Def Tech C/L/R 2002 x 3? - AVS Forum | Home Theater Discussions And Reviews
Old 08-26-2012, 05:34 PM - Thread Starter
EVERY1ELECTRONIC's Avatar
I got a very good deal on 3 of these speakers and my plan was to use them as front and center speakers for a very timber matched setup, do you guys think it would be worth it to bi-wire all 3 speakers, the cable has already been run for bi-wireing the front 3 speakers when I first started building my HT.
I also have some bp 8 speakers that I could use as fronts along with 1 of the CLR 2002 speakers, not sure which configuration would give me the best sound, any thoughts on this?
What do you guys think would be great speakers for surrounds? I really like the UIW RSS II not sure if that would be ideal or sound right with any of these arrangements?
I also wanted to know your thoughts on the cs8060hd center channel, is that center better than the clr 2002 aside from having the built in sub?
EVERY1ELECTRONIC is offline
Old 08-27-2012, 11:43 AM
swallan's Avatar
Liked: 27
at one time i was thinking of going with 3 clr 2002 right now i have the clr 2002 as center and the sm 350 for left and right i would think that 3 clr 2002 would sound pretty good.
swallan is offline
