Keep the ELT's or go with in walls? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 08-12-2012, 02:59 PM - Thread Starter
dago52's Avatar
Quoted: 111 Post(s)
Liked: 68
We just moved into our new home and I plan on wall mounting our 55" Vizio on the wall. I have a set of Onix ELT's and I love them but I would like a clean look. I could mount the left and right on the wall almost out of view but the center would have to go under the TV. It's a big wall with just the TV and pictures and all the components will be located in a closet. I just don't want to sacrifice any sound and plus I already have the ELT'S, but I would strongly consider it if it will sound as good.
Denon X4200W
Chane's A5rx-c's Towers
Chane A2rx-c Center
Chane A1.4 Front Heights
EMP Bipoles Surrounds
Epson 2045 with 125" Elite Screen
dago52 is offline
post #2 of 7 Old 08-12-2012, 07:46 PM
ack_bk's Avatar
Quoted: 614 Post(s)
Liked: 697
I would try wall mounting them first and see how you like them. That said, these speaker are rear ported, so having them right against the wall is not going to be ideal and could result in muddy sound. But again, try it and see what you think.
If you go the in wall route, what budget are we talking about and do you have a subwoofer?
ack_bk is offline
post #3 of 7 Old 08-12-2012, 07:53 PM - Thread Starter
dago52's Avatar
Quoted: 111 Post(s)
Liked: 68
Well I have some Omni mounts that keep them off the wall and they would be mounted up high in the corners facing down. As far as a sub, I have 2 incredible DIY subs that shake the house. If I decided to go with the in walls, my budget would be around 1,000 for the set of 5. After thinking more about it, I think I will mount these speakers and see how it goes, if it works then I saved a grand. I will post some pics hopefully next week. I'm wiring everything next weekend and hopefully will have the media closet all together.
Thanks for your help.
Denon X4200W
Chane A2rx-c Center
dago52 is offline
post #4 of 7 Old 08-12-2012, 08:09 PM
ack_bk's Avatar
Quoted: 614 Post(s)
Liked: 697
It is not ideal to mount your left and right main speakers high on the wall, especially in the corner. Give it a try, I think that makes sense, but an in wall speaker would definitely give you a cleaner look and more optimal placement (and I am guessing better sound). For $1K you could get three matching in wall speakers for your mains and use the Onix speakers for surrounds.
ack_bk is offline
post #5 of 7 Old 08-22-2012, 08:43 AM - Thread Starter
dago52's Avatar
Quoted: 111 Post(s)
Liked: 68
Ok, just an update. I mounted the 2 fronts and surrounds this weekend. I still have some tweaking to do but they sound great. I purchased some sans speaker brackets and the speakers are approximately 8" from the wall. I was also able to get all the components cemtralized and the hardware for the roomie remote. I'm loving the fact that I can't see any wires. I will try to post some pics.
Thanks for the input
Denon X4200W
Chane A2rx-c Center
dago52 is offline
post #6 of 7 Old 08-22-2012, 10:09 AM - Thread Starter
dago52's Avatar
Quoted: 111 Post(s)
Liked: 68
Denon X4200W
Chane A2rx-c Center
dago52 is offline
post #7 of 7 Old 08-22-2012, 10:10 AM - Thread Starter
dago52's Avatar
Quoted: 111 Post(s)
Liked: 68
The last picture is a DIY sub and it shakes the house. I even built a second one but have no room for it.
Denon X4200W
Chane A2rx-c Center
dago52 is offline
Reply Speakers
