Speaker stand for Definitive Technology Pro Cinema 600 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-24-2012, 07:24 AM - Thread Starter
cowboys88's Avatar
Can anyone recommend a pair of speaker stands for the Pro cinema 600? I was looking at the Sanus natural wood stands but thought the speakers might look a little odd on since the speakers are oval shaped and would be sitting on a square stand. Also, do you think it is worth it to spend an extra $160.00 to get the Pro Cinema 800? Thanks,
cowboys88 is offline
post #2 of 4 Old 08-24-2012, 08:44 PM
JimWilson's Avatar
Quoted: 1270 Post(s)
Liked: 1579
I have the Sanus EFSat stands. They have a multitude of different adapters, so you can mount almost any type of speaker to them. I think for the price they're a good deal.
Yes. The difference between the two systems is worth more than $160 upcharge.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is online now
post #3 of 4 Old 08-25-2012, 09:01 AM
Hookedonc4's Avatar
Quoted: 26 Post(s)
The 600 is a great sounding system we use wall mounts for all except center channel.
Denon X4000, SC-91, VSX-51,VSX-81 Pioneer Elites and Denon 1611
James loudspeaker inwalls main and future theater
Control4
Other speaker zones DefTech, Polk, Russound, Boston Acoustics
Hookedonc4 is offline
post #4 of 4 Old 08-25-2012, 09:11 AM
raehza's Avatar
Search on amazon.com for deftech wall mount and stands made by deftech. They aren't that expensive and work very well.
Projector: AE7000
Screen: 5x12 Wilson Art Laminate Designer White
Receiver: Denon 2112Ci
Fronts: DefTech 8020ST
Center: DefTech 8040HD
Side Surround: DefTech SR 8040 BPs
Rear Surround: DefTech PM 1000s
Subwoofers: 2x HSU VTF 15H's
raehza is offline
Reply Speakers
