Energy 5.1 take Classic Vs Energy CF-30 , CB-5 , Energy Power 10 Sub , CC-5 - AVS Forum | Home Theater Discussions And Reviews
Old 08-17-2012, 10:34 AM - Thread Starter
pandwadi's Avatar
I am looking to buy new home theater system with budget of $1000-1300 total for speakers and receiver. I don't have much experience with HT other than i had Bose 3.2.1 4-5 years back. So need help from experts.
I am thinking about Receiver Yamaha RX-V473 5.1-Channel Network AV Receiver $400.
How do i select speaker system? I have following options and i am not able to select
1) Energy 5.1 take Classic : $400 , easy and most popular
2)Pre Built Energy CF-30 , CB-5 , Energy Power 10 Sub , CC-5
like this one sold on amazon
http://www.amazon.com/Yamaha-5-1-Channel-Floorstanding-Bookshelf-Subwoofer/dp/B008RYTSYU/ref=sr_1_11?s=electronics&ie=UTF8&qid=1345219632&sr=1-11&keywords=Yamaha+RX-V473+speaker
3)Custom build example.
Energy CF-30 Pair
CB-5 Pair
Energy Power 100 Sub ,
CC-10
Please help me decide this system. I will use system to listen to music more than watch movies so clarity of the sound is very important to me.
pandwadi is offline
Old 08-17-2012, 12:05 PM
cel4145's Avatar
Quoted: 2657 Post(s)
Liked: 2987
The Energy Take Classics are nice for small satellite speakers, but full range speakers are a better choice if you don't need the small size of the Takes.
Based on the frequency response of the Energy Power 100 Sub is 45Hz-150Hz+/-3dB, it would be a poor sub for music and/or HT; it's low end frequency response is no better than the CF30s. The BIC F12 or Energy S10.3 are much better choices.
Here's what I would do:
A pair of Energy V6.2 and Energy V5.2C for your front L/R/C. Then use RC-10s for the rears. A Denon 1612 for the receiver. Then wait on the sub for six months or a year if you can't afford it now, especially given that music is your priority (the sub is not needed as much). This setup would be in a whole different league from the CF30s, CC10, and CB-5s and the V6.2s will be incredible for music.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
Old 08-17-2012, 12:23 PM
Otto Pylot's Avatar
Quoted: 1361 Post(s)
Liked: 853
^^^^^ would the Takes (5.1) still be a good choice if one needs to stick to the small form factor and speaker weight? The stands that I already have would support the weight of the Takes but anything bigger (heavier) would probably require a new set of stands (which isn't in the budget right now). The sub I have now is an 8", 28Hz-200Hz and seems to work well in our environment.
Otto Pylot is offline
Old 08-17-2012, 12:56 PM
cel4145's Avatar
Liked: 2987
It's not worth it to get the Takes over full range speakers just because you already have stands. There will be that big of a difference in sound quality.
cel4145 is offline
Old 08-17-2012, 01:27 PM - Thread Starter
pandwadi's Avatar
Thanks a lot. Let me review it.
pandwadi is offline
Old 08-17-2012, 01:58 PM
Otto Pylot's Avatar
Liked: 853
Let me rephrase. I need to stick to the bookshelf-sized speakers (all the way around). I realize that the audio quality is light years apart between the two but are the Takes a good choice if one needs to stick to the bookshelf size?
Old 08-17-2012, 02:02 PM
cel4145's Avatar
Liked: 2987
For bookshelf size, better to go with full range ones that have at least 5" drivers. The Takes don't have any mid-bass at all because of the tiny drivers. You'll get a richer fuller sound with bigger speakers.
cel4145 is offline
Old 08-17-2012, 02:20 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
I would find a way to work with something like the Cambridge S30 - and yes, they do
have bass. And they will mate well, with the Energy S10.3 sub
http://www.amazon.com/Cambridge-Audio-S30-Bookshelf-Speakers/dp/B00198LYMU
http://www.crutchfield.com/p_779S30DO/Cambridge-Audio-S30-Dark-Oak.html
http://cdn.avsforum.com/1/1c/1ceb88f9_525x525px-LL-9de8411c_vbattach248087.jpeg
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
Old 08-18-2012, 09:42 AM - Thread Starter
pandwadi's Avatar
Looked at Energy V6.2 and Energy V5.2C and both look very bulky for apartment.
I am thinking about combination of
Energy Take Classic 5.0
http://www.crutchfield.com/p_732TAKE50/Energy-Take-Classic-5-0.html?tp=184&kw=&org=pla&nw=g&crv=14052697225#customer-reviews-tab
Bic F12 - 200
http://www.amazon.com/BIC-America-F12-475-Watt-Subwoofer/dp/B0015A8Y5M
I see Bic F12 has very good reviews.
pandwadi is offline
Old 08-18-2012, 09:47 AM - Thread Starter
pandwadi's Avatar
Also how is the feedback on
Fluance AVHTB+ Surround Sound Home Theater 5 Speaker System
http://www.amazon.com/Fluance-AVHTB-Surround-Theater-Speaker/dp/B00064JWSG/ref=pd_cp_e_3
with
Bic F12 - 200
Is this better combination than Energy 5.0 take classic and Bic F12?
pandwadi is offline
