Speakers Popping when Sound Interrupted on Xbox 360 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-31-2012, 06:59 PM - Thread Starter
Kimoosabi's Avatar
Maybe this is a totally normal thing that I am being completely OCD about, but I've noticed in certain games that when the sound is interrupted I sometimes hear a "pop" in the audio. Say for example, in the XBLA game From Dust, if I pause the game during a loud thunder crack or rolling wave, I tend to hear a "pop" as it pauses. In other games, if I cut off a cutscene mid-play by skipping it etc. I'll also get a pop when the sound is interrupted.
Is this normal, or is there something wrong with my speakers? I connect my 360 to a monitor via VGA connection, and then run the audio to my PC speakers.
Kimoosabi is offline
post #2 of 4 Old 08-01-2012, 06:49 AM - Thread Starter
Kimoosabi's Avatar
Bump
post #3 of 4 Old 08-03-2012, 03:20 PM
DonH50's Avatar
Quoted: 2100 Post(s)
Liked: 1664
Probably normal. You are cutting off the sound in the middle of a transient; the popping noise is the system re-equilibrating around the common-mode point. Also, some audio tracks do not break off cleanly so it may be happening in the audio codecs or sound card. Probably not a problem.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #4 of 4 Old 08-04-2012, 05:45 AM
SaviorMachine's Avatar
Liked: 90
I've definitely heard pops coming from track changes in purely digital signal streams, like when playing music on my computer (rarely) or through the USB port on a couple of my receivers (less rarely). I think this is just a switching goof-up in the sound processing hardware; I think it's similar to what you've been experiencing and I think it's harmless.
Once again, I am sorry to take a sledgehammer to so small and fragile a nut. -- Richard Dawkins, The Greatest Show On Earth
SaviorMachine is offline
Reply Speakers
