Which of these speaker systems should I choose? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-25-2012, 02:47 PM - Thread Starter
avfanatic1's Avatar
Quoted: 74 Post(s)
Liked: 30
I'm helping a friend decide on an entry level home theater system for $500 for the speakers/sub and have narrowed it down to this list. Which of these are the best of is there another I should consider (I'd ideally not like to hear more since I'm trying to narrow down the list, but if it is really worth mentioning then give it a go...
In no particular order:
  • Klipsch HD 500 5.1 High Definition Theater system
  • Pioneer SP-BS41-LR Speaker System
  • Energy 5.1 Take Classic Home Theater System
  • Definitive Technology ProCinema 600 5.1 Speaker System (this may be a stretch $ wise though so unless it is really that much better)
Thanks in advance!
avfanatic1 is offline
post #2 of 3 Old 07-25-2012, 04:51 PM
Hspecialist's Avatar
Check out Frys Electronics website, gobs of Polk deals and some of those are for sure not "entry level" which makes the score that much better!
Brian in Bakersfield...
Hspecialist is offline
post #3 of 3 Old 07-25-2012, 07:29 PM
louisssss's Avatar
http://www.newegg.com/Product/Product.aspx?Item=N82E16882981013
i have no experience with this set, but for $299, i'd get it over any other HTIB out there.
+Buy a $200-33 receiver like the Pioneer VSX-1022 (thats what i got for 300) but theres many options out there.
louisssss is offline
Reply Speakers
