My setup. Need suggestions. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 09-01-2012, 09:53 AM - Thread Starter
awcamaro's Avatar
Left/Right Speakers:
Sony SS-B3000
-or-
Bic DV62si
Center Channel:
BIC FH6 LCR
-or-
BIC DV62CLRS
Surround:
Dayton B652
Subwoofer:
BIC V1020
A/V Receiver:
Onkyo NR515
OR
Two Pairs of Sony SS-B1000 for Left/Right/Surround
instead of the sony SS-B3000 + Dayton B652
If you have any better suggestions, my budget is $700 Probably can go up or down a few bucks.
awcamaro is offline
post #2 of 7 Old 09-01-2012, 10:25 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
Is your total budget $700 for 5 speakers, subwoofer and a receiver? I want to make sure that's clear.
Afro GT
afrogt is offline
post #3 of 7 Old 09-01-2012, 10:26 AM - Thread Starter
awcamaro's Avatar
Yeah it's pretty low. I'll probably update bits and pieces down the line.
awcamaro is offline
post #4 of 7 Old 09-01-2012, 11:02 AM
afrogt's Avatar
Liked: 755
If you plan to update over time then just start off with a receiver and two speakers or receiver 2 speakers and sub.
How big is the room and what's your planned usage home theater vs music. vs gaming?
What devices do you already have? TV? Blu Ray? DVD? Gaming Device? Sat or cable receiver? Are they all HDMI devices?
Afro GT
afrogt is offline
post #5 of 7 Old 09-01-2012, 11:56 AM - Thread Starter
awcamaro's Avatar
Home entertainment, not home theater room. That means open. It's about medium size. I have a projector set up, and ps3, and a few other devices, all hdmi. I have all the receivers stuff done. I just need to know what speakers to get. My couch is about 10-12 feet from the screen. I have two walls. One behind the screen, and one to the left of the couch.
When I say I plan to update over time, I mean, use what I got for about 5 years before upgrading. Yeah, not that great. I want to start off with a 5.1 and update the components as I go on. My receiver's a 7.2 so I don't necessarily have to upgrade my sub by replacing it. I could add another one. I know starting off with two good speakers and a receiver is better, but I would prefer to always have a 5.1.
awcamaro is offline
post #6 of 7 Old 09-01-2012, 11:58 AM - Thread Starter
awcamaro's Avatar
Gaming≥Movies>>>Just music.
Yeah, thats an equal or greater than symbol.
awcamaro is offline
post #7 of 7 Old 09-01-2012, 02:44 PM
afrogt's Avatar
Liked: 755
$700 budget
Option 1
2 pair Bic DV62si @ $108.50/pr = $217
http://www.amazon.com/BIC-America-DV62si-Bookshelf-Speakers/dp/B00006JPDI/ref=pd_bxgy_e_img_y
1 Bic DV62 CLRS 2 $104
http://www.amazon.com/BIC-America-DV-62CLRS-Channel-Speaker/dp/B00009WBYL/ref=pd_cp_e_2
Bic F12 subwoofer @ $200
http://www.amazon.com/BIC-America-F12-475-Watt-Subwoofer/dp/B0015A8Y5M/ref=pd_bxgy_e_img_y
Total $521, leaves you $179 for a receiver.
Option 2
3 BIC DV62 CLRS @ $104ea = $312
Bic V1020 subwoofer @ $150
Dayton Bookshelf 652 @ $30/pr
Total $492
Option 3
3 BIC FH6-LCR @ $$106ea = $318
http://www.amazon.com/BIC-America-FH6-LCR-6-5-Inch-Frequency/dp/B0015A8Y3E/ref=sr_1_3?s=electronics&ie=UTF8&qid=1346532365&sr=1-3&keywords=bic+dv62clr-s
Dayton bookshelf 652 @ $30/pr
Total $498
Option 4
3 pair of Dayton 652 bookshelf speakers @ 30/pr = $90, use one speaker as center keep the other as a spare.
1 Klipsch RW-12d subwoofer @ $300.
http://www.newegg.com/Product/Product.aspx?Item=N82E16882780078
Total $390
So you've already purchased the receiver? If so then your speaker budget is closer to $400-$450?
Afro GT
afrogt is offline
Reply Speakers
