What you guys think of my bookshelf speaker options? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 08-31-2012, 09:41 AM - Thread Starter
flargosa's Avatar
I have been wanting to upgrade my living room speakers from desktop speakers to something better. I have been reading up on the under $1k bookshelf speakers and have found a few options. What do you guys think of my choices below? It has be a bookshelf unfortunately due to its higher wife acceptance factor. The speakers will be in a medium size room 2500 cubic ft. where half of one wall opens into another medium size room.
My choices in order of preference are:
1. The Clue - It can placed within 2 inches of the back wall.
2. Dynaudio speakers (Dynaudio BM 6A MKII) - nearfield so not sure if it work.
3. Paradigm Studio 20
My amp is an old Marantz 5.1 reciever 100 watts/channel so should be adequate. Which ones do you guys think is best? any other recommendations? Budget is $1k
flargosa is offline
post #2 of 11 Old 08-31-2012, 09:48 AM
BeeMan458's Avatar
Liked: 813
If you could list your current speakers and what your sub is?
BeeMan458 is offline
post #3 of 11 Old 08-31-2012, 10:06 AM - Thread Starter
flargosa's Avatar
Current speakers is Swan Diva M200 25 watts. http://www.newegg.com/Product/Product.aspx?Item=N82E16836136102. No subwoofer.
flargosa is offline
post #4 of 11 Old 08-31-2012, 10:08 AM
BeeMan458's Avatar
Liked: 813
My recommendation would be to first see about adding a pair of, at minimum, 10" subs (smooth, tight bass) and then decide if you need a speaker upgrade or what your upgrade path should be.
My opinion, the center channel is the most important speaker, this being quickly followed by one's choice in subwoofers.
In your case, you already have a set of speakers but no subs.
post #5 of 11 Old 08-31-2012, 12:19 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Jay1 is offline
post #6 of 11 Old 08-31-2012, 01:13 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Along with NHT, I like >
Monitor Audio
http://www.audioadvisor.com/prodinfo.asp?number=MRSRX2%20%20%20%20PGLSWHT
Focal 806V
http://www.dedicatedaudio.com/inc/sdetail/25529
Outlaw Audio BLS
http://www.outlawaudio.com/products/bls.html
http://www.outlawaudio.com/products/bls_about.html
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #7 of 11 Old 08-31-2012, 03:55 PM - Thread Starter
flargosa's Avatar
Thanks guys, I'll be doing more reading up on your suggestions. I have gone to BB a few times to audition their speakers, not sure if it is their setup but wasn't too impressed with their speakers, B&W and Energy. Not even close to my mid price headphones, Hifiman HE500 or my previously owned Audeze LCD-2. Not sure if it was their setup but it didn't have the clarity I was looking for, lots of mushy sounding bass with ok clarity across the spectrum.
flargosa is offline
post #8 of 11 Old 08-31-2012, 04:18 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Good luck finding speakers that can match $700 headphones at pretty much any price... Your room, and the typical less then ideal placement in said room have WAY to much influence for that to happen.
Jay1 is offline
post #9 of 11 Old 08-31-2012, 04:23 PM
BeeMan458's Avatar
Liked: 813
And it's a shame as that's a fact. Currently listening to the cable TV with a pair of Sennheiser, HDR-180.
post #10 of 11 Old 08-31-2012, 08:48 PM
cel4145's Avatar
Quoted: 2655 Post(s)
Liked: 2985
And good bass from a sub of near that quality will pretty much take all of your $1K budget.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
post #11 of 11 Old 08-31-2012, 09:54 PM - Thread Starter
flargosa's Avatar
Will planar speakers at $1k sound better than the current choices?
flargosa is offline
Reply Speakers
