Can someone please help me understand Sensitivity - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-27-2012, 02:57 PM - Thread Starter
index2020X's Avatar
My naïve understanding of sensitivity was that it's a measure of how much sound a speaker can output per unit volume of electrical input (a crude measure of efficiency and loudness?). Clearly I must be wrong because my outgoing Polk R150 has a sensitivity of 89 dB while the new B&W CM5 has a sensitivity of 88 dB. At the same volume level on my receiver, the CM5 produces way more sound.
Thanks in advance.
index2020X is offline
post #2 of 4 Old 08-27-2012, 04:08 PM
Bill Fitzmaurice's Avatar
Liked: 4699
Unless accompanied by a measured SPL chart sensitivity claims should be taken with a truckload of salt.
Bill Fitzmaurice is offline
post #3 of 4 Old 08-27-2012, 04:12 PM
Hamilcar Barca's Avatar
After you've swallowed your truckload of salt, consider that the actual difference between 88dB and 89dB is quite small.
Hamilcar Barca is offline
post #4 of 4 Old 08-27-2012, 04:23 PM
Gooddoc's Avatar
Quoted: 2707 Post(s)
Liked: 1873
You understand it right. What you discovered is that manufacturers don't always report sensitivity accurately, or they use different methodologies.
The ohm rating of a speaker is listed as a single number, but in reality sometimes fluctuates dramatically in actual usage. A 8 ohm speaker can dip below 4 ohms at certain frequencies. Every speaker varies differently and the actual ohm of the speaker can significantly impact the sensitivity measurement.
For example, the standard methodology to measure sensitivity is a 1watt(or 2.83v) signal measured at 1 meter. Using this method, a speaker that dips to 4 ohms at the frequencies measured would have a 3 dB higher sensitivity than a speaker that was 8 ohms at that frequency.
Also, sensitivities are reported by some manufacturers as in-room and others anechoic. The in-room sensitivity will be higher due to room gain, and that could be 3+ dB. Many don't tell you which method they use.
So using the industry "standard" to measure sensitivity can lead to very different results.
Sent from my Galaxy Nexus using Tapatalk 2
Gooddoc is offline
Reply Speakers
