EMPtek or Aperion?? Would love some advice. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 08-19-2012, 04:12 PM - Thread Starter
rics17's Avatar
Hello. Looking to upgrade and I have narrowed it down to Aperion or EmpTek models. I have read many reviews but am still undecided on which to get. I will take any other suggestions for systems since I am a novice at best when it comes to this. The room is 15' X 12' with 9' ceiling.
I also would like recommendations on a receiver (5.1 or 7.1) that is good enough to handle. I currently own an Onkyo TX NR 509 but I think I would need an upgrade. Please correct me if I am wrong and if there is anything else that I would need.
Aperion: Intimus 5T Tower, 5C Center, 4BP Surround and Bravus Iia 8D sub on sale for $1300.
I would also consider the Verus line if they are really worth the extra money but most likely would exceed $2000. Not a deal breaker but if I can get something just as good for less I may as well go that route.
EmpTek: E55Ti Tower, E55Wi Surround, E56Ci Center and ES1010i sub also on sale for $1740.
I do like both systems and their design but more importantly I would like to know if the sound difference is worth paying more. If anyone can offer any advice I would greatly appreciate it. Many thanks.
rics17 is offline
post #2 of 19 Old 08-19-2012, 05:43 PM
pukemon's Avatar
Quoted: 279 Post(s)
Liked: 71
I think you would definitely need a receiver upgrade. Might want to consider a prepro and some nice amps for either brand you end up with.
butter and jelly please.
Home theater gladly not designed by ereed or bgtighe23. 65" JS9500, Marantz 7702MKII, Parasound Halo A31, ClassDaudio SDS470 4ch, RBH R56, 4xRBH R55, 2x RBH R5, Hsu VTF 2 MK 3 and VTF 3 for subwoofage, OnStage MS7701B mic stand with boom for improved Audussey XT32 calibrations. Listening space happily treated with 1" OC 703 rigid fiberglass. OPPO 203 or 205 soon.
pukemon is offline
post #3 of 19 Old 08-19-2012, 05:46 PM - Thread Starter
rics17's Avatar
Thanks pukemon!! I will take that into consideration and start searching for a better receiver.
rics17 is offline
post #4 of 19 Old 08-19-2012, 06:36 PM
gtpsuper24's Avatar
Liked: 99
You don't need a pre pro and separate amps for those speakers. A decent receiver will power them just fine, find one with preouts to add a separate amp later on but 99% sure you won't need 200+watt amps. I would use more of your budget toward getting a better subwoofer or two than the two subs you have listed. I would skip both the EMP sub and Aperion sub and go with something like HSU VTF-2 MK4.
I would go with the Aperion since its cheapest of the two and add some extra for a different subwoofer.
gtpsuper24 is offline
post #5 of 19 Old 08-19-2012, 06:40 PM
darkpoet25's Avatar
Liked: 40
Something like the 709 should be adequate enough for those speakers. Not to mention the pre-outs, should the OP decide to get an outboard amp later on.
Cliff
darkpoet25 is offline
post #6 of 19 Old 08-19-2012, 07:12 PM - Thread Starter
rics17's Avatar
Thank you both gtpsuper24 and darkpoet25 for your opinions!!! I may really consider going the Aperion route now with the 709 and a different sub.
rics17 is offline
post #7 of 19 Old 08-19-2012, 08:39 PM
Elihawk's Avatar
Quoted: 1030 Post(s)
Liked: 869
Cannot comment on Aperion, but I own the Emptek speakers and they look and sound great!
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is online now
post #8 of 19 Old 08-19-2012, 08:42 PM - Thread Starter
rics17's Avatar
Thanks Elihawk! Glad you are enjoying your system. May I ask you what kind of receiver you are using?
rics17 is offline
post #9 of 19 Old 08-19-2012, 08:48 PM
Elihawk's Avatar
Liked: 869
You don't want my avr...older Sherwood with no hdmi!
Will be looking for a new avr soon...thinking about a denon!
post #10 of 19 Old 08-19-2012, 08:51 PM - Thread Starter
rics17's Avatar
Okay thank you again!!
rics17 is offline
post #11 of 19 Old 08-19-2012, 08:56 PM
gtpsuper24's Avatar
Liked: 99
Other than wanting newer updated options, I assume that the Sherwood has no problems powering the EMPs to high out levels?
I think the OP should check out receivers that have the options he would want (ie. #of channels, # of hdmi, audyssey, ect not power) You would be really surprised at the levels a receiver can push some speaker that are 8ohm with no crazy impedance dips.
post #12 of 19 Old 08-19-2012, 09:14 PM - Thread Starter
rics17's Avatar
Will do gtpsuper24.
rics17 is offline
post #13 of 19 Old 08-19-2012, 09:34 PM
zieglj01's Avatar
Quoted: 949 Post(s)
Liked: 848
Since they both have a return policy - if you can not make up your mind, then order a pair of
bookshelf speakers from the same series of both companies. Check out the sound signature
and find out which one you like best. Then set up the system that you like best, I would still
prefer a subwoofer from the sub experts > HSU, Outlaw, SVS or Epik.
Marantz, Denon, Yamaha and Pioneer Elite > make some nice receivers. Good Luck!
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is online now
post #14 of 19 Old 08-19-2012, 09:41 PM - Thread Starter
rics17's Avatar
Thanks zieglj01!! Appreciate your answers to my questions. Looking forward to checking out those brands.
rics17 is offline
post #15 of 19 Old 08-20-2012, 06:00 AM
Elihawk's Avatar
Liked: 869
Sorry, the Sherwood is rated at 75 watts per channel and has never failed to produce sufficient volume...so yes, it has plenty of power to drive the EMPs! Not reference levels or anything, but more than enough volume for my 14 x 16 foot room plus some. This model has been discontinued, so a mute point anyway!
post #16 of 19 Old 08-20-2012, 06:27 AM
pukemon's Avatar
Quoted: 279 Post(s)
Liked: 71
The emp's are rated 6 ohms I believe. Threw out the receiver recommendation to make sure he gets a receiver that will do 6 ohms without problems.
pukemon is offline
post #17 of 19 Old 08-20-2012, 06:32 AM
pukemon's Avatar
Quoted: 279 Post(s)
Liked: 71
And I believe they were 88db speakers for the towers. Nothing heavy duty but between that and 6 ohms the op should look into something a little heavier duty, not necessarily wattage.
pukemon is offline
post #18 of 19 Old 08-20-2012, 07:44 AM - Thread Starter
rics17's Avatar
That is good to know Elihawk, thanks!
Some butter and jelly for pukemon for his input! Thanks.
rics17 is offline
post #19 of 19 Old 08-24-2012, 11:47 AM
shanebo's Avatar
This. I'm running that same EMP setup (minus the EMP sub) and I love it. I'm powering the system with a Yamaha RX-A710 (in 8 ohm mode) and it's plently loud for my 25x16x18 open room. Music can be heard throughout the house, even when I run 6 outdoor speakers simultaneously on zone 2 (although I really need to get a separate amp to run these speakers).
shanebo is offline
Reply Speakers
