7.1 rear L& R aiming - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 08-19-2012, 03:05 PM - Thread Starter
Lastyear4gt's Avatar
My rear surrounds are set up about standing height. Should I aim them in and down at the listening or just in and let them fire over the listening area. I've read many different opinions. They are direct firing bookshelves.
Edit: I should mention they are about 16 feet behind the seating area.
LG 47LG70 LCD, Onkyo TX-NR818, Energy Connoiseur CC-10, 4- CB-20's, 4 Omnimount 20.0, 2- CR-10's, 10" JBL Studio 150, PS3, Bell 9143 HD PVR
Lastyear4gt is offline
post #2 of 17 Old 08-19-2012, 06:03 PM
pukemon's Avatar
Quoted: 279 Post(s)
Liked: 71
Guessing from what you mentioned probably just let them fire straight. No toe in or aiming down if that is what you mean. You could always try different configs and see what works best also.
butter and jelly please.
Home theater gladly not designed by ereed or bgtighe23. 65" JS9500, Marantz 7702MKII, Parasound Halo A31, ClassDaudio SDS470 4ch, RBH R56, 4xRBH R55, 2x RBH R5, Hsu VTF 2 MK 3 and VTF 3 for subwoofage, OnStage MS7701B mic stand with boom for improved Audussey XT32 calibrations. Listening space happily treated with 1" OC 703 rigid fiberglass. OPPO 203 or 205 soon.
pukemon is offline
post #3 of 17 Old 08-19-2012, 06:15 PM - Thread Starter
Yeah that's what I was referring to. Thanks for the input.
post #4 of 17 Old 08-19-2012, 10:53 PM
sdurani's Avatar
Quoted: 4509 Post(s)
Liked: 2915
I would point each rear speaker at the listener on the opposite side of the seating. So the right rear speaker would be aimed at the listener sitting on the left end of the couch. This won't affect the listener sitting in the middle, but will help minimize the volume level difference of the rear speakers for listeners sitting on either side.
Sanjay
sdurani is offline
post #5 of 17 Old 08-20-2012, 07:08 AM - Thread Starter
You'd aim them cross firing?
post #6 of 17 Old 08-20-2012, 12:50 PM
sdurani's Avatar
Liked: 2915
Yes. Speakers are typically loudest on-axis (pointing directly at you), and start getting quieter as you rotate them off-axis (away from you). Likewise, speakers sound louder when they are closer to you, and start getting quieter as you move them farther away.
If both your rear speakers were pointed directly forward, then the listener on the left side of the couch will be dominated by the sound of left rear speaker, for two reasons: it will be on-axis (pointed directly at his head) AND closer to him than the other rear speaker. Double whammy.
However, if you point that left rear speaker at the listener on the right side of the couch, then you trade off some of the energy of the closer speaker by hearing it attenuated off-axis. Even better, the rear speaker that is farther away is pointing directly at you, compensating for the distance by hearing it louder on-axis.
For the listener seated in the middle of the couch, both rear speakers will be equidistant and sound balanced. It is the listeners on either side that will thank you, for having a more balanced rear soundstage (by keeping the nearby speaker from dominating). You might want to consider this for your side speakers as well, if they are mounted above ear height.
Sanjay
sdurani is offline
post #7 of 17 Old 08-20-2012, 03:12 PM - Thread Starter
Interesting idea. I'll give it a try. I cannot however apply this to the side speakers as they are dipole speakers. Which leads me to another question. They have a selectable switch. Should I have them set to bipole or dipole?
post #8 of 17 Old 08-20-2012, 08:32 PM
sdurani's Avatar
Liked: 2915
IF they are so close to the listeners that their direct sound will be distracting, then set them to dipole (so that the listeners are sitting in the null). Otherwise, I would set them to bipole.
Sanjay
sdurani is offline
post #9 of 17 Old 08-20-2012, 08:48 PM
Skylinestar's Avatar
Quoted: 1056 Post(s)
Liked: 185
How about doing this for front L+R speakers to improve the sweetspot?
Skylinestar is online now
post #10 of 17 Old 08-20-2012, 09:11 PM
wlhungdude's Avatar
Quoted: 180 Post(s)
Liked: 223
may be worth checking this out...
http://libinst.com/PublicArticles/Setup%20of%20WG%20Speakers.pdf
hope it helps
mods, can we have a 'dislike' button ?
wlhungdude is offline
post #11 of 17 Old 08-20-2012, 09:11 PM
carp's Avatar
Quoted: 2503 Post(s)
Liked: 1765
I have seen that kind of toe in recommended to avoid a big first reflection of the side walls and to indeed give a wider sweet spot. I tried it and didn't like it, I toe in so that the mains are pointed right at me.
carp is online now
post #12 of 17 Old 08-20-2012, 09:12 PM
carp's Avatar
Liked: 1765
hope it helps
Beat me to it, that's exactly what I was referring to.
carp is online now
post #13 of 17 Old 08-20-2012, 09:39 PM
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
hope it helps
great read, thanks
mgrotel is offline
post #14 of 17 Old 08-20-2012, 10:01 PM
Mitchellin's Avatar
Rives Audio's site helped me out. I was in need of some help with proper placement of my front mains and the "resources" link had a shload of links, concepts, formulas, and geek reads that would allow a deaf person to dial in the most complicated system.
Mitchellin is offline
post #15 of 17 Old 08-20-2012, 10:45 PM
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
^ do you have a link?
mgrotel is offline
post #16 of 17 Old 08-21-2012, 01:50 AM
sdurani's Avatar
Liked: 2915
Won't improve the sweet spot since it is intended to make the soundstage more consistent for listeners on either side of the sweet spot. Definitely worth a try to see if you like it.
Sanjay
sdurani is offline
post #17 of 17 Old 08-21-2012, 09:57 AM - Thread Starter
hope it helps
That was an interesting read, makes alot of sense. I'm gonna give it a try.
Reply Speakers
