Using a tower for center. Should I be? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 09-01-2012, 06:13 PM - Thread Starter
accordex's Avatar
Quoted: 12 Post(s)
Hi guys, new to the forum.
I recently bought a pair of the infinity p363's at frys. I know they're not the best but for 200 bucks...they sound and look amazing. I bought another one for the center seeing as I don't have much money and have a nice big Hitachi projection HDTV to set it on top of. My question is am I getting the best sound using this tower sitting sideways on top of my Tv? Or would there be a huge difference in buying the actual primus center? I would hate to spend 200 on the center where I could spend that on another pair for surrounds.
I mainly ask because I have nothing to compare it to as my previous center was a small onkyo htib speaker...so I don't know what an actual real center sounds like.
I do know watching cabin in the woods there were scenes where those woofers were MOVING!
Looking forward to your feedback. Thanks
raypjuarez likes this.
accordex is offline
post #2 of 10 Old 09-01-2012, 08:30 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1350
Using a identical tower as a center is actually better than using a regular center, from a performance perspective. Check out this article for a more technical explanation of why. Horizontal center speakers are a compromise in performance for the sake of placement accommodation, because vertical speakers are usually too awkwardly shaped for most entertainment systems. If you don't have to live with that compromise, then you certainly should not. If I had the space for it, I would be using a tower as well.
shadyJ is offline
post #3 of 10 Old 09-01-2012, 08:34 PM
Bill Fitzmaurice's Avatar
Liked: 4630
No, due to the reasons noted in the link in the post above. Drivers aren't arranged vertically just because it looks good that way, it's because they work better that way.
Bill Fitzmaurice is online now
post #4 of 10 Old 09-01-2012, 08:41 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
The Infinity tower was designed/engineered to stand-up - and this brings the best sound.
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #5 of 10 Old 09-01-2012, 11:13 PM
shadyJ's Avatar
Liked: 1350
Lol, I somehow missed the part about using it sideways. Yeah, it definitely isn't built for that.
shadyJ is offline
post #6 of 10 Old 09-04-2012, 12:47 AM - Thread Starter
accordex's Avatar
Quoted: 12 Post(s)
Thanks for the replies, but I'm still confused...it's ideal to use the same speaker but not to lay it sideways? In what scenario would one be able to stand up a tower to use as a center short of standing it in front of the tv?
accordex is offline
post #7 of 10 Old 09-04-2012, 01:01 AM
BarnacleBill's Avatar
Liked: 39
That's it. If you have a projector and screen you can put three towers behind the screen. If you have a flat screen mounted on the wall and no console below the TV, you can put a tower speaker under the TV as a center.
From everything I've read here, three identical speakers arranged vertically is the best set-up, if you can do it.
BarnacleBill is offline
post #8 of 10 Old 09-04-2012, 01:03 AM - Thread Starter
accordex's Avatar
Quoted: 12 Post(s)
I see that makes sense...thanks!
accordex is offline
post #9 of 10 Old 09-04-2012, 01:23 AM
sdurani's Avatar
Quoted: 4479 Post(s)
Liked: 2899
TV mounted on the wall just above the centre tower or all three speakers behind an acoustically transparent screen.
Sanjay
sdurani is offline
post #10 of 10 Old 09-04-2012, 01:56 AM
Alec88's Avatar
Quoted: 27 Post(s)
Do you want to use the same driver sizes? If not you can use the PC251 with 5 1/4" drivers for the center and two P153 bookshelfs for surrounds.
You can use a primus bookshelf for the center as well but the tweeter will end up being far left or right if placed horizontally. Not sure how that would sound since I haven't tried it. Nice speakers.
Sony DA5700ES
PSB Image T5, PSB Image B5, PSB Image B4, PSB Image C4
Alec88 is offline
Reply Speakers
