Def Tech Pro 600 or 800? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 08-24-2012, 11:01 AM - Thread Starter
cowboys88's Avatar
I am looking at the Def Tech Pro 600 to pair with a Denon 2113ci. Is it worth the extra money to upgrade to the Pro 800?
cowboys88 is offline
post #2 of 12 Old 08-24-2012, 11:12 AM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
Do you have a dedicated subwoofer, and what is your budget?
The parent company for Deftech sells refurbished speakers on Ebay and, depending on your budget, you might even be able to step up to a Pro 1000:
http://www.ebay.com/itm/Definitive-Technology-ProMonitor-1000-Speaker-BBNDKA-/190644675513?pt=Speakers_Subwoofers&hash=item2c634ee3b9
The white model is $159 shipped
ack_bk is offline
post #3 of 12 Old 08-24-2012, 12:05 PM - Thread Starter
cowboys88's Avatar
No, I do not have a sub. I looking to stay under 800.
post #4 of 12 Old 08-24-2012, 12:25 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Do you need small, or can you go bigger? Can you start with 3.1 for now?
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #5 of 12 Old 08-24-2012, 01:10 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
I am with you on this. Focus your $800 budget on your main three speakers and get a sub.
You could do three of these (assuming you stick with Deftech):
http://www.ebay.com/itm/Definitive-Technology-ProMonitor-800-Speaker-BBNDHA-/190687206753?pt=Speakers_Subwoofers&hash=item2c65d7dd61
For $360 and still get a decent sub like this one (room size would help):
http://www.hsuresearch.com/products/stf-2.html
Then add some surrounds later.
ack_bk is offline
post #6 of 12 Old 08-24-2012, 01:13 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
This sub is a great deal right now:
http://www.vanns.com/shop/servlet/item/features/549645163
$300 shipped would give you $500 budget for speakers which puts you within $25 of the refurb Deftech 1000.
ack_bk is offline
post #7 of 12 Old 08-24-2012, 01:36 PM
rick240's Avatar
Quoted: 18 Post(s)
Liked: 52
These are good choices.
You definitely want at least the 800, nit the 600, and if you can afford the 1000 all the better (you will be upgraded further in the future this way).
Also, check your local craigslist for a used sub. You might find something decent for $275 which makes the refurbed 1000 affordable.
rick240 is offline
post #8 of 12 Old 08-24-2012, 01:39 PM - Thread Starter
cowboys88's Avatar
Yes, I can definitely start with a 3.1. Any recommendations on the 3 main speakers and a sub for at or below $800.00? I could go a little over if I have to.
post #9 of 12 Old 08-24-2012, 02:23 PM
Kini62's Avatar
Quoted: 1415 Post(s)
Liked: 1301
3 NHT SuperZero 2.0s and a HSU VTF-2 MK4 or Outlaw sub. Too bad the Rythmik FV12 is still not available.
How big is your listening area?
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #10 of 12 Old 08-24-2012, 03:29 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
That Jamo sub is a good choice, and a good bargain > post #6
http://www.avsforum.com/t/1425552/jamo-sub-650-omnimic-frequency-response-graphs
Also, the Definitive Tech SM350 is a good speaker - buy 2 pair, and use one speaker as a center channel.
That would be cheaper, than buying a center channel
http://www.newegg.com/Product/Product.aspx?Item=N82E16882325059
Who AM I
zieglj01 is offline
post #11 of 12 Old 08-24-2012, 06:13 PM - Thread Starter
cowboys88's Avatar
The area is about 16 1/2 x 15 but its basically open to the kitchen as well. After reading the posts I think I am leaning towards the 3.1 with a sub. So if anyone has any more speaker recommendations, I'm all ears.
post #12 of 12 Old 08-24-2012, 08:42 PM - Thread Starter
cowboys88's Avatar
I went with the Jamo sub, couldnt pass it up for 249.00 with free shipping. Now I just need to fiigure out the other three speakers.
Reply Speakers
