5.1 Speakers to go with Denon AVR-1713 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 07-30-2012, 02:41 PM - Thread Starter
Hi all. We've moving into a new condo unit and am planning to set up a new 5.1 system. (had a really cheap sony HTIB before)
Decided to get Denon AVR-1713 and am wondering what your recommendations for speakers are. I've looked at Energy, Polks, Paradigm, and there are still so many other brands. We need to decide on the speaker within the next couple days so we can have it ready when the wiring guy arrives later this week to hide all our cables in walls/under floors, which is why I've turned to you guys for help in narrowing down the choices so we can make the decision quickly.
Usage and source:
Gaming and blu-ray movies from PS3, connected through optical (70%)
Cable from digital cable box through HDMI (10%)
Misc. content from the tv (low def stuff), connected through HDMI (10%)
Music via Airplay or USB (10%)
Here's our living room layout: (have a combined living/dining)
We prefer to spend under $1000 for the speakers but the budget can be adjusted up. Also, we have no wall or shelf behind or beside the couch so the rear surround speaker would probably have to be floorstand?
Thanks in advance for help.
kend7510 is offline
post #2 of 11 Old 07-30-2012, 03:21 PM
smasher50's Avatar
Quoted: 377 Post(s)
Liked: 18551
fwiw, pair of hometheater direct level3 bookshelves for front $300
htd level3 center $200
pair of level2 bookshelves for rears $200
energy s10.3 sub $200 newegg
you might want to place the rear speakers on speaker mounted brackets like the pinpoint am40's( $60 a pair... great brackets) on the adjacent walls about 5-6ft. high above the couch pointed at each other just a suggestion
i'm so laid back,i'm laid out
smasher50 is offline
post #3 of 11 Old 07-30-2012, 04:17 PM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 567
I suggest that you get the Jamo S506 system, which should cost around $700, and the Klipsch RW12D subwoofer, for around $300.
The rear speakers can be mounted on small wall-mounted shelves.
commsysman is offline
post #4 of 11 Old 07-30-2012, 04:35 PM
afrogt's Avatar
Quoted: 1365 Post(s)
Liked: 947
Umm, the S606 system is a heck of alot cheaper, $400 vs $700 for the s506.
http://www.vanns.com/shop/servlet/item/features/544231343/jamo-s606hcs3?s_c=site_search
Afro GT
afrogt is online now
post #5 of 11 Old 07-30-2012, 07:39 PM - Thread Starter
A dealer is recommending the PSB HT-2 system for $700. Would that be a good option?
kend7510 is offline
post #6 of 11 Old 07-30-2012, 08:59 PM
afrogt's Avatar
Liked: 947
If you want smaller speakers the Image HT2 isn't bad, They only have 4" woofers though. I'd like larger speakers than that up front. Good price though.
Afro GT
post #7 of 11 Old 07-31-2012, 12:45 PM - Thread Starter
I inquired about upgrading some speakers in the HT2 package but the sales guy said the $700 is a special price point for the package; changing anything with be significantly more expensive. For instance, upgrading the front B4s to B5 would increase the price from $700 to $950.
I also got another deal: Klipsch F-10 system for $970.
(http://www.klipsch.com/f-10-home-theater-system)
Which would be the better option? We have enough space in the front for two floorstands. Thanks!
kend7510 is offline
post #8 of 11 Old 07-31-2012, 01:03 PM
smasher50's Avatar
Quoted: 377 Post(s)
Liked: 18551
fwiw, looking at your diagram it looks like your sitting about 7' away from tv,imo bookshelf speakers are going to give you more of a soundstage compared to towers which will be in your face. iwould also look into front ported speakers so you can place near the walls without any distortion or boominess. rear ported speakers will have to be put away from the walls puting them even closer to you making for a not so good sound just my 2 cents
post #9 of 11 Old 07-31-2012, 01:17 PM - Thread Starter
kend7510 is offline
post #10 of 11 Old 07-31-2012, 01:33 PM
smasher50's Avatar
Quoted: 377 Post(s)
Liked: 18551
fwiw , again its your money and choice but the htib are not going to give you the sound of some nice bookshelves and a good sub.those speakrs that come in those htib have small drivers so you just don't get the same sound and those subs imo are mostly boom boxes i just think you can do better for $900
post #11 of 11 Old 07-31-2012, 06:40 PM
DR.DTS's Avatar
Quoted: 25 Post(s)
For that size of space I'd throw in...
Energy RC-1 Micro 5.1 which currently at Crutchfield is a steal at this price.... http://www.crutchfield.com/p_732RCMIC/Energy-RC-Micro-5-1.html?tp=184
Another is the...
Definitive Technology ProCinema 400 like this... http://www.crutchfield.com/p_735PCIN4B/Definitive-Technology-ProCinema-400.html?tp=184
I haven't heard these but being Boston you can expect some good sound. For your space they should fit nicely. I've read several reviews and users are and have been surprised by the sound coming from the small SATs.
Boston Acoustics SoundWare XS 5.1... http://www.crutchfield.com/p_065SDWX51B/Boston-Acoustics-SoundWare-XS-5-1.html?tp=184#overview-tab
DR.DTS is offline
Reply Speakers
Denon Avr 1713 Receiver
