, so just a recap, i need to figure out my rear surrounds to complete my 7.2 setup, the following is what i have so far:
Denon 2112 reciever
Pioneer C21 center
2 Pioneer FS-51 fronts
2 Pioneer BS-21s
2 Klipsch RW-12D subwoofers
The front 3.2 arrangement is set, but I have yet to finalize what i want to do with the surrounds. However, I have narrowed it down to two options (please see attached PDF):
1. buy another Pioneer FS-51 pair, use those as the side surrounds and move the BS-21s to the rear surrounds in the "1" locations in the closets. I would just open the closet doors when watching a movie, doing that would not bother me at all. since the speaker wire will be in the wall, i could hide the faceplate in the closets. It would also be a cleaner look with no rear channels visible when not watching a movie. i think the FS-51s would sound a lot better and i can get a pair for about 80$.
2. buy a set of mirage nanosats for about 100$ to ceiling mount as rear surrounds where the "2"s are in the pdf and leave the BS-21s as the side surrounds.
thoughts? im leaning towards the option 1 especially since the BS-21s and stands will be in a closet they will be less likely to get knocked over. the stands have some sharp corners too and there will be a 2 year old running aroung in my house soon smile.gif
mgrotel is offline
post #40 of 53 Old 08-01-2012, 08:41 PM - Thread Starter
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
bump
mgrotel is offline
post #41 of 53 Old 08-02-2012, 10:50 AM
Liked: 2444
well honestly I have two 7.1 setups and because of the very few movies with 7 channels sound,I decide to used then as front height,the surround back speakers where just there for months without been playing ,so I decide to place the speakers from back surround to front height and I was impress of the effect that I decide to keep then that way.
post #42 of 53 Old 08-02-2012, 11:03 AM - Thread Starter
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
i was planning to run it the THX mode or whatever so it would blend the 5.1 surround into 7.1 surround. have you tried that?
and what do the front height speakers add? do you just plug them into the same outputs as the front left and front right?
mgrotel is offline
post #43 of 53 Old 08-02-2012, 11:20 AM
Liked: 2444
post #44 of 53 Old 08-02-2012, 11:44 AM - Thread Starter
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
i guess i need to figure out if my denon 2112 even supports front height speakers, thanks
mgrotel is offline
post #45 of 53 Old 08-02-2012, 12:08 PM
willieconway's Avatar
Quoted: 166 Post(s)
Liked: 156
It does, see page 54 in the manual. Also, here are the specs from the Amazon product page:
Dolby Pro Logic IIz: With the option of two additional height channels, this feature adds a vertical dimension to the soundstage, providing more immersive surround sound.
Adjusting settings according to personal preference is not calibration.
Epson 5030UB, 100" Carada Criterion with Classic Cinema White, Onkyo TX-NR818, NHT Classic 3s, Classic ThreeC, SuperZero 2.1s, Mirage Omni S10, Oppo 103D.
My Blu-Ray collection
willieconway is offline
post #46 of 53 Old 08-02-2012, 03:43 PM - Thread Starter
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
cool, thanks
so the front height speakers get separate outputs? just wanting to know to make sure its ok to get a different type of speaker for it.
mgrotel is offline
post #47 of 53 Old 08-02-2012, 03:45 PM - Thread Starter
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
based on the rear view of the receiver on amazon, i do not see an 8th set of speaker connections. where does the front height speakers connect to? thanks
mgrotel is offline
post #48 of 53 Old 08-02-2012, 03:59 PM
afrogt's Avatar
Quoted: 1434 Post(s)
Liked: 982
There are two speaker terminals on the back of the 2112 that say Surr Back/Amp Assign. If you don't have surround back speakers then you can use those terminals for front height speakers. You just need to assign the amps for that purpose. Its definitely in the manual, see pages 54 & 58.
AVR 2112.jpg 123k .jpg file
Afro GT
afrogt is offline
post #49 of 53 Old 08-02-2012, 04:01 PM - Thread Starter
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
oh, so i cant have both, got it, thanks.
mgrotel is offline
post #50 of 53 Old 08-02-2012, 06:27 PM
Liked: 2444
To have both surround back and front height at the same time.You need a 9.1 av receiver.
post #51 of 53 Old 08-06-2012, 12:43 PM - Thread Starter
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
Originally Posted by KidHorn View Post
You want rear surrounds to act as bipolar speakers. They should be diffuse.
ok, so omni directionals would work good as rear surrounds. what about side surrounds? is it best for those to be directional or omni directional to match the rear surrounds?
mgrotel is offline
post #52 of 53 Old 08-06-2012, 03:43 PM
afrogt's Avatar
Liked: 982
From what I've read its better to have your rear surrounds as monopoles and the side surrounds as omnidirectional.
Or just get 4 omnidirectional speakers, that works too.
Afro GT
afrogt is offline
post #53 of 53 Old 08-06-2012, 04:44 PM - Thread Starter
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
ok, thanks.
that promo code expired for the mirage nanosats, does anyone know of a place to get them that cheap right now? or do they go on sale often on that website? thanks
mgrotel is offline
Reply Speakers
Denon Avr 2112ci Receiver , Pioneer Sp C21 130 Watt Rms 2 Way Speaker , Pioneer Sp Fs51 Lr Floorstanding Loudspeakers Black Pair , Pioneer Sp Bs21 Lr 80 Watt Rms 2 Way Speaker , Klipsch Rw 12d 12 Subwoofer Each , Speaker Systems , Subwoofers , Cambridge Audio S20 Speakers Dark Oak Pair
