Best 7.0 speaker suggestions, $1500-$2000? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 08-04-2012, 07:08 AM - Thread Starter
gbould's Avatar
I need some suggestions for a 7.0 speaker system for a 12' wide, 16' long, and 9' ceiling HT space. I plan to use an HSU VTF-15H sub. My budget for the 7.0 speaker system is $1500-$2000.
60% movies
40% music (jazz, classical)
Thanks in advance for your recommendations.
My Media Room (Basement)
gbould is offline
post #2 of 15 Old 08-04-2012, 07:36 AM
commsysman's Avatar
Quoted: 974 Post(s)
Liked: 525
Here's a recommendation:
A pair of PSB Image T5 speakers, four Image B4 speakers, and an Image C5 center speaker.
Those will run you $799 + $540 + $320 at Saturday Audio Exchange.
commsysman is offline
post #3 of 15 Old 08-04-2012, 07:43 AM
smasher50's Avatar
Quoted: 355 Post(s)
Liked: 15762
how far away from tv or screen are you sitting
i'm so laid back,i'm laid out
smasher50 is online now
post #4 of 15 Old 08-04-2012, 08:39 AM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
Have you considered the Hsu 7.0 package for under $1200 delivered?
Unless you listen to lots of 2 channel music, floorstanding speakers are overkill if you get a 15H. The sub will handle all bass under 80hz and do a much better job than any speaker.
http://www.hsuresearch.com/products/speakerpkg.html
ack_bk is online now
post #5 of 15 Old 08-04-2012, 09:29 AM - Thread Starter
gbould's Avatar
Thank you for your recommendation. I'll take a look at PSB.
gbould is offline
post #6 of 15 Old 08-04-2012, 09:31 AM - Thread Starter
gbould's Avatar
I will be sitting 11'-12' from a 110" screen.
gbould is offline
post #7 of 15 Old 08-04-2012, 09:33 AM - Thread Starter
gbould's Avatar
I'll also take a look at the HSU speakers. Thanks!
gbould is offline
post #8 of 15 Old 08-04-2012, 10:11 AM
zieglj01's Avatar
Quoted: 942 Post(s)
Liked: 846
Look at the Definitive Tech - good prices
Studio Monitor 450 for fronts
http://www.newegg.com/Product/Product.aspx?Item=N82E16882325060
Studio Monitor 350 for surrounds
http://www.newegg.com/Product/Product.aspx?Item=N82E16882325059
C/L/R 2002 for center
http://www.vanns.com/shop/servlet/item/features/548499960/definitive-technology-c-l-r-2002-black?
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is online now
post #9 of 15 Old 08-04-2012, 12:51 PM
smasher50's Avatar
Quoted: 355 Post(s)
Liked: 15762
fwiw, since this system is to be used about even between music and home theater ;
ascend acoustics sierra-1 fronts
sierra-1 center
pair of cbm170 surround
pair of htm200 for back total $1912
or
pair of nht classic 3 for fronts
classic 3 center
pair of absolute zeros for surround
pair of super zeros for back total $1900
just a few suggestions to look at
post #10 of 15 Old 08-04-2012, 01:35 PM - Thread Starter
gbould's Avatar
Thanks for he deftech links. I'll take a look.
gbould is offline
post #11 of 15 Old 08-04-2012, 01:44 PM - Thread Starter
gbould's Avatar
Smasher,
Probably 50/50 to be fair. Not familiar with NHT or Ascend, but I'll look at them as well.
gbould is offline
post #12 of 15 Old 08-04-2012, 01:51 PM
smasher50's Avatar
Quoted: 355 Post(s)
Liked: 15762
ascend and nht are a few of the best ID companies out there with great sounding speakers imo
post #13 of 15 Old 08-04-2012, 06:17 PM - Thread Starter
gbould's Avatar
I have also been looking at Axiom and Aperion speakers. Any feedback on those brands?
gbould is offline
post #14 of 15 Old 08-14-2012, 10:27 PM
vilas's Avatar
Quoted: 17 Post(s)
What did you decide to go with?
vilas is offline
post #15 of 15 Old 08-16-2012, 09:22 AM - Thread Starter
gbould's Avatar
Still lurking looking. Also taking a good look at the EMP Tek tower system.
gbould is offline
Reply Speakers
