Need help with a Surround set up for a small bedroom - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-06-2012, 07:24 PM - Thread Starter
kaniada's Avatar
I'm been a long time lurker on these forums and found a wealth of information but I'm stuck and looking for advice on putting together a surround setup for my bedroom. The room is W12' x L13' so space is at a premium and not something that I have normally had to take into account when putting together a decent speaker setup. I really having difficulty picking something compact that will also not sound like wet tissue paper wrapped over a toilet paper tube.
I'm looking for recommendations on a full set of speakers and a receiver in the price range of $1500 - $3000. My primary uses would be watching movies and streamed netflix through my boxee box.
kaniada is offline
post #2 of 6 Old 08-06-2012, 09:27 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
5 channel? 7 channel? ? You have no idea at all of things you're considering yet? What kind of lurker are you? wink.gif
Since you're looking for subjective recommendations: I'd suggest looking at Ascend for speakers, good bang for the buck (ascendacoustics.com) Set of 170SEs across the front with some 200SEs for surrounds and maybe hook up with a Rythmik sub they can package for you would sound great. Maybe a HSU combo set of speakers/sub. AVR you'll do fine with in the $300-500 range (look at Onkyo, Pioneer, Denon, Yamaha among others) with a good feature set and sufficient power for pretty loud in the bedroom with reasonably efficient speakers.
lovinthehd is offline
post #3 of 6 Old 08-06-2012, 09:30 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Look at Focal 705V speakers, $100 off per pair - they are also cheaper than
their center channel speaker - they can also be wall mounted if needed.
Buy 3 pair and use one speaker as a center channel
http://www.dedicatedaudio.com/inc/sdetail/34397
Subs >
Epik sub
http://www.epiksubwoofers.com/legend.html
Energy sub
http://www.newegg.com/Product/Product.aspx?Item=N82E16882269026
HSU subwoofer
http://hsuresearch.com/products/vtf-2mk4.html
http://hsuresearch.com/products/vtf-1mk2.html
Go to AC4L and look at Denon and Marantz receivers
http://www.accessories4less.com/make-a-store/brand/denon/results/1.html
http://www.accessories4less.com/make-a-store/brand/marantz/results/1.html
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #4 of 6 Old 08-07-2012, 12:14 PM - Thread Starter
kaniada's Avatar
I am mainly looking for a 5.1 setup and I didn't post anything I had been considering because I was hoping for some unbiased answers. I was initially looking at an energy 5.1 setup but decided against it after I started to read up on ascend and hsu speakers.
After doing some looking around today with the recommendations in this thread, I'm leaning towards:
Hybrid 2 - 5.1 Package in Satin Black
http://www.hsuresearch.com/products/hybrid2pkg.html
Marantz SR5006 AV Receiver
http://www.accessories4less.com/make-a-store/item/MARSR5006/Marantz-SR5006-AV-Receiver-with-Networking-and-AirPlay/1.html
or
Yamaha-RX-V671
http://www.amazon.com/Yamaha-RX-V671-7-1-Channel-Network-Receiver/dp/B004QR56SE/ref=wl_it_dp_o_pdT1_nS_nC?ie=UTF8&colid=20VQU71L5PAHI&coliid=I1VGCME2SXGB55
The Marantz receiver seems like a great deal but I am somewhat leery of buying a refurbished receiver.
kaniada is offline
post #5 of 6 Old 08-07-2012, 01:32 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
It is up to you on speaker choice and receiver. I have bought Denon and Marantz refurbish receivers
with no problems. Good Luck.
Who AM I
zieglj01 is offline
post #6 of 6 Old 10-02-2012, 06:40 AM - Thread Starter
kaniada's Avatar
I just wanted to reply back and mention how pleased I am with the Hsu speakers and the Marantz receiver. The sound is perfect for the smaller room and I am frankly a little shocked at just how nice the speakers are for their price. The speakers have a very balanced sound and do not have harsh horns at higher volumes that I have experienced with Klipsch speakers.
Even more impressive is the level of customer service that comes along with the speakers. When I ordered my speakers in the comment box of my order I requested advice for the best placement of my new speakers. Low and behold the next day Dr. Hsu himself called me and asked for a drawing of the room I planned to use them in. In a few hours he sent me his recommendations as well as bracket recommendations. It is so rare to have such a personal level of customer service these days.
Thanks again for your recommendations.
kaniada is offline
Reply Speakers
