Plz help me so that I DON'T end up purchasing BOSE - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 58 Old 08-04-2012, 06:29 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
Originally Posted by Bill Fitzmaurice View Post
As opposed to putting them on the floor where the high frequencies can't be heard? As for their size, if you want high sensitivity you'll only get it from a large cab. In the OP's case high sensitivity speakers seem a more viable alternative than dropping the ceiling eight feet.
Well definitely not on the floor. I just think of the SHO's as more of a speaker that you would place on a stand.
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
post #32 of 58 Old 08-04-2012, 06:32 AM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
Guys, it looks like he is sitting almost 22' away from his speakers! With 18' ceilings also this is a big challenge. I think Bill is spot on, he will need the most sensitive speakers out there. The SHO 10's/Pro 10's make a lot of sense. Yes, he will have to buy his 5.1 setup in stages, but sticking less sensitive speakers in that space will not make much sense.
OP, any chance you can move that couch forward? I am not even sure how you can see much detail from the TV at 22' back...
ack_bk is offline
post #33 of 58 Old 08-04-2012, 07:08 AM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
Right! I sit 10 feet away (lee even) from a 120 inch screen.
Plus sitting against the back wall is not the best place for surround sound either.
psgcdn is offline
post #34 of 58 Old 08-04-2012, 07:08 AM
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
IME SHOs sound better when positioned on or close to the wall. ( I suspect that this is because the baffle step is not an issue).
Even though the SHO-10 may look large, they are actually shallower than many bookshelf speakers out there.
But if one is looking for a speaker that will disappear in the leaving room decor, then SHO may not be the right choice.
zheka is online now
post #35 of 58 Old 08-04-2012, 10:31 AM
losservatore's Avatar
Quoted: 2337 Post(s)
Liked: 2078
I think that the SHO wouldn't look big in that big room,He have plenty of space for larger speakers,Those bookshelf will look small in that room so they can be positioning on the walls,They wont look bad at all.But definitely he need a high sensitivity speaker with compression horn tweeter.
other wise you will have to move your seating position more closer for other type of speakers.
Living Room :Oled 65" B6 / Marantz SR7010 / Xbox One S / PS4 Pro / HTPC / 2 PSA XS30 / Revel Performa3 F206 / Revel Performa3 C205 / Revel Surrounds / Sonos Connect / Roku 4 Ultra /Amazon Fire tv /
losservatore is offline
post #36 of 58 Old 08-11-2012, 01:27 PM - Thread Starter
Hustler's Avatar
Alright guys. So I have decided to go with the HTD flat panels for now. Also decided on the AVR-1912 from accessories4less. That brings my total expense to $925.00.
Now the only thing left is the sub.....So just like you guys suggested the minimum requirements for speakers for my relatively large room, what are the minimum requirements for the SUB? Also any suggestions that would match my picks? I am thinking, I may spend some extra cash and get the whole system all together.
Btw, Bill, really appreciate your advice and I will definitely be looking at these SHO's for my basement home theatre. It just that I dont like to hang bookshelves in my family area, plus they are a bit out of the budget right now. With that being said, I am usually the kind that "buys once and cries once" but I will have to make an exception in this case. Once again, appreciate your time and advice.smile.gif
Hustler is offline
post #37 of 58 Old 08-11-2012, 01:35 PM
zieglj01's Avatar
Quoted: 958 Post(s)
Liked: 855
The HTD Flat Panel speakers are good, I would still move that couch forward. How much budget do you have left for a sub?
No need to worry about brand matching a subwoofer.
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #38 of 58 Old 08-11-2012, 01:54 PM - Thread Starter
Hustler's Avatar
So right now, I am planning to hang the surrounds on the side walls, facing the couch. I did move the couch about 6 inches forward from the rear wall. As far as budget, I guess, just like speakers, it will depend on what is the minimum required sub size in my room.
Also, hanging the surrounds up high like 10 -11 ft shouldn't be an issue right? I am thinking of tilting them a bit downwards towards the couch. Another question was that the avr-1912 outputs 90watts each, but the HTD surrounds are rated for 80 watts max, any issue there?
http://www.htd.com/Products/flat-panel-speakers/middy-compact-speaker
and just to confirm, I am looking at the Middy Compact Speakers from HTD for the surrounds.
Hustler is offline
post #39 of 58 Old 08-11-2012, 03:00 PM
smasher50's Avatar
Quoted: 356 Post(s)
Liked: 15904
fwiw,if you can bring the surrounds down to about 5-6ft.off the floor would be better. should have no problem with wattage issue and if don't mind buying used a member is selling his eD a2-300 sub for $200 in the avs classifieds just a suggestion
i'm so laid back,i'm laid out
smasher50 is offline
post #40 of 58 Old 08-11-2012, 05:14 PM
zieglj01's Avatar
Quoted: 958 Post(s)
Liked: 855
Lower your surrounds, the Middy will be fine and will timbre match the Flat Panels. As long as you do not
use extreme volume levels, the 1912 with the speakers will be OK. Things can sound better if you can find
a way (have room), to move the couch up even more.
Who AM I
zieglj01 is offline
post #41 of 58 Old 08-11-2012, 08:00 PM - Thread Starter
Hustler's Avatar
slight change. I think, I am leaning more towards Denon AVR-2112CI as compared to 1912. Seems to have more features plus Audyssey MultEQ XT seems to be a good thing to have. smile.gif
Hustler is offline
post #42 of 58 Old 08-11-2012, 08:16 PM - Thread Starter
Hustler's Avatar
cant move the surrounds any lower due to the fact that one side of the room doesnt have a wall, rather a hallway rolleyes.gif
Hustler is offline
post #43 of 58 Old 08-11-2012, 08:26 PM
zieglj01's Avatar
Quoted: 958 Post(s)
Liked: 855
Then tilt/aim them down. A lot of people do this.
Who AM I
zieglj01 is offline
post #44 of 58 Old 08-11-2012, 08:40 PM - Thread Starter
Hustler's Avatar
dont mind used at all. But, is this the sub (eD a2-300) that will be enough for me?
Hustler is offline
post #45 of 58 Old 08-11-2012, 09:04 PM
zieglj01's Avatar
Quoted: 958 Post(s)
Liked: 855
I would look at the Outlaw subs, they will play pass 100 hz
http://www.outlawaudio.com/products/lfm1plus.html
Who AM I
zieglj01 is offline
post #46 of 58 Old 08-12-2012, 08:01 AM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
+1
Elemental Designs has had a lot of problems with their products and service. I would stay away from them. The Outlaw LFM-1 Plus or the HSU VTF-2 MK4 would be good choices.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #47 of 58 Old 08-12-2012, 06:06 PM - Thread Starter
Hustler's Avatar
well, ~$500.00+ is a bit out of the budget, since I have yet to buy a 3d player as well.
Hustler is offline
post #48 of 58 Old 08-12-2012, 06:30 PM
zieglj01's Avatar
Quoted: 958 Post(s)
Liked: 855
The Klipsch RW-12, is $299 til midnight
http://www.newegg.com/Product/Product.aspx?Item=N82E16882780078
Who AM I
zieglj01 is offline
post #49 of 58 Old 08-12-2012, 08:58 PM - Thread Starter
Hustler's Avatar
any issues with having this sub on hardwood floor? Do have kids in the house so side firing might be an issue....
Hustler is offline
post #50 of 58 Old 08-12-2012, 09:59 PM
zieglj01's Avatar
Quoted: 958 Post(s)
Liked: 855
Some people use a subwoofer isolation riser - your subwoofer will have a grill
http://www.amazon.com/Auralex-Subwoofer-Isolation-15x15x2-inch-Charcoal/dp/B001140OZ0/ref=sr_1_1?ie=UTF8&qid=1344830020&sr=8-1&keywords=subwoofer+pad
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Dmi&field-keywords=Auralex+SubDude+Subwoofer+Isolation+Riser
Who AM I
zieglj01 is offline
post #51 of 58 Old 08-12-2012, 10:03 PM - Thread Starter
Hustler's Avatar
Hustler is offline
post #52 of 58 Old 08-20-2012, 10:23 AM - Thread Starter
Hustler's Avatar
Got the speakers delivered. Impressed with the packaging as they were double boxed and then in a cloth bag. Nice build quality as well. Haven't tested the sound yet. Will keep you guys posted.
Hustler is offline
post #53 of 58 Old 08-20-2012, 07:29 PM
beezar's Avatar
I think you are still too far away from the front speakers and way too close to the back wall. It would be difficult to get good surround sound being that close to the back wall (look up stuff on ideal surround speaker placement). I would suggest moving the couch 8' forward so you will be 14-16' from the TV. That would greatly improve your sound by improving the surround speakers as well as making it so you won't be too far from the fronts (especially since your front speakers are relatively small for the size of that room). Also, an 80" TV from 14' would look fantastic compared to 22' away.
Moving up the couch closer may not look as bad as you might think; I used to have mine on the back wall and moved it up 1/3 of the way up and I prefer the look. At least you could try it and demo the speakers from that location for comparison after redoing Audyssey.
beezar is offline
post #54 of 58 Old 08-21-2012, 11:51 PM - Thread Starter
Hustler's Avatar
Yes, the couch has been moved forward a bit so the rear surrounds are actually behind the couch now.
Does anybody know about a recent reference disc that can be used to audition/tweak the speakers. I have the older one that Klipsch had at one point, wonder if there is a latest one out...!!!
Hustler is offline
post #55 of 58 Old 08-24-2012, 05:47 PM - Thread Starter
Hustler's Avatar
Anybody...?? Or is it that I am limited to certain parts of certain movies....!!
Hustler is offline
post #56 of 58 Old 08-24-2012, 05:57 PM
brandonnash's Avatar
Liked: 32
There is a thread called home theater demo tree over in the dedicated theater forum. You can download that and burn to blu ray if you have a burner.
brandonnash is offline
post #57 of 58 Old 08-24-2012, 06:30 PM
cel4145's Avatar
Liked: 2991
If this is your first Denon and use of Audyssey, one thing that could help to get your audio configured well is AVS member batpig's Denon and Audyssey guides.
Also, if you have not calibrated your TV, the Disney WOW disk is worth getting. The video calibration tools are excellent. It also has some short Disney video demo stuff, some of which your kids would like. Not sure that the audio calibration stuff will be all that useful since Audyssey MultiEQ XT will do most of the work for you.
cel4145 is offline
post #58 of 58 Old 09-11-2012, 03:51 PM - Thread Starter
Hustler's Avatar
Guys,
Thanks a bunch for your help. Got everything hooked up and it sounds GREAT. I am trying to tweak things so the klipsch sub has a tight-er punch. Other than that, I am happy with the speaker quality from HTD.
Hustler is offline
Reply Speakers
