Speaker stand recommendations? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-20-2012, 06:41 PM - Thread Starter
index2020X's Avatar
So, I learned a ton from this forum and was able to get a great set of speakers.
Being a newbie about speaker stands as well... I thought I'd ask before going out and buying something. Does the quality matter for audio quality in anyway? Should I just go out and buy something that looks good enough? Metal vs. wood?
index2020X is offline
post #2 of 4 Old 08-20-2012, 08:31 PM
JimWilson's Avatar
Quoted: 1274 Post(s)
Liked: 1584
Perhaps by some esoteric measure the material a stand is made form might be considered an influence on the sound, but the reality is there's really no audible (and more than likely even quantifiable) difference. Purchase whatever you deem appropriate.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is online now
post #3 of 4 Old 08-20-2012, 08:45 PM - Thread Starter
index2020X's Avatar
post #4 of 4 Old 08-24-2012, 08:11 AM
Tom C's Avatar
Quoted: 70 Post(s)
Liked: 72
This probably goes without saying, but the height of the stand makes a difference. Ideally the tweeters should be at ear level, so keep that in mind when deciding on which stand to get.
LG OLED55B6P ** Denon AVR-X4200W ** oppo UDP-203 **oppo BDP-103D
HR44 DirecTV ** Panamax 5300 ** Harmony One Universal Remote
Hsu HB-1 MK2 (L, R & S) ** Hsu HC-1 MK2 (C) ** Hsu VTF-15H (sub)
Crowson Technology Level 2 Motion System
Tom C is online now
Reply Speakers
