Center channel recommendations - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #1 of 32 Old 08-26-2012, 07:46 PM - Thread Starter
cowboys88's Avatar
Need recommendations on a center channel to put between 2 definitive technology 800 speakers. I have $200.00 to spend.
cowboys88 is offline
post #2 of 32 Old 08-26-2012, 07:53 PM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
Just get another one and place it on its side.
http://www.amazon.com/Definitive-Technology-ProMonitor-Bookshelf-Speaker/dp/B000TD6QLK
dr_bling likes this.
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
post #3 of 32 Old 08-26-2012, 08:32 PM
logan115's Avatar
The procenter 1000 is the matching center for the 800s.
Chris
logan115 is offline
post #4 of 32 Old 08-27-2012, 05:57 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
Putting the same speaker on its side will sound better. Having the tweeter aligned directly with the woofers gives you more horizontal lobing.. Read this article to find out why having a two way on its side is better than that center.
http://forum.blu-ray.com/showthread.php?t=89614
post #5 of 32 Old 08-27-2012, 08:50 PM
Kal Rubinson's Avatar
Quoted: 677 Post(s)
Liked: 460
Not really.  Any horizontal array will have lobing problems whether it is an MTM or an MT bookshelf design.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #6 of 32 Old 08-27-2012, 09:23 PM
rick240's Avatar
Quoted: 18 Post(s)
Liked: 52
...but if I've understood your, and others, comments correctly...
...the MT will have lobing only in the crossover region
...whereas the MTM will have lobing in the entire range of the two Ms plus the crossover range
rick240 is offline
post #7 of 32 Old 08-28-2012, 05:38 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
Exactly.
http://www.audioholics.com/education/loudspeaker-basics/vertical-vs-horizontal-speaker-designs
post #8 of 32 Old 08-28-2012, 07:19 AM
Quoted: 677 Post(s)
Liked: 460
In theory.  However, the lobing is dependent on driver spacing and only significant when the driver spacing exceeds 1 or 1/2 wavelength (depending on who you believe).  Thus, "the two Ms" will have problems only at the upper end of their ranges and not at the lower end.  So, it comes out to the same issue:  Major lobing problems are generally in the crossover range, regardless of the number of drivers.
Kal Rubinson
post #9 of 32 Old 08-28-2012, 08:44 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
I suggest that you get the Cambridge Audio S50; it should be perfect for that setup, and it just happens to cost $200. You should no problems at all with that combination.
commsysman is offline
post #10 of 32 Old 08-28-2012, 02:13 PM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
I still say getting one of his L/R will still be the best match since it's the exact same speaker.
post #11 of 32 Old 08-28-2012, 03:25 PM
Kini62's Avatar
Quoted: 1415 Post(s)
Liked: 1300
+1
I have SuperZero 2s and use one laid over on its side for a center and notice no issues whatsoever.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #12 of 32 Old 08-28-2012, 07:23 PM
Quoted: 677 Post(s)
Liked: 460
Originally Posted by Kini62 View Post
+1
Not everyone hears the problems and that's OK.
Kal Rubinson
post #13 of 32 Old 08-28-2012, 08:56 PM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
post #14 of 32 Old 08-29-2012, 09:38 AM
JHAz's Avatar
Quoted: 305 Post(s)
Liked: 271
JHAz is offline
post #15 of 32 Old 08-29-2012, 11:50 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
http://m.youtube.com/watch?v=5zey8567bcg
post #16 of 32 Old 08-29-2012, 11:59 AM
HighEndAV's Avatar
You need to call the manfacture to see if putting it on its side is acceptable, to many variables. But usally a center will have more mid rang drivers since it plays 80% or more if the voices. But whatever you gde get one that matches you have limited choices if you get another brand or a speaker that is not voiced the same it will stick out like a sore thumb.
HighEndAV is offline
post #17 of 32 Old 08-29-2012, 12:25 PM
pureiso's Avatar
This focus on using a bookshelf design and putting it on its side is interesting to me. People are so worried about lobing, when it is rather benign until well off axis. You are just trading one set of problems with another if you ask me...
pureiso is offline
post #18 of 32 Old 08-29-2012, 02:40 PM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
You're not making any compromises if the tweeter radiates equally in all directions.
post #19 of 32 Old 08-29-2012, 04:09 PM
Quoted: 677 Post(s)
Liked: 460
Nope.  In fact, it can be ameliorated with controlled dispersion but that kind of sophistication is beyond most middle-market products.
Kal Rubinson
post #20 of 32 Old 08-29-2012, 04:31 PM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
There are plenty of middle market controlled dispersion speakers. Or am I not understanding your response?
post #21 of 32 Old 08-29-2012, 09:09 PM
Quoted: 677 Post(s)
Liked: 460
The point I was making is that "if the tweeter radiates equally in all directions" it will not resolve the lobing problems associated with horizontally arrayed drivers.  In fact, controlled dispersion is possible way to ameliorate the problems.
Kal Rubinson
post #22 of 32 Old 08-29-2012, 09:58 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
The vertical null of a TM system is a phase alignment issue, it doesnt matter if it's CD or not. The best compromise for most people should be a vertical TM under the screen tilted back slightly.
Jay1 is offline
post #23 of 32 Old 08-29-2012, 10:10 PM
Quoted: 677 Post(s)
Liked: 460
Yup.
Kal Rubinson
post #24 of 32 Old 08-30-2012, 08:39 AM
pureiso's Avatar
Even then, it is still compromise. You are not completely on axis with the tweeter, and if you are then other seats will not be. More importantly, you lose sensitivity and gain distortion in a TM design over an MTM design. It is compromise no matter what unless you have a transparent screen with speakers exactly aligned, and usually those speakers will have a small line array (MTMMM) or need to be a well designed speaker to not run into compression/distortion at reference levels.
pureiso is offline
post #25 of 32 Old 08-30-2012, 09:29 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
ah, I see what you meant now. I guess my point was if the tweeter radiates equally in all directions, then laying it on its side would not make it sound differently, right? (at least I think so, I still have much to learn)
But I very much agree with you vis a vis the directivity and controlled dispersion.
post #26 of 32 Old 08-30-2012, 11:05 AM
rick240's Avatar
Quoted: 18 Post(s)
Liked: 52
ah, I see what you meant now. I guess my point was if the tweeter radiates equally in all directions, then laying it on its side would not make it sound differently, right? (at least I think so, I still have much to learn).
As I understand laying the speaker horizontally doesn't create lobing, it just changes it from being in the vertical direction to the horizontal direction. Lobing happens because there are two source producing sound in the same frequency range and the two waves combine either cancelling or adding causing audible effects.
The point is that most people sit at the same vertical level when watching a movie but are horizontally dispersed in front of the screen.
Hence - vertical lobing is a non issue - horizontal lobing can be an issue with wide horizontal dispersion of people and/or particular speaker designs.
rick240 is offline
post #27 of 32 Old 08-30-2012, 11:45 AM
hwdoughty's Avatar
I have a similar question to that of the OP. I have a Boston Acoustics Soundware S 5.1 surround system. I don't much like the looks of the cube for the center channel, and I want to expand to a 7.1 system. As such, I'm looking for a dedicated center channel speaker that would match well to the Soundware S satelites. Then I could buy one more Soundware S and have a 7.1 system. Any recommendations?
hwdoughty is offline
post #28 of 32 Old 08-30-2012, 01:47 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
If you tilt the speaker back, you will be vertically on axis. Horizontally, a vertical TM configuration will have very wide dispersion at all frequencies but the very top of the tweeters response, which has nothing to do with vocal intelligibility. There are plenty of large woofer, high sensitivity 2-way designs available. A perfect example of this setup idea is the Klipsch Heresy
A smaller, cheaper option would be a Chase SHO-10 with a custom stand.
http://www.gwizpro.com/stands/proddetail.php?prod=SCStands
Jay1 is offline
post #29 of 32 Old 08-30-2012, 03:00 PM
pureiso's Avatar
Fair enough, many home theater setups will still have seats that could be easily off axis both vertically and horizontally even with an angled speaker. There are definitely some well designed 2-way speakers, some may be rather sensitive as well. However, using the same drivers in an MTM you will still have lower distortion especially in the vocal range that the midranges would be handling.
pureiso is offline
post #30 of 32 Old 11-10-2014, 11:25 AM
boontok's Avatar
Quoted: 13 Post(s)
Liked: 0
I say to get another matching 800 and keep it vertical. Now your front sound stage has no variation from left to right.
boontok is offline
Reply Speakers
Speaker Systems , Center Channel Speakers , Definitive Technology Promonitor 800 Bookshelf Speaker Single White , Definitive Technology Procenter 1000 Gloss White Ea Center Channel Loudspeaker
