Timbre Matching - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By JimWilson
post #1 of 22 Old 07-26-2012, 02:15 PM - Thread Starter
WagBoss's Avatar
Can someone give some links to in depth explanations of timbre matching? Or try to convince me why it's so important? I have went my entire life and never had a timbre-matched front 3 speaker set-up. Is it possible to timbre match different brands? If I can't tell that there are different brands/timbres, should I even bother timbre matching because isn't the only thing that matters is how I hear it ? :P
WagBoss is offline
post #2 of 22 Old 07-26-2012, 02:21 PM
BeeMan458's Avatar
Liked: 813
It's not as important as some might want you to believe but see it in the light of having four different tires of the same size on your vehicle. I'm sure that when driving down the road, other than each tire having it's own road noise, you won't notice.
Timbre.
BeeMan458 is offline
post #3 of 22 Old 07-26-2012, 02:44 PM
JimWilson's Avatar
Quoted: 1263 Post(s)
Liked: 1560
Timbre/voice matching is really quite important, especially if you want more then a jumble of noise while watching your TV.
To an extent, yes. After all, you're the one who has to be satisfied. That being said... if you had the opportunity to hear what a properly tuned and timbre matched system sounds like you'd understand the difference. Instead of a cacophony of noise it's a symphony of sound.
No, because different companies go about reproducing sound in disparate ways.
If you want a decent guide to some of the basics try this link.
COmusicaddict likes this.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is offline
post #4 of 22 Old 07-26-2012, 02:59 PM - Thread Starter
WagBoss's Avatar
I don't have timbre matched and to me my speakers flow really well together
WagBoss is offline
post #5 of 22 Old 07-26-2012, 03:27 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
But have you heard timbre matched speakers as a comparison?
Afro GT
afrogt is offline
post #6 of 22 Old 07-26-2012, 04:14 PM - Thread Starter
WagBoss's Avatar
in imax, movie theatres, not at a house though.
WagBoss is offline
post #7 of 22 Old 07-27-2012, 11:04 AM
BeeMan458's Avatar
Liked: 813
Speakers that are not timbre matched, in the simple have a fingernail on the chalkboard, jarring quality to them. The closer the timbre match, the smoother the overall sound quality. A reaction along the lines of; Now that's what I'm talking about!
If your muscles are tight and the hair on your arms is standing up and you find yourself wanting to kill your system, you don't have timbre match. If you're kicked back, feeling all warm and fuzzy all over, you have timbre match. It's that or sonically you're brain dead which, if you think about it, is a good thing. With many here, it could go either way.
(j/k people)
post #8 of 22 Old 07-27-2012, 11:11 AM - Thread Starter
WagBoss's Avatar
(j/k people)
lol, only feel that way when i hear tv speakers XD
What do you think of the timbre matching between polk LSIM 704C and polk lsi9's?
WagBoss is offline
post #9 of 22 Old 07-27-2012, 11:23 AM
BeeMan458's Avatar
Liked: 813
I can't say for Polk Audio as personally, I moved away from them as fast as possible. Why, because I found them too laid back for my upfront aggressive tastes.
http://www.youtube.com/watch?v=hWs0CezaK6Y&feature=related
Loud and bassy.
post #10 of 22 Old 07-07-2015, 12:06 PM
dekard's Avatar
I've been trying to get an answer to this very question. Did you ever try it?
dekard is offline
post #11 of 22 Old 07-07-2015, 04:13 PM
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 938
Timbre match........hmmmmmmmm
Timbre matching produces "Symphony of sound?"
Not using timber matched speakers all around produces same similar sound as fingernails moving across a chalkboard?
Ok........
BTW, same two speakers can/will not match exactly across full frequency spectrum.........not to mention changing speaker location can change impression of timbre.
Match speakers by frequency response, sensitivities, and rms capabilities..........let eq do the rest. Same speakers ie "timbre matched" speakers can make process of calibration much easier......that's it.
doublewing11 is offline
post #12 of 22 Old 07-07-2015, 04:23 PM
Quoted: 229 Post(s)
Liked: 938
Measure two identical speakers and watch how dissimilar FR is........
I've seen rooms using three, yes three different speaker manufacturers in their system......sound was "Symphonic!"
Granted, the guy is a Guru regarding integrating....EQ!
post #13 of 22 Old 07-07-2015, 04:56 PM
djp2k7's Avatar
Quoted: 105 Post(s)
Liked: 45
Where I've found it's evident that speakers aren't timber matched is during panning sounds from speaker to speaker. The different timbre stands out and becomes noticeable. For example when the sound of a plane pans from front right to surround right
djp2k7 is online now
post #14 of 22 Old 07-07-2015, 05:11 PM
dekard's Avatar
Agreed! It's even worse when the camera pans and moves a voice from l\r to the center.
dekard is offline
post #15 of 22 Old 07-07-2015, 05:13 PM
Quoted: 229 Post(s)
Liked: 938
Doppler effect.........shouldn't sound exactly the same
post #16 of 22 Old 07-07-2015, 06:23 PM
SchattenJager's Avatar
Quoted: 98 Post(s)
Liked: 47
A sound going across the front soundstage ( Left to Center to Right) should have the same sound qualities, otherwise it could be distracting for discerning listeners. However, if you honestly can't tell the difference (even after listening to a properly calibrated and timbre matched system), then you shouldn't need to worry about it.
SchattenJager is offline
post #17 of 22 Old 07-07-2015, 06:36 PM
nvidio's Avatar
Quoted: 381 Post(s)
Liked: 121
Ok........
The left and right speakers obviously are placed closer to a side wall than the center speaker is. So due to the combined effect of SBIR ( http://www.gikacoustics.com/speaker-...-response-sbir ) and modal ringing you will get waterfall plots in REW that look wildly different for the center speaker than they do for the left or right speaker no matter what, and no amount of EQ is going to help fix that problem because an accurate un-smoothed hi res waterfall plot says a thousand times more about timbre than any frequency response curve ever will, with or without the EQ. You can flush mount your speakers if their design dictates that you should flush mount them. You can install two boatloads of broadband absorption everywhere in your room. And you can choose to believe that you can cheat physics.
nvidio is offline
post #18 of 22 Old 07-08-2015, 09:20 AM
dekard's Avatar
Wow, that's a lot of words. Even if they're all true, the effects will apply equally to a set of speakers that are matched and a set that aren't match. So, it's irrelevant. Besides, you are talking about frequency response and EQ curves, voice matching has little to do with a standard freq\eq. It's more about tone and SQ, which frequency graphs are quite bad at demonstrating.
I've run matched and unmatched speakers and you can easily tell the differences. Can you still enjoy the setup with unmatched speakers? Sure! But having a set of matched speakers will produce a more coherent sound stage.
dekard is offline
post #19 of 22 Old 07-08-2015, 09:43 AM
It is what it is
Molon_Labe's Avatar
Quoted: 1858 Post(s)
Liked: 1913
I am a fan of using the same speaker for L/C/R and surrounds. Having done mismatched in the past, and timbre matched speakers for the same "family", there is no comparison compared to identical speakers in the sound field. Unfortunately, Atmos/DTS:X is going to require that I depart from this design.
Molon_Labe is offline
post #20 of 22 Old 07-08-2015, 11:28 AM
jaeelarr's Avatar
Quoted: 46 Post(s)
Liked: 42
Personally, i think timbre matching is overblown. Others live and die by it. If it doesnt bother you, than i wouldnt stress on it. I have never timbre matched have never experienced "chalk board" like qualities.
jaeelarr is offline
post #21 of 22 Old 07-08-2015, 11:43 AM
Elihawk's Avatar
Quoted: 1013 Post(s)
Liked: 854
For two years I had a mismatched front, in fact, ribbon tweeter center and dome tweeter L/R and thought it sounded real good...until I bought the correct center- WOW, what a difference. What I thought was good now sounds like utter crap! Everything is relative....
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is offline
post #22 of 22 Old 07-08-2015, 12:13 PM
nvidio's Avatar
Quoted: 381 Post(s)
Liked: 121
If by 'irrelevant' you mean that trying to timbre match a center speaker to the left and right speaker is, due to the effects of SBIR and room modes, less relevant than many think, then I will agree.
That is pretty much *exactly* what I said, i.e., "no amount of EQ is going to help fix that problem because an accurate un-smoothed hi res waterfall plot says a thousand times more about timbre than any frequency response curve ever will, with or without the EQ."
Like I said, that greatly depends on the speaker placement, the listening position, and the room acoustics. For example, would you prefer surround speakers that are placed way too close to the side walls so that they will sound crappy as a result from that, but are identical to the left and right speakers that are placed at a much farther distance from the side walls so that *they* will sound great, or would you prefer surround speakers that are designed to be nearfield/midfield so that they can be placed at a farther distance from the side walls when you can adjust the speaker distance in the settings of your AVR or processor/preamp accordingly?
nvidio is offline
Reply Speakers
