Gauge AWG cable to use for speakers? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 07-26-2012, 11:42 PM - Thread Starter
flyhigh123's Avatar
I have a pioneer receiver 1122 and will be powering polk speakers, 2 monitor 70 and CS2, the rears are M60's. Longest run is about 25 feet of wire.
I was wondering for speaker wire if I should buy 14 or 16 gauge CL2 speaker wire?
Anyone can let me know?
flyhigh123 is offline
post #2 of 8 Old 07-27-2012, 05:56 AM
Bill Fitzmaurice's Avatar
Liked: 4630
Use this to find out:
http://www.bcae1.com/images/swfs/speakerwireselectorassistant.swf
Bill Fitzmaurice is offline
post #3 of 8 Old 07-27-2012, 07:43 AM
BeeMan458's Avatar
Liked: 813
Get multi-strand, oxygen free, 12AWG zip line and be done with it. Terminations are extra.
BeeMan458 is offline
post #4 of 8 Old 07-27-2012, 07:53 AM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
I recommend reading this site:
http://www.roger-russell.com/wire/wire.htm
Proper gauge wire is the key, no reason not to buy your wire from Monoprice and save money. "Magic cables" are a myth..
ack_bk is offline
post #5 of 8 Old 07-27-2012, 07:59 AM
BeeMan458's Avatar
Liked: 813
Who are you kidding, they're real. Magic cables make your money disappear and magically reappear again in somebody else's pocket. It's true.
post #6 of 8 Old 07-27-2012, 08:37 AM
WagBoss's Avatar
this
WagBoss is offline
post #7 of 8 Old 07-27-2012, 09:00 AM
PeterK's Avatar
Quoted: 41 Post(s)
Liked: 54
And when in doubt use larger wire (smaller gauge # = larger diameter). While surrounds don't draw much current, the wire feeding them tends to be much longer and longer wire gives more voltage drop. I use 12 gauge wire for everything - from Monoprice. 16 gauge wire is marginal to me but may be fine for your usage.
PeterK is offline
post #8 of 8 Old 07-27-2012, 09:15 AM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
This is good advice. Since I ran my speaker wire through my walls when I was finishing my basement, I also planned for 4ohm speakers even though I currently have 8ohm speakers... You never know what the future holds (I may eventually buy 4ohm speakers) and I read more and more reviews where speakers that are rated as 8ohm, really should be rated 4ohm.
ack_bk is offline
Reply Speakers
