Denon AVR 1312 with two Polk Tsi 200 Book shelve speakers advice needed - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-28-2012, 06:48 AM - Thread Starter
saifucmp's Avatar
Dear Experts,
I have plan to improve my sound system , Presently I have been using SAMSUNG 40 LED TV with Videocon D2H HD.I have plan to by Denon AVR 1312 and two polk audio TSi 200 Book shelf speakers,Could I get descent audio with this configoration , now I have no plan to use surround speakers later I will upgrade with surround speakers. My use is 70 % Movies and 30 % Mussic , my room size is 13 ft x 11 ft.
Plaese advice with your recommendatios
Thanks in advance to all.
SAIFULLA
saifucmp is offline
post #2 of 5 Old 08-28-2012, 07:40 AM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 567
That sounds like a good way to go.
If it is within your budget, I would suggest that you also purchase a Polk PSW505 subwoofer, as you will probably want more low bass than the front speakers will have.
commsysman is offline
post #3 of 5 Old 08-28-2012, 08:34 AM
zieglj01's Avatar
Quoted: 1573 Post(s)
Liked: 1428
Originally Posted by saifucmp View Post
Dear Experts,
Depends on what your definition of decent is - and also your budget.
__________________________________________
Who AM I
Speakers -- Snell K7 > Q Acoustics 3020 > Boston VS240
Receiver -- Integra 50.2
zieglj01 is online now
post #4 of 5 Old 08-28-2012, 08:49 AM
afrogt's Avatar
Quoted: 1373 Post(s)
Liked: 948
Are you getting the Tsi200s at a discount? If not the Monitor 40's are the same speaker for less.
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290202
If you wait for a sale, you could get the Monitor 60 towers for $120 each which is still probably less than the Tsi200s and a much better speakers.
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290206
They come on sale for $109-$119 ea quite often with free shipping.
Afro GT
afrogt is online now
post #5 of 5 Old 08-28-2012, 01:24 PM
smasher50's Avatar
Quoted: 377 Post(s)
Liked: 18602
fwiw, i would look into the denon avr1612 ( $199 at accessories4less) this step up will give you audyssey which will help you place your speakers in the best location and help configure the speakers for best sound .also some kind ofa budget would help
i'm so laid back,i'm laid out
smasher50 is online now
Reply Speakers
Denon Avr 1312 Receiver , Polk Audio Tsi200 Bookshelf Speakers Pair Cherry , Speaker Systems , Bookshelf Speakers , Premier Acoustic Pa 4 0 Monitors Black
