which speakers to use as fronts ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-20-2012, 05:44 PM - Thread Starter
carsfreak88's Avatar
hey how you guys doing i recently bought klipsch speakers
2 x KG 5.5
2 x RF - 3 II
1 x RC 3 II
which speakers do you guys think i should use as fronts?
the rf-3 ii or the kg 5.5
the guy i bought the speakers from used the kg 5.5 as the fronts but from what i was reading on the forum
it says that the center should match the fronts
so i am not sure what to do
carsfreak88 is offline
post #2 of 3 Old 08-20-2012, 05:56 PM
skally's Avatar
Def. the KG 5.5's as fronts ( L&R) as use the RC 3 II as a center
skally is offline
post #3 of 3 Old 08-20-2012, 07:51 PM
zieglj01's Avatar
Quoted: 1709 Post(s)
Liked: 1624
The Klipsch Reference towers, are higher quality performers to me - for best balance up front,
I would go with the RF-3 towers and RC-3 center > they will timbre (voice) match.
Your choice and good luck.
__________________________________________
Who AM I
Speakers -- Canton GLS 2 > Boston VS240
Receiver -- Integra 50.2
zieglj01 is online now
Reply Speakers
