On-wall speaker suggestions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 08-19-2012, 03:03 PM - Thread Starter
iAusio80's Avatar
Hey Guys,
Looking for some on-wall speaker suggestions. Some bookshelves with wall mount options are also good. These go next to my 60inch Samsung flat panel.
Budget for Left, Right, Center = ~$1200ish
I currently have Energy takes which are great and surprisingly somewhat fill the living room (1000 odd sq feet). As you can tell, I am not a critical listener
I am planning to use this set-up for 60% HT and 40% streamed music. This along with some Sonos or Audioengine speakers should help with my Sonos set-up as well.
I may end-up with Sonos speakers for kitchen etc as I'd have to run wires for Audioengine. Anyways, that's altogether a different headache.
Options I am considering:
[1] B&W 685s for L,CR,R - Requesting wall mount options
[2] Kef Q300 + Kef Q600 - Requesting wall mount options
[3] Definitive XTRs - Haven't heard them, but read good reviews
[4] Totem Tribes - Haven't heard them, but read good reviews
I am guessing any of these would be better than in-walls?
Appreciate your inputs!
iAusio80 is offline
post #2 of 7 Old 08-20-2012, 01:32 PM - Thread Starter
iAusio80's Avatar
Originally Posted by iAusio80 View Post
Hey Guys,
bump ;-
iAusio80 is offline
post #3 of 7 Old 08-20-2012, 01:55 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
If you like the sound of the Take speakers, I would think any of the above would sound good. That said why do you have to wall mount bookshelf speakers? Do you not have the option of using stands? Otherwise I tend to like the on-wall options if you have to go on-wall. The Deftech and Totem speakers look interesting. With any of these choices you will want a dedicated subwoofer, have you budgeted for one?
ack_bk is offline
post #4 of 7 Old 08-20-2012, 04:12 PM - Thread Starter
iAusio80's Avatar
Thx!
I'd prefer wall mount to keep a clean look and also avoid them being knocked over by dog or get pounded by the robotic vacuum cleaner.
I really did start with floorstanders in mind, but have kind of moved away assuming bookshelves wouldn't be a bad sacrifice.
I've heard the 685s and like them, but the Kefs seem to have good reviews and are slightly cheaper as well. I could get a pair @ reduced price from A4less.
I haven't heard the Deftechs or Totems. I do have a PA subwoofer. Not earthshaking, but kind of does the job. Could always get an SVS or Rhythmik in the future ;-
What I was looking for is to itemize the top (within the budget) bookshelves or on-wall speakers and then narrow down per reviews and auditioning.
iAusio80 is offline
post #5 of 7 Old 08-20-2012, 05:22 PM
smasher50's Avatar
Quoted: 354 Post(s)
Liked: 15593
fwiw, pair of nht classic3's and classic3 center.these are acoustic suspension designed (no ports) so they can be mounted to walls if you don't mind buying used there are pair of classic3's and center on audiogon for $700 obo
i'm so laid back,i'm laid out
smasher50 is offline
post #6 of 7 Old 08-20-2012, 05:46 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Two good options from Focal
The 705V can be wall-mounted - with the good price, buy 2 pair and use one as a center channel.
The regular center channel is more expensive. Special price here.
http://dedicatedaudio.com/inc/sdetail/34397
The Focal Sib XL is another option
http://www.musicdirect.com/p-4906-focal-sib-xl-speaker-ea.aspx
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #7 of 7 Old 08-21-2012, 12:41 PM - Thread Starter
iAusio80's Avatar
Great!. Need to find a place to audition.
List in no specific order:
[5] Focal 705V
iAusio80 is offline
Reply Speakers
