Need suggestion for dorm-room speakers please! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 26 Old 08-08-2012, 10:05 AM - Thread Starter
Bland's Avatar
Hey all, this is my first post here and I don't mean to be a leecher but I am completely overwhelmed by the possible selections of speakers so I'm looking for a bit more personalized advice. My roomate and I are looking to split the price on a quality audio setup so we need some help. The setup will mainly be used through my computer where we'll be doing anything from playing music, to streaming tv, to gaming. I already have a WA3 Desktop Amplifier which has been amazing thus far so the setup can go directly through there if possible.
Anyway we'd love some suggestions on a $200-$400 setup knowing that our room is small, we have an amp, and we will mostly be playing music / streaming T.V. through them. If you need any other info please ask. Thanks!
Edit: Also he lives right next to a Sony outlet so if Sony offers any quality speakers that may be first choice. Otherwise I'm happy to purchase online or whatever.
Bland is offline
post #2 of 26 Old 08-08-2012, 10:54 AM
Elihawk's Avatar
Quoted: 1326 Post(s)
Liked: 1160
I assume that Amp will not support a subwoofer?
And I assume that maybe smaller desktop speakers would be prefered?
If you have the room for tower speakers, you can often get a pair of Infinity Primus or Polk M70s for under 400 dollars. However, having lived in a dorm room in the past, I know that Space is a premium. One bookshelf speaker that I can personally comment on is the Def Tech SM 450 and it can be had for 329.00/pr right now from New Egg.com. Excellent bass for a budget desktop speaker and it looks very good.
http://www.newegg.com/Product/Product.aspx?Item=N82E16882325060
Set up #1: EMP e5Ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, SVS NSD SB12 sub, Marantz Slimeline 1504 AV receiver
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and EMPtek10i10i sub, Denon 1910 AV receiver
Set up #3: Philharmonics- BMR in a 2.0 system, music only, Yamaha RXV-363 AV receiver
Elihawk is offline
post #3 of 26 Old 08-08-2012, 10:55 AM
Elihawk's Avatar
Liked: 1160
PS don't know much about Sony speakers, but they don't get a lot of good reviews from the AVS forum members....
Elihawk is offline
post #4 of 26 Old 08-08-2012, 11:24 AM
zieglj01's Avatar
Quoted: 1555 Post(s)
Liked: 1402
I would skip the Sony speakers - the Definitive SM450 is a good option.
__________________________________________
Who AM I
Speakers -- Snell K7 > Q Acoustics 3020 > Boston VS240
Receiver -- Integra 50.2
zieglj01 is online now
post #5 of 26 Old 08-08-2012, 11:55 AM
Elihawk's Avatar
Liked: 1160
Another option...not sure Cerwin Vega is known for great quality, but they have a reps of getting loud!
http://shopcerwinvega.com/detail/CER+CMX-5/CMX-5
Elihawk is offline
post #6 of 26 Old 08-08-2012, 02:23 PM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 567
Well, Sony makes a lot of really poor cheap speakers, and they also make a pair of speakers that sell for $13,000.
Unfortunately, they don't make much in between.
For a dorm room, your best bet in my opinion is to get a set of good bookshelf / monitor speakers that will have decent bass and nice overall sound quality.
My first choice would be the Boston Acoustics Classic CS26 speakers, which go down to 52 Hz, and are $150 each right now at Amazon and other dealers.
The Polk Monitor 40 speakers are another possibility. They are a lot cheaper, and have good bass, but are not as good-sounding overall.
commsysman is offline
post #7 of 26 Old 08-08-2012, 02:27 PM - Thread Starter
Bland's Avatar
I think the Def Tech 450's look awesome and are pretty much exactly what I'm looking for. What sort of wires am I going to need with them and will they be able to work with my 6.3mm desktop amp? Also is there any hope of me being able to transport them to parties or should I just forget that idea entirely?
Thanks all for the suggestions and help. Much appreciated.
Bland is offline
post #8 of 26 Old 08-08-2012, 02:35 PM
commsysman's Avatar
Liked: 567
The WA3 headphone amplifier is the only amplifier you have mentioned so far. That is not designed for driving speakers and will not do so.
If you think it will drive speakers you are very confused.
You will need to get a receiver or integrated amplifier with at least 30 watts per channel of output power to drive your speakers (for example the Denon 1312 receiver or Sony STR DH-100)
The other possibility is to buy some powered speakers, with amplifiers built-in to the speaker enclosure (for example the Audioengine 2 speakers).
post #9 of 26 Old 08-08-2012, 02:40 PM - Thread Starter
Bland's Avatar
You will need to get a receiver or integrated amplifier with at least 30 watts per channel of output power to drive your speakers.
Yeah I believe I understand now. They are only designed for headphones and do not have the required input etc.
Do you think these speakers will suffice without an amp? Or should I buy a cheaper pair with a decent amp or what?
Edit: I'm guessing from what you said they are going to require an amp.
Bland is offline
post #10 of 26 Old 08-08-2012, 02:44 PM
commsysman's Avatar
Liked: 567
Amazon has the Sony STR-DH-100 for about $130 right now; that would be a good place to start. It has 100 watt amplifiers, which is way more than you will need.
Buy a set of Polk Monitor 40 speakers for $165, and you should be in pretty good shape.
Speakers, without amplifiers to drive them, are as useful as a car with no engine.
post #11 of 26 Old 08-08-2012, 02:57 PM - Thread Starter
Bland's Avatar
Gotcha.
You think I should go with the Polk Monitor 40's over the Def Tech 450's? I don't mind spending a bit more money if it's going to be worth it in the long run. They are also a bit more compact for my dormroom which is cool.
If you think the Polk's are a much better entry level speaker though definitely speak up.
Bland is offline
post #12 of 26 Old 08-08-2012, 03:05 PM
zieglj01's Avatar
Liked: 1402
You can get a nice Sherwood receiver here - good price
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=252-125
I would hands down, choose the Definitive SM 450 over the Polk speakers.
Who AM I
post #13 of 26 Old 08-08-2012, 03:12 PM
jevans64's Avatar
Quoted: 194 Post(s)
Liked: 149
Gotcha.
I think you will be OK with the Polk even though I think the DefTech 450's will sound better. The DefTech have a 6.5" active driver and a 10" passive radiator which will produce more low end and a fuller sound. I have the SM55 which is the SM450 replacement and these are kick-ass computer speakers. The only thing that really changed between the SM450 and SM55 is the sleeker design of the SM55. I'm currently using, or should I say UNDER-USING, my SM55's for front height speakers in my DefTech home theater setup. The SM450's are being closed out, so good deals can be found on these.
Denon AVR X7200WA, Emotiva XPR-5, Emotiva XPA-7, Sony XBR 75" 850C, Oppo UDP-203, Roku Ultra.
DefTech BP7000SC (L/R), CLR3000 (C), SM55 (FH), UIW BPZ/A (SB), UIW 75 (TM).
JBL L7 (Sur), EoSone RSR 350 (RH).
PC 2.1 setup. Emotiva Stealth 6, SVS SB16-Ultra sub, Emotiva DC-1 DAC.
jevans64 is offline
post #14 of 26 Old 08-08-2012, 06:45 PM
Mitchellin's Avatar
I noticed an idea above for Audioengine 2...great idea for a small space! If all source signals will be coming from your PC, I say skip the notion of buying a receiver and buy 2 pairs. Check out their website...cool stuff for small spaces.
Mitchellin is offline
post #15 of 26 Old 08-08-2012, 07:01 PM
Elihawk's Avatar
Liked: 1160
Sorry...didn't realize that was a headphone amp! I own the dt sm450s and the polk m40s! The dt sm450 wins that race hands down. However, since you have no amp capable if powering the speakers, the audioengine 2 are the way to go, IMHO!
Elihawk is offline
post #16 of 26 Old 08-09-2012, 02:11 AM - Thread Starter
Bland's Avatar
Hmm I'm a bit torn here. It's tempting to drop the money on the dtsm450's + receiver/amp but at the same time I definitely don't think I'm going to end up getting the full use out of them. I think the audioengine 2's will suffice for the most part. I know they are basically meant for my computer but if I need to will I be able to plug them into my TV? Also is that an ipod input I see for them in case I want to go directly via ipod? That would be great for parties for sure.
Bland is offline
post #17 of 26 Old 08-09-2012, 03:34 AM
pukemon's Avatar
Quoted: 289 Post(s)
Liked: 73
Corsair sp2500?
butter and jelly please.
Home theater gladly not designed by ereed or bgtighe23. 65" JS9500, Marantz 7702MKII, Parasound Halo A31, ClassDaudio SDS470 4ch, RBH R56, 4xRBH R55, 2x RBH R5, Hsu VTF 2 MK 3 and VTF 3 for subwoofage, OnStage MS7701B mic stand with boom for improved Audussey XT32 calibrations. Listening space happily treated with 1" OC 703 rigid fiberglass. OPPO 203 or 205 soon.
pukemon is offline
post #18 of 26 Old 08-09-2012, 03:39 AM
smasher50's Avatar
Quoted: 376 Post(s)
Liked: 18513
fwiw, pair of energy rc-10's - vanns $220 ---great sounding speakers
topping tp-30 tripath amp -parts express $109 ---sounds great, way more than enough power for dorm,compact for space, easy access for computer,will not get hot even if left on for 24 hrs., and built like a tank
i'm so laid back,i'm laid out
smasher50 is online now
post #19 of 26 Old 08-09-2012, 05:37 AM
Elihawk's Avatar
Liked: 1160
The DT SM350 would be more than adequate for a smallish dorm room...so if you get a receiver/amp, whichever DTSM model is on sale would work fine.
Yes, the audioengines, the sound connects from a ipod/headphone jack. You may need an adapter for your TV set, however.
Elihawk is offline
post #20 of 26 Old 08-09-2012, 09:44 AM
cel4145's Avatar
Quoted: 2662 Post(s)
Liked: 3001
That's also the nice thing about powered monitors. Very portable if you want to setup them up in another room for a party or something.
In addition to the Audioengine 2s, if you have a Guitar Center nearby, go and listen to their powered studio monitors. You might find something you like. For example, I think the KRK Rokits would be good dorm room speakers.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #21 of 26 Old 08-14-2012, 09:04 AM - Thread Starter
Bland's Avatar
Went with the Audioengine 2's, just fyi. Realized I never updated my purchase.
Bland is offline
post #22 of 26 Old 08-21-2012, 07:17 PM - Thread Starter
Bland's Avatar
So the Audioengine 2's arrived and while they sounded quite good they didn't produce the volume I need for hosting some parties.
I ordered the Definitive Technologies SM 450 set from Newegg for $330 shipped (I just realized on the back of the speakers Def Tech is literally 20 mins from my house... gonna call tomorrow and ask if they could cop me a good deal), and I also ordered the Sherwood receiver here: http://www.parts-express.com/pe/showdetl.cfm?Partnumber=252-125 as recommended in the previous post.
Would someone mind giving me advice on what wires I need to set these up? I've never had a legit pair of speakers before. Thanks.
Bland is offline
post #23 of 26 Old 08-21-2012, 07:30 PM
zieglj01's Avatar
Liked: 1402
For a small area, regular 16 awg speaker wire is fine - I tend to use 14 awg, it does not cost much.
Monoprice is one place to get it.
http://www.monoprice.com/products/search.asp?keyword=SPEAKER+WIRE
Or, go to Home Depot, Lowe's, Walmart or RadioShack.
Who AM I
post #24 of 26 Old 08-21-2012, 07:37 PM - Thread Starter
Bland's Avatar
Thanks. That's really all I'll need? Guess I'll just head to Walmart in that case so I don't have to wait for shipping.
Bland is offline
post #25 of 26 Old 08-21-2012, 07:55 PM
zieglj01's Avatar
Liked: 1402
For receiver and speaker hook-up, all you need is speaker wire.
Do you already have your cable, that you have been using from your computer set-up?
The Sherwood takes RCA input cable from sources, and has a headphone jack.
Who AM I
post #26 of 26 Old 08-21-2012, 07:56 PM - Thread Starter
Bland's Avatar
Awesome. Well no as I passed them to a friend so I'll need to pick up a speaker cable but I believe I have a few RCA cables from my headphones.
Bland is offline
Reply Speakers
