Fix Axiom M60 v2 rubber foot? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-01-2012, 11:15 AM - Thread Starter
FuzzyReets's Avatar
Quoted: 219 Post(s)
Liked: 24
Hi folks. I have a loose rubber foot on my M60 v2 speaker. I tried screwing it back in but no such luck. What's the procedure to fix? Do I have to take one of the woofers out? Is that safe? Any help greatly appreciated. Thanks.
Denon x2300w
XBox One S
Sony BDP-S6500
Apple TV4
LG OLED65B6p
FuzzyReets is offline
post #2 of 3 Old 09-01-2012, 01:26 PM
Bill Fitzmaurice's Avatar
Liked: 5684
How is it attached? Wood screw? If so put glue a toothpick or two into the hole to tighten the fit for the screw.
Bill Fitzmaurice is offline
post #3 of 3 Old 09-05-2012, 04:10 PM
Brenttom's Avatar
Remove the woofer and check to see if the T-nut is secured to cabinet. Using some pressure, try to secure the nut back into the cabinet. If it does not bite the cabinet, remove the nut and re-insert the nut from the outside of the cabinet.
Brent Tombari | Axiom Audio Expert | http://www.axiomaudio.com | 1.866.244.8796
Follow us on Facebook! http://facebook.com/AxiomAudio
Brenttom is offline
Reply Speakers
