polk audio RT55 wire question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-09-2012, 04:46 PM - Thread Starter
splatee's Avatar
Quoted: 30 Post(s)
Ok, i just changed my current setup of Insignia bs-2111 to polk audio rt55 fronts and back. I am a bit confused on how to wire these biggrin.gif
I went the polk audio website and found the user manual but it is a bit vague. It explains how to bi-wire and bi-amping. All i want to do is connect regular but the terminals have metal jumpers connecting the top post to the bottom but they are only tightened on the bottom set. Now shouldn't these be tightened top and bottom?
Right now the top terminals are not tightened down. The jumper is just sitting loose.
Thank you
splatee is offline
post #2 of 2 Old 08-09-2012, 05:16 PM - Thread Starter
splatee's Avatar
Quoted: 30 Post(s)
Ok, i figured it out....they are both tightened down. I forgot that when they were unhooked from the previouse owners system they had to loosen up the nut rolleyes.gif and i am using bannana plugs. LOL.
splatee is offline
Reply Speakers
