Sound improvment with a passive inwall subwoofer - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-14-2012, 12:09 PM - Thread Starter
InWall guy's Avatar
I am in the process of building a new house and am at the wiring point. I have very limited experience with in-ceiling speakers. More often than not they sound flat and lack bass. For stereo set-ups in two rooms I am considering adding passive in wall subwoofers and found great deals on:
Sonance 8 inch in wall single subwoofers. I don't want to add an additional sub woofer amp for stereo-set-ups and these rooms.
Here are my questions..
With a 6 1/2 inch woofer in the ceiling speaker will adding the sub give me much better bass response?
Do I have to buy a back enclosure or could I just add two extra 2x4s to create an enclosure in the wall?
Is it worth the extra cost? I know this last question is a very subjective.
Here are the specs on the sub:
Specifications
Woofer
8" (203mm) long throw carbon fiber cone, dual voice coil, with a rubber surround
Frequency Response
35Hz - 250Hz
Power Handling
150 watts
Sensitivity
90dB (2.83V/1meter)
Crossover Frequency
150 Hz
Optional Enclosures
Optional wooden acoustic enclosures optimize bass performance and reduces sound spillover to adjacent rooms.
Dimensions (WxHxD)
9 7/8" x 15 15/16" x 3 7/8" (251mm x 405mm x 99mm)
Cut-Out Dimensions (WxH)
8 1/2" x 14 1/2" (216mm x 368mm)
Shipping Weight
13 lbs (5.8kg) each
InWall guy is offline
post #2 of 6 Old 08-14-2012, 03:47 PM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
That's a fairly specialized subwoofer question. You might get more help in the AVS subwoofer forum.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #3 of 6 Old 08-14-2012, 09:02 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
How large is your room. The challenge I see is with in-wall subwoofers is you have to nail the placement. With an in-room subwoofer, you have placement flexibility and the ability to move the sub.
There are seem attractive smaller in-room subs out there, would you at least consider that option.
ack_bk is offline
post #4 of 6 Old 08-14-2012, 09:16 PM
Audiophile2k's Avatar
Liked: 46
If you are just trying to avoid having the speakers in room, you could use an in floor IB design. I have never heard a success story with in wall subs. It seems it is almost impossible to execute well, especially with smaller drivers.
Audiophile2k is offline
post #5 of 6 Old 08-15-2012, 09:30 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
It can be done successfully. Just don't expect it to be cheap.
http://bgradia.com/subwoofer-speakers.html
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
post #6 of 6 Old 08-15-2012, 07:52 PM
Hookedonc4's Avatar
Quoted: 26 Post(s)
^ Yes, my James loudspeaker Baby Grand Concerto's have 10" sub built in and they are awesome...
Inwalls
Bi-Amp Full Range In-Wall
Bi-amp 3-Way
(1) 10" Slimline Subwoofer
(2) 8" Woofers
(1)Soft Dome Tweeter.
Patented AFDC Network, Sealed Aircraft Aluminum Enclosure.
Denon X4000, SC-91, VSX-51,VSX-81 Pioneer Elites and Denon 1611
James loudspeaker inwalls main and future theater
Control4
Other speaker zones DefTech, Polk, Russound, Boston Acoustics
Hookedonc4 is offline
Reply Speakers
