Two 10" paradigm subs? OR one 12" paradigm sub - AVS Forum | Home Theater Discussions And Reviews
Old 08-09-2012, 11:46 PM - Thread Starter
nismosis's Avatar
I noticed my 1326k pioneer has two sub outputs. So my question is simple, based on budget for either, or, which would be better? Two 10's or one 12? Both being paradigm monitor series subs.
They will be paired with a center 3, monitor 11's, and mini-monitors. Thanks!
nismosis is offline
Old 08-09-2012, 11:55 PM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
You can do a lot better than Paradigm subs for your money. Two is usually better than one but 10" subs aren't going to dig very deep or with authority. At the least, I would do dual 12" ers from the likes of HSU, Rhythmik, Epic, SVS or Outlaw.
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
Old 08-10-2012, 01:49 AM - Thread Starter
nismosis's Avatar
Am I just naive in thinking that paradigm would "match" their subs to their speakers? I'm sure you can get better speakers for the money as well; however, I think they sound great and just thought aesthetically the matching sub would be best. I have heard they do pump pretty well also. I wouldn't be dissatisfied would I? I'm not with the towers and other speakers...
nismosis is offline
Old 08-10-2012, 02:02 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
Subs don't have to match. That is primarily a center channel thing. If you really like the subs and they perform to your satisfaction then I would get them. However, if you have the opportunity, I would listen to some others to give you an ideaof how they stack up against the competition. But by all means avoid Polk subs except for the PSW505. All the rest are really bad.
Old 08-10-2012, 04:35 AM - Thread Starter
nismosis's Avatar
Good to know!
nismosis is offline
Old 08-10-2012, 06:10 AM
dowop's Avatar
Quoted: 42 Post(s)
I am running two of the new sub 10`s. They do sound pretty good but for the money I spent I am sure I could of done a lot better.
dowop is offline
Old 08-10-2012, 06:21 AM
BeeMan458's Avatar
Liked: 813
Beware, subs are a sonic drug. Two 10" subs equal one 12" sub. But one 12" sub equals unbalanced sound. Now you need two 12" subs to have balanced sound. And then you come to realize that two 12" subs equal one 15" sub and one 15" sub equals unbalanced sound. So, if you can, build to a minimum pair of 15" subs and consider yourself a bass addict. And don't even think of slowing down enough to let the THX bug bite you in the behind as now you're into separate pre/pros and amplifiers.
(Oh crap, there's another three grand I don't need. I should have bought a bass boat.)
(Currently addicted to two 12" subs, looking to upgrade to a pair of 15" subs.)
Right now, the upgrade choices before me are, 15" Rythmik, Epik or Hsu with the edge going to Rythmik SE 15" but loving the Rosenut veneer of the Hsu's.
BeeMan458 is offline
Old 08-10-2012, 06:46 AM
Bill Fitzmaurice's Avatar
Liked: 4629
Originally Posted by nismosis View Post
which would be better? Two 10's or one 12? !
Assuming the tens go as low as the twelve two tens are better, as it allows placing them in different spots to smooth out room modes.
Bill Fitzmaurice is offline
Old 08-10-2012, 07:04 AM
BeeMan458's Avatar
Liked: 813
Originally Posted by Bill Fitzmaurice View Post
...as it allows placing them in different spots to smooth out room modes.
Dang those bass loading corners.
Old 08-10-2012, 07:09 AM
Liked: 4629
Corner loading is your friend. It's walls that cause problems.
Old 08-10-2012, 07:10 AM
BeeMan458's Avatar
Liked: 813
You're right. I was thinking of ceiling corners as opposed to wall corners. Sorry for the misspeak.
Old 08-10-2012, 07:11 AM
dowop's Avatar
Quoted: 42 Post(s)
The Bass is a lot smoother with two subs. I have mine sitting on subdudes also & they sound good like I said. I went with Paradigm because those are the rest of my speakers. I knew the subs did not have to match. But I could have gotten two different brand subs for quite a bit less $$.
dowop is offline
Old 08-10-2012, 10:30 AM
Liked: 4629
They don't cause problems in the frequencies where most subs operate either. Mid-bass (100 to 180Hz, give or take), yes. For that reason what are commonly labeled as bass traps more properly should be called mid-bass traps.
Old 08-10-2012, 12:15 PM
BeeMan458's Avatar
Liked: 813
Not arguing, my old school vs new school learning teaches me of bass traps and ceiling corners being the general trouble makers. With today's bass management, anything from 120Hz and down is considered a complainant. confused.gif
(And I should add, flat ceiling corners as opposed to diagonal cathedral ceiling corners where angular deflection occurs.)
One must see sound waves in the likes of liquid and pebbles dropping on the mirrored surface of a lake.
Old 08-10-2012, 12:56 PM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
One must see sound waves in the likes of liquid and pebbles dropping in the mirrored surface of a lake.
You might want to take a peek at this before picking a fight with Bill.
http://billfitzmaurice.com/
Subwoofers , Paradigm , Pioneer , Center Channel Speakers , Polk Audio Psw505 12 Inch Powered Subwoofer Single Black
