How many 10W speakers(100 volt) can be connected to 150W amplifier?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-01-2012, 04:12 AM - Thread Starter
shaddu's Avatar
I have ALTO TMX80dfx mixer amplifier and Proel XE51CT speaker. I want to know if its compatible with each other.
shaddu is offline
post #2 of 5 Old 08-01-2012, 05:44 AM
Bill Fitzmaurice's Avatar
Liked: 5687
As many as you wish, so long as you wire them with the appropriate series/parallel configuration to keep the total impedance load within the amplifier's capacity.
Bill Fitzmaurice is offline
post #3 of 5 Old 09-12-2012, 11:39 PM - Thread Starter
shaddu's Avatar
I have 16 numbers of Proel XE51CT ceiling speaker(100V with transformer) and a ALTO TMX80dfx powered Mixer?? Will this be compatible with each other?? Or Is there any other solution
shaddu is offline
post #4 of 5 Old 09-13-2012, 05:37 AM
ShaQBlogs's Avatar
Quoted: 27 Post(s)
What do you mean by connect multiple speakers? can you be more specific on how you intend to connect.
I mean, Do you intend to connect them to just the left and right channel... such that 8 speakers in series/parallel to the left channel and 8 to the right channel?
Or do you intend to use multiple channels and connect them appropriately.
ShaQBlogs is offline
post #5 of 5 Old 09-15-2012, 12:21 PM
LeBon's Avatar
Quoted: 184 Post(s)
Liked: 88
Those speakers appear to be designed for a constant-voltage distribution system. Google for references on that. Usually the transformers have taps to determine how much wattage goes to the individual speaker.
LeBon is offline
Reply Speakers
