Best receiver, bookshelf, center and subwoofer combination under $1,200 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 08-31-2012, 09:45 PM - Thread Starter
Andrewnew's Avatar
What possibilities could you suggest for 70 percent music and 30 percent movies in a bedroom? I dont want a speaker system in which you buy as a set, because I am limited by money and I want to buy each piece over a period of a year. I would like some good low bass and some thump as well as the higher frequency sounds.
Some speakers I have come across are:
HB-1 MK2 Horn Bookshelf Speaker -Although I saw somewhere that the hb-1's wouldnt work well with other brands. If so, scrap it.
BIC PL-200 Acoustech Platinum Series Subwoofer
I also want them to have matching style.
I hope this isnt too demanding. Thanks!
Andrewnew is offline
post #2 of 7 Old 08-31-2012, 10:15 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
How does the Bic, seem to match in style to the HSU speakers?
How much can you spend at a time?
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is online now
post #3 of 7 Old 08-31-2012, 11:34 PM - Thread Starter
Andrewnew's Avatar
Thankyou for replying, I was only pointing out what I liked as seperate possibilities, but not as a pair.
I can spend around 400 at a time.
post #4 of 7 Old 09-01-2012, 05:08 AM
soup dragon's Avatar
i dont know if you consider buying used but there are lots of good stuff in the used market that are high quality and will not break the bank. nhts, b&w, psb and paradigms older models are very good sounding speakers, with that budget you can buy paradigm mini monitors, atoms or titans, psb image speakers, b&w dm303s, or nht super ones, these are great sounding speakers imho, the hsu and bic sub are plain looking subs that will match well with any of these speakers with grills on em if you get them in black,
soup dragon is offline
post #5 of 7 Old 09-01-2012, 06:21 AM
smasher50's Avatar
Quoted: 355 Post(s)
Liked: 15694
fwiw, pair of boston acoustics a26's at vanns $400
boston acoustics a225 center $250 vanns
energy s10.3 sub $199 newegg when on sale usually once a month
Andrewnew likes this.
i'm so laid back,i'm laid out
smasher50 is offline
post #6 of 7 Old 09-01-2012, 08:18 AM
cel4145's Avatar
Quoted: 2658 Post(s)
Liked: 2990
Wait to determine the subwoofer once you are ready to buy, and consult the AVS subwoofer forum. There may be some specific deal at that time that you'll want to take advantage of.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #7 of 7 Old 09-02-2012, 03:29 AM - Thread Starter
Andrewnew's Avatar
thankyou for your input, does it matter what receiver you use? and how much is enough to spend?
Reply Speakers
