3k - 5k budget starting from nothing. - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 39 Old 09-12-2012, 08:29 PM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
Originally Posted by tony123 View Post
My system:
3 LaScalas = 1400
2 Heresies= 250
2 Danley DTS10's = 2000
XPA5= 800
Integra 40.1= $900
Total is $5350. I've got a few other pieces, but you wouldn't have to.
For home theater, it will arguably compete with home theaters of any price range.
Tony's is an excellent setup. Very hard to beat for the price.
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
post #32 of 39 Old 09-12-2012, 08:31 PM
mmiles's Avatar
Quoted: 468 Post(s)
Liked: 214
Damn good deal on the Klipsch. Did you replace any drivers or crossovers? What was the condition of the cabinets? Whetecdid you find them?
Mike Miles
mmiles is offline
post #33 of 39 Old 09-12-2012, 11:35 PM
SmokenAshes's Avatar
Liked: 53
Just want to throw this in here for you to look at and get some ideas. This is my thread of a HT I built back in April. Everything all together was under 5k.
http://www.avsforum.com/t/1401232/first-time-ht-build-the-smoken-theater
Sent from my DROID RAZR using Tapatalk 2
SmokenAshes is offline
post #34 of 39 Old 09-13-2012, 07:17 AM
AcuDefTechGuy's Avatar
Quoted: 175 Post(s)
Liked: 262
Originally Posted by flyng_fool View Post
Different speakers. The Ascends are great, and really nice speakers. But the SHO-10's will outdo them easily for HT. The CD with the horn is what sets the SHO-10 apart.
Not all high efficiency speakers will outdo other speakers for HT. it depends on the room size and the volume. Not everyone wants 105dB volume and not everyone has a large room.
The OP's room is only 11' x 16'. Kind of small. Even the small $99 NHT SuperZero bookshelf speakers can play extremely loud in this room when paired with a great sub.
The most important component IMO is the subwoofer.
I very highly recommend getting the Funk 18.0 unpowered sub, which is $1695 for Canadians. Add a Crown XLS1000 for $300 or use an existing amp if you have.
Just get some bookshelf speakers from KEF, Revel, B&W, Focal, Dynaudio, NHT, Ascend, CHT, etc, and pair them with a Funk 18.0.
Billy p likes this.
AcuDefTechGuy is offline
post #35 of 39 Old 09-13-2012, 08:14 AM
Pianist718's Avatar
Quoted: 134 Post(s)
Check out my system.
If you want to spend a bit more so that in the future with different room size you won't have to go back to upgrading I'd look into Ascend Towers and that massive center channel speaker.
Sharp LC-80LE650U 80-inch, Denon AVR 4311ci, Ascend Sierra-1 NrT, Ascend HTM-200 (surrounds), Rythmik F12, WD TV Live Media Player, Samsung BD ES6000, Denon DVD-2910 & Sony BDP-S370 SACD/DVDa, Monster HTS 5100 MKI, Monster Z2 Biwire, Logitech Harmony One, Sennheiser HD600, Schiit Modi/Vali
Pianist718 is offline
post #36 of 39 Old 09-14-2012, 05:35 AM
OldMovieNut's Avatar
This system will give you unbelievable sound.
Used Gallo Ref 3.1 $1800
http://app.audiogon.com/listings/full-range-gallo-acoustics-reference-3-1-silver-2012-09-12-speakers-52722
Gallo Classico CL-C $600
http://www.roundsound.com/classico-cl-c.php
Gallo Classico CL-1 $495
http://www.roundsound.com/classico-cl-1.php
Ryhtmik F15 974
http://www.rythmikaudio.com/F15.html
Onkyo 818 $1100
Total: $4969
Plus shipping
Later you could add a separate amp (Emotiva XPA-3) for 700
There are other variations on this system that would give you the amp (cheaper sub and Classico CL-3 instead of the 3.1) and still come in under around $5000
Gallo offers free shipping both ways and a 60 day in home trial for their Classico series.
Cheers
OldMovieNut
OldMovieNut is offline
post #37 of 39 Old 09-14-2012, 05:51 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
I had forgotten how small his room is. But, for roughly the same price, he might as well get the high efficiency speakers, then if he ever moves into a larger room he's all set instead of having to re-shop!
post #38 of 39 Old 09-14-2012, 07:07 AM
Quoted: 175 Post(s)
Liked: 262
True, hence I also mentioned CHT (SHO-10/ PRO-10).
But the point is, if he isn't moving to a bigger house anytime soon, high efficiency speakers will not outperform any other speakers for his small size room and 85dB volume in terms of SPL.
For example, he could get the KEF Q300 speakers for $450/pr brand new from some dealers. 14" x 12" x 8", weighs about 17 lbs. It is rated for 110dB SPL. He gets the big brand name. Technologies inherited from the $160,000 KEF Muon. Cheaper in cost in the end. Sounds great.
Or how about the KEF Q900 for $1300 delivered new? SPL rated for 114dB. I think that's loud enough. Reviewed and measured my Stereophile and HTM. Big brand name.
post #39 of 39 Old 09-16-2012, 03:22 PM - Thread Starter
Scottyp3's Avatar
I just auditioned some speakers and heard some energy veritas (or however you spell that) and wasnt too impressed by the towers. Also listened to WIDE variety of bookshelves but it was hard to compare towers to bookshelves when there was a very small subwoofer.
Many of the speakers listed (Ascend etc) will cost a lot to ship to Canada
Scottyp3 is offline
Reply Speakers
