Best Bang for the Buck? Starting from scratch and would love some expert opinions! - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 34 Old 08-30-2012, 06:07 AM
KidHorn's Avatar
Quoted: 1383 Post(s)
Liked: 890
We recently had a room addition. It's 24'x16' with cathedral ceilings and an open floor plan. We have hardwood floors with area rugs. I have a 11.2 surround system. I would guess I spent around $5k for everything. Not including the TV. What I've found is the subwoofer is the most important thing. It just doesn't sound good without good bass. Getting good bass is the most difficult thing in a large room. I went with 2 emotiva subs on closeout, but if I were buying now, I would definately get the outlaw sub on sale now. After that, I agree the center and fronts are the next most important and if you have room for 3 identical speakers, get that. if not, get a center that's from the same line as the fronts. Surrounds are the least important, but don't get too cheap. They should be of the same general quality as the fronts. If you're like me, if the weakest link doesn't sound right, it will bother me to no end. I'm probably suggesting spending more than you want, but buying something you won't like is throwing money away.
KidHorn is offline
post #32 of 34 Old 08-30-2012, 07:06 AM - Thread Starter
fmaz's Avatar
Exactly. I really want to do this right. But of course, with the renovation we have to put in some cost controls.
fmaz is offline
post #33 of 34 Old 08-30-2012, 07:43 AM
KidHorn's Avatar
Liked: 890
Get 3 of these for LCR
http://www.vanns.com/shop/servlet/item/features/543758931
$180 each or $540
Outlaw sub for $600
2 of these for surrounds
http://www.vanns.com/shop/servlet/item/features/542021944
$180 each or $360
They can be switched from di-pole/bi-pole so you can choose which sounds better to you.
total = 540 + 600 + 360 = 1,500. Right on your preferred budget. All 5 are from the same line so they'll appearance match
KidHorn is offline
post #34 of 34 Old 08-30-2012, 08:50 AM
pronghorn/az's Avatar
Quoted: 20 Post(s)
Liked: 31
Originally Posted by smasher50 View Post
fwiw,pair of ascend acoustics cmt340 se and cmt 340 se center
pair of ascend acoustic's cbm 170's for surround tota l$1212
svs pb12-nsd sub $769
its at your top end of budget but well worth it imo.
Plus one on the Ascend Acoustics, best bang for the buck from what I'm hearing. And check out Rythmiks fourm. He's releasing a new 12" version soon.
Jeff
pronghorn/az is offline
Reply Speakers
