Martin Logan Motion 10 vs Infinity Primus P363 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 08-03-2012, 11:08 AM - Thread Starter
untrueparadox's Avatar
Which one is better considering a 50% music and 50% home theater?
I'm planning a 5.1 setup for my small living room. It's maybe 12' x 18' and extends to an open kitchen.
The ML Motion 10 is $119 from Newegg right now and the P363 is $99 from Frys at the moment. Which one is a better choice?
I currently have two primus p150 bookshelves but one of the grills is broken so if I plan to keep that, I'll need to get a new one. Everything else will have to be bought. Thanks.
untrueparadox is offline
post #2 of 10 Old 08-03-2012, 11:09 AM
ack_bk's Avatar
Quoted: 601 Post(s)
Liked: 686
Can you listen to them both? I personally like the sound of the folded ribbon tweeter for music in the Motion 10, but the Primus is no slouch.. You really should try to listen to them if possible as they are different sounding speakers.
ack_bk is offline
post #3 of 10 Old 08-03-2012, 11:22 AM - Thread Starter
Yeah that's what I plan to do as well but I can't seem to find a retailer that sells the motion 10. Best Buy's lowest model is the 12 and the reviews seem to say that it is quite different.
post #4 of 10 Old 08-03-2012, 04:20 PM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 567
Amazon is selling the Motion 10 for $160 each right now. IMO it is very good for that price; hard to beat.
commsysman is offline
post #5 of 10 Old 08-03-2012, 04:52 PM
templemaners's Avatar
I'd get the P363's - $99/ea is a stupid good price.
templemaners is offline
post #6 of 10 Old 08-03-2012, 04:59 PM
afrogt's Avatar
Quoted: 1335 Post(s)
Liked: 923
I think you missed the part where he said Newegg is selling them for $119 each.
Actually $99 each with the promo code MALO83 thru Sunday.
http://www.newegg.com/Product/Product.aspx?Item=N82E16882981007
Afro GT
afrogt is offline
post #7 of 10 Old 08-04-2012, 06:04 AM
commsysman's Avatar
Liked: 567
I guess you missed the part where he said he couldn't find ANY retailer that was selling them....right before my message (post #3...). That is what I responded to.
I guess he meant a LOCAL retailer, so he could audition personally.
post #8 of 10 Old 08-04-2012, 09:31 AM - Thread Starter
Yeah I stopped by best buy and frys but both of them cleared out the motion 10 and 12's a while back. The primus was in an open demo so I couldn't get a real good feel for it with all the noise going on. I will probably pick up the p363's since the matching surrounds and center are way cheaper.
post #9 of 10 Old 08-04-2012, 09:33 AM
ack_bk's Avatar
Quoted: 601 Post(s)
Liked: 686
I think you will be happy with the Infinity's. For that price, you really cannot go wrong.
ack_bk is offline
post #10 of 10 Old 08-04-2012, 12:01 PM
pukemon's Avatar
Quoted: 283 Post(s)
Liked: 71
Anybody here think the infinity p363 is better than Polk audio monitor 60's or are they both pretty comparable?
butter and jelly please.
Home theater gladly not designed by ereed or bgtighe23. 65" JS9500, Marantz 7702MKII, Parasound Halo A31, ClassDaudio SDS470 4ch, RBH R56, 4xRBH R55, 2x RBH R5, Hsu VTF 2 MK 3 and VTF 3 for subwoofage, OnStage MS7701B mic stand with boom for improved Audussey XT32 calibrations. Listening space happily treated with 1" OC 703 rigid fiberglass. OPPO 203 or 205 soon.
pukemon is offline
Reply Speakers
