Best Looking *mini* speakers for HT - Salk, Haberth, etc - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-24-2012, 08:39 PM - Thread Starter
chefwong's Avatar
New Family Room Setup...
Minimal as possible so no floorstanders. Very clean look...
I'm having a custom made enclosure in which the Rhtmik 15" will sit. The enclosure....will server as a sidetable.
This is strictly for tv / movie use.
What is that smalles set of GREART looking/sounding speakers. Either it will be a 2.1 or 3.1 setup.
I toyed with the idea of inwalls but nixed it.
The bookshelves will either sit on the custom media console I'm having built OR...I will figure out something
Thoughts, suggestions.
High WAF factor required ;-)
As minimalistic in looks as possible
chefwong is offline
post #2 of 5 Old 08-25-2012, 04:30 AM
ccotenj's Avatar
Liked: 101
if you are interested in salks, call jim and ask his advice... he will shoot straight with you...
before you build that custom enclosure to put a sub in (likely not a good idea, fwiw, unless you meant you were having a custom sub box built), ask jim about subs too... smile.gif
- chris
ccotenj is offline
post #3 of 5 Old 08-25-2012, 07:20 AM
Greg121986's Avatar
Quoted: 48 Post(s)
Liked: 35
Harbeth Monitor 30.1 is an exceptional compact speaker. It might be a bit bigger than you need, but I recently spent some time listening to it and as you would expect, it's phenomenal.
Greg121986 is offline
post #4 of 5 Old 08-25-2012, 07:46 AM
rick240's Avatar
Quoted: 28 Post(s)
Liked: 53
How big is the room?
How loud do you listen?
What receiver/amp do you have?
How big is the budget?
rick240 is offline
post #5 of 5 Old 08-25-2012, 07:48 AM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 569
The KEF iQ30 is a very nice-looking speaker, especially in the walnut veneer cabinet.
So is the iQ70 etc.
commsysman is offline
Reply Speakers
