What front lrc to replace quintet with denon avr591? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 08-20-2012, 10:03 PM - Thread Starter
Popeeta's Avatar
Hey guys! Finally got a bigger house and I have room for bigger speakers now! Unfortunately, my budget has mostly been spent on house so I would really like to keep it around $800 or less for the 3 speakers. Preferably around 600 or less. I am willing to wait for items to go on sale.
So I have to denon avr591 and really like it. I will probably never have more than 5 speakers (not counting sub of course). Basically, I want to keep the quintet surround speakers and upgrade the 2 fronts and the middle. The room is a pretty good size. 20x25 with 14' ceilings. Is it do-able with the 591 at 75watt per channel? Would most speakers work well with the quintets still being used for surround? Is there anything that would work great keeping the quintet center speaker and using that budget just for left and right tower speakers? Thanks guys.
Popeeta is offline
post #2 of 11 Old 08-20-2012, 10:13 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
Infinity primus P363 and PC351 center
http://www.crutchfield.com/p_108P363BK/Infinity-Primus-P363.html
http://www.crutchfield.com/p_108PC351BK/Infinity-Primus-PC351.html
KEF iQ70 speakers were $250ea this morning.
http://www.newegg.com/Product/Product.aspx?Item=N82E16882156011&nm_mc=KNC-GoogleAdwords&cm_mmc=KNC-GoogleAdwords-_-pla-_-NA-_-NA
matching center IQ60C
http://www.newegg.com/Product/Product.aspx?Item=N82E16882156010
I'm sure they'll be on sale again shortly.
Quintet center is too small to use with larger speakers. The other Quintets will be fine as surrounds.
Afro GT
afrogt is online now
post #3 of 11 Old 08-20-2012, 11:28 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Big room means you should look at speakers capable of high output levels. These BIC PL speakers come in just under your budget, and should do well for your situation
http://www.amazon.com/BIC-America-PL-89-Acoustech-Speakers/dp/B001VIXH7I
http://www.amazon.com/BIC-Acoustech-PL-28-Center-Speaker/dp/B001VIPUFU/ref=pd_bxgy_e_text_b
(these speakers are designed to be pushed up against a wall for HT)
Jay1 is offline
post #4 of 11 Old 08-21-2012, 12:24 AM
kemetblk's Avatar
Quoted: 13 Post(s)
I second the Infinity's. Great sound for the money. With ceilings that high you definitely need high output, I would also look at JBL as they are known for their output. If you like aggressive music (rock, rap, etc.) and action movies/games they are a great choice.
HD-DVD: 55 / Blu-ray: 97
newest: Brotherhood of the Wolf / Kingsmen, How to Train your Dragon
AVR: Marantz SR6006
F/C/R: Polk RTi A9's / CSi A6 / Speakercraft AIMWIDE 3 / Sub: SVS PB12-NSD
SonyXBR-75X940D Samsung BD-P2550, Toshiba HD-A30, Nvidia Shield TV (2015), Xbox360 Elite, PS3, WDTV Live
kemetblk is offline
post #5 of 11 Old 08-23-2012, 12:26 PM - Thread Starter
Popeeta's Avatar
My wife shot down the infinitys just because they're so ugly! They'll be up front and center in full view. Not many reviews on any of the others but I will watch to see if they go on sale. Anyone have experience with the klipsch kf-28's?
Is my receiver too small to push something like that without an external amp? There are preouts but don't have an amp at this time. Seems like there's not really a great choice of 5.1 receivers that put out much more than 90 watts/channel. Please correct me if I am wrong.
Popeeta is offline
post #6 of 11 Old 08-23-2012, 01:20 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
I believe you can do better than the Klipsch - however, you may like them
You can buy a 7.1 receiver, and still only use 5.1
http://www.accessories4less.com/make-a-store/item/DENAVR991/DENON-AVR-991-7.2ch-Networking-A/V-Theater-Surround-Receiver/1.html
Did your wife look at the KEF, that was reccomended?
Also, what does your wife think about white speakers with a black grill? Boston is a good one.
http://www.accessories4less.com/make-a-store/item/BOSA360WHA/BOSTON-ACOUSTICS-A360-3-Way-Dual-6.5in-Tower-Speaker-Each-White/1.html
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #7 of 11 Old 08-23-2012, 02:08 PM
afrogt's Avatar
Liked: 755
The Denon 991 doesn't have the preouts required for an amp to power the front speakers , you'll need the 3311 or 3312. Or if you want to go back a couple of years the 990/3310.
The AVR-591 doesn't have any preouts except for surr back which wont help you, I own that receiver.
Afro GT
post #8 of 11 Old 08-23-2012, 02:33 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
They key question for all this - do you plan to listen at extreme mancave levels, or moderate levels?
Who AM I
zieglj01 is offline
post #9 of 11 Old 08-23-2012, 02:58 PM - Thread Starter
Popeeta's Avatar
Lol. Not super extreme but I love a really loud movie that can be felt as well as heard.
Popeeta is offline
post #10 of 11 Old 08-23-2012, 03:37 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
The biggest impact will come from good subwoofers - and they have their own amp.
Tower speakers will sound much better than little sat speakers > that tend to sound
big in a walk-in closet. A bigger Denon receiver with more amp power can help out.
If you really want to do amps - then this Yamaha receiver has pre-outs.
http://www.amazon.com/Yamaha-RX-V667-7-2-Channel-Theater-Receiver/dp/B003P2V52M
http://usa.yamaha.com/products/audio-visual/av-receivers-amps/rx/rx-v667/?mode=model
Who AM I
zieglj01 is offline
post #11 of 11 Old 08-23-2012, 03:58 PM - Thread Starter
Popeeta's Avatar
Ok sounds good I'll save the budget up for a better denon and work from there. Thanks for the help
Popeeta is offline
Reply Speakers
Denon Avr 591 Receiver
