Looking for a speaker buying guide or help purchasing some - AVS Forum | Home Theater Discussions And Reviews
Old 07-26-2012, 06:57 PM - Thread Starter
kjb1686's Avatar
Hi everyone i am in the market for a half way decent set of speakers so i was looking to find a guide or someone to help me with this. I don't know the first thing about speakers all i know is that there are 2.1 ones and 5.1 ones after that i don't know which i need or what i need. I was looking for some help buying some i don't know what a good price range would be either i was thinking about 100-150 that sound about right. If i can get some decent ones for cheaper i will now i won't be getting these for another week or so but i wanted to be able to get some research done before i make my purchase. I would appreciate any help that someone can give me thank you.
kjb1686 is offline
Old 07-26-2012, 07:17 PM
Hspecialist's Avatar
There is a Phillips HTIB type setup for 199 on walmart.com
Hspecialist is offline
Old 07-27-2012, 06:36 AM - Thread Starter
kjb1686's Avatar
Bump
kjb1686 is offline
Old 07-27-2012, 06:53 AM
BeeMan458's Avatar
Liked: 813
First step would be to go by a Best Buy and see what tickles your fancy and get an idea of what's available, for what price so you realistically have a better feel of what works for your budget.
This review article might get you started.
BeeMan458 is offline
Old 07-27-2012, 07:08 AM
JimWilson's Avatar
Quoted: 1270 Post(s)
Liked: 1581
There's no mention of the receiver you have, what you plan on using the speakers for or room size, so it's going to be very difficult for anyone to really help much. For your projected budget you can pretty much assume anything you buy will be of dubious quality though; that's simply not enough $$ to ensure anything but compromise.
Some of the least expensive (but still usable) systems I can think of are the DefTech ProCinema 60.6 and the Klipsch HD 500. However, they're twice your budget, and would still only work in small rooms.
If you want to read some information about speakers in general try this link. It takes you through some of the basics.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is offline
Old 07-27-2012, 07:08 AM - Thread Starter
kjb1686's Avatar
Well i would go to a best buy but the closest one from me would be about 70 miles from where i live. The only stores i have in town is a walmart yes that is all i have near me without having to travel a good distance. I might just go to the best buy website and look around and see what i can find.
Well my room is about medium size i will be sitting maybe 2 feet away at a desk. I will be using these to watch movies and play games. As of right now i am only using my speakers on my computer so i have no setup at all which is why i am looking to upgrade to get a good system. Well i can go higher i just didn't know which price would be perfect, i will be going back to school in about a month so i will be getting some money from there so i can easily upgrade my budget to about 300-400 dollars then.
kjb1686 is offline
Old 07-27-2012, 07:16 AM
gprace's Avatar
Quoted: 359 Post(s)
Liked: 5658
Just my opinion, but maybe you should go to Best Buy so that you can demo some speakers and determine what sounds best in your price range. Also, while in the store, check out their open box and demo sales.
LG Oled65E6P, Arcam AVR400, OPPO UDP-203, ATV3, Samsung DVR, Rega P3 turntable, Bellari VP130 Phono Pre Amp, Vienna Acoustics Mozart Grand SE Fronts, Vienna Acoustic Maestro Center, Vienna Acoustic Bach Rears, Rel T3 Sub
gprace is offline
Old 07-27-2012, 07:32 AM
LCDeez's Avatar
Ok well Ill give a few tips:
1) 2.1 is considered a "stereo" setup and usually consists of 2 main speakers + optional subwoofer (for deep bass). This is generally preferred for music lovers.
2) 5.1 is considered "surround sound" or "home theater" setups and consists of 5 speakers - 2 mains (left and right), 1 center channel (in the center of the viewing area) , and 2 surround speakers (placed behind the seating area). + the optional subwoofer( again for deep bass).
Deciding between them comes down to preference and use. For movie watching...5.1, for music and gaming...prob 2.1. For all of the above...5.1 .
With a $200 budget its gonna be tough to get any descent speakers AND a amplifier. I am not a fan of Home Theaters in a Box as they are usually pretty bad in terms of sound and quality, but they do offer a descent bang for your buck.
So you have a few choices...grab a home theater in a box, accept that the sound quality will be mediocre, and go on down that road...or
"invest" the $200 in a nice stereo or 5.1 home theater receiver and next paycheck grab some speakers and build a system (it can take time as a lot of people will tell you)....or hit the used market and sniff out a great deal on some good used gear.
I will leave you with my suggestions for "cheap" speakers to get your started:
Pioneer entry level speakers - http://www.newegg.com/Product/Product.aspx?Item=N82E16882117403
- http://www.newegg.com/Product/Product.aspx?Item=N82E16882117405
-http://www.newegg.com/Product/Product.aspx?Item=N82E16882117406
Energy -http://www.vanns.com/shop/servlet/item/features/542469405/energy-rc10
-http://www.vanns.com/shop/servlet/item/features/542796859/energy-cb5
NHT - http://www.crutchfield.com/p_228SZ20B/NHT-SuperZero-2-0.html?tp=186
Polk - http://www.crutchfield.com/p_107R150/Polk-Audio-R150.html?tp=186
-http://www.amazon.com/Polk-Audio-TSi200-Bookshelf-Speakers/dp/B0018QRO9A/ref=sr_1_4?s=electronics&ie=UTF8&qid=1343395551&sr=1-4&keywords=polk
-http://www.amazon.com/Polk-Audio-Monitor-Floorstanding-Speaker/dp/B0002Z240W/ref=sr_1_20?s=aht&ie=UTF8&qid=1343395631&sr=1-20&keywords=polk
This list could get really long. But those are a good place to start. My suggestion is to build a system. If you absolutely have to have a 5.1 right now with $200, looks like a Home theater in a box is gonna be your best option. If you are willing to start with a 2.1 and upgrade I suggest the following setup:
- http://www.newegg.com/Product/Product.aspx?Item=N82E16882117405 + http://www.amazon.com/Denon-AVR-1312-Channel-Theater-Receiver/dp/B004U403S6/ref=sr_1_2?s=electronics&ie=UTF8&qid=1343395873&sr=1-2&keywords=audio+video+receiver
That comes out to about $220 bucks. Others could have better advice, just my 2 cents
-cheers
LCDeez is offline
Old 07-27-2012, 07:40 AM
BeeMan458's Avatar
Liked: 813
My suggestion would be, if you can, make the drive. I like road trips. Grab a loved one or a friend and make an outing out of it. Enjoy the scenery of the drive, check out Best Buy and have a hamburger and fries to make it all worthwhile. Instead of making the drive a chore, make it an adventure in buying speakers. Did I mention that I like road trips? biggrin.gif
Old 07-27-2012, 06:25 PM - Thread Starter
kjb1686's Avatar
Well i get paid next friday so i might take a drive over to where my closest best buy is and have a look around. Hopefully i can find some ideas and then when i get paid next i will look into purchasing or upgrading what i might get.
kjb1686 is offline
Old 07-27-2012, 07:15 PM
zieglj01's Avatar
Quoted: 941 Post(s)
Liked: 846
I prefer a receiver and bookshelf speakers to start -
however, if sitting 2 feet back and on a tight budget >
then look at this Denon/Boston setup.
http://www.accessories4less.com/make-a-store/item/DENDHT1312BA/DENON-DHT-1312BA-Home-Theater-System-w/Boston-Acoustics-Speakers/1.html
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
