Bowers and Wilkins CM5 vs Polk LSiM703 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 08-18-2012, 05:08 PM - Thread Starter
index2020's Avatar
Looking for any advice that will help me break the tie between Bowers and Wilkins CM5 vs Polk LSiM703. Listened to both and love both. They cost about the same. Am torn... any advice?
index2020 is offline
post #2 of 13 Old 08-18-2012, 06:42 PM
AcuDefTechGuy's Avatar
Quoted: 175 Post(s)
Liked: 262
All things being equal, B&W commands a lot more respect and pride of ownership. It helps when your big brothers include the $60,000 Nautilus, $25,000 800D2, and $15,000 802D2. Resale value for B&W is probably among the best.
AcuDefTechGuy is offline
post #3 of 13 Old 08-18-2012, 06:50 PM
enricoclaudio's Avatar
Quoted: 1512 Post(s)
Liked: 1666
Trust in your ears and get the one that sounds better for you.
Enrico Castagnetti @ Rythmik Audio
Media Room: Ascend Acoustics Sierra Towers w/ RAAL, Horizon w/ RAAL, Sierra 2s & Lunas | Rythmik F12SE (x2) | Emotiva XMC-1 | Emotiva XPA-3 & XPA-200 | Oppo 105D | Bluesound Node 2 | Sony HW40ES |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac|
Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz NR1606 | Emotiva XPA-200 Gen 2 | Samsung UN50JU6500 |
enricoclaudio is offline
post #4 of 13 Old 08-18-2012, 07:21 PM
Quoted: 175 Post(s)
Liked: 262
Of course, get the one that sounds better. But what if they are exactly the same on SQ. Then what would you get?
post #5 of 13 Old 08-18-2012, 08:12 PM
index2020X's Avatar
index2020? the reason i had to add X?
index2020X is offline
post #6 of 13 Old 08-18-2012, 08:56 PM
Quoted: 175 Post(s)
Liked: 262
post #7 of 13 Old 08-19-2012, 09:21 AM
jm86wvu's Avatar
I'd bet my hat (which I'm really quite fond of) that those speakers will not sound exactly the same. If I'm wrong then you could consider aesthetics, build quality, warranty, applicable deals on price, and resale value. Best bet is to get your hands on both and sit back and enjoy. Forking out the extra dough for return shipping will be worth it if you know you got the best choice.
jm86wvu is offline
post #8 of 13 Old 08-19-2012, 09:32 AM
Quoted: 175 Post(s)
Liked: 262
The OP says he loves them both.
He loves them both equally. Thus he is torn.
So that means he loves both their sound quality equally.
I did not say the speakers sound exactly the same.
2 speakers that sound differently can have equal sound quality since it is pure personal preference.
post #9 of 13 Old 08-19-2012, 06:09 PM
jm86wvu's Avatar
Whoops! Sorry OP (and AcuDefGuy). I'll admit I didn't give your post(s) my full attention before responding. Didn't see the "listened to both and love both" part. I maintain that warranty and appearance should help you in your decision. I'm not familiar with the warranties on either but the B&Ws would get my vote on aesthetics. Which finish were you looking at on each?
jm86wvu is offline
post #10 of 13 Old 08-20-2012, 08:42 AM
index2020X's Avatar
perhaps could decide based on best deal for each?
post #11 of 13 Old 08-20-2012, 08:57 AM
WagBoss's Avatar
Just wondering, what price were you quoted for them?
WagBoss is offline
post #12 of 13 Old 11-21-2012, 03:19 PM
scottwayne's Avatar
I just got back from Soundscape in Baltimore and compared the CM5 and the LSiM703. I thought they both sounded incredible but I gave the nudge to the Polk because of the deeper bass. No sub necessary with the Polks. Also they were 10% off ($1350).
scottwayne is offline
post #13 of 13 Old 11-22-2012, 07:48 AM
unbridled_id's Avatar
Nice to see Polk update the Lsi line. I owned the lsi 9's and like them quite a bit, and the 703 looks to be a nice speaker.
unbridled_id is offline
Reply Speakers
