Best 5.1 combination under 400. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 09-02-2012, 08:31 PM - Thread Starter
awcamaro's Avatar
What's the best combination of speakers to form a 5.1 system for under 400. I have an open room, and my couch is about 12 feet from the screen.
I was thinking about a pair of Sony SS-B3000 for the front, a pair of Dayton B652 for the surround, a BIC FH6 LCR or BIC DV62CLR-S as the center, and a BIC V1020 Sub.
Any other suggestions? I already have a receiver. An Onkyo NR-515 to be exact.
Also, do you prefer the Sony SS-B3000 or the BIC DV62si better?
awcamaro is offline
post #2 of 10 Old 09-02-2012, 08:31 PM - Thread Starter
awcamaro's Avatar
Thanks in advance
awcamaro is offline
post #3 of 10 Old 09-02-2012, 11:42 PM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
This Pioneer series on special at Newegg is an excellent bargain for the price, better than the Sony or Dayton speakers. There are promo codes that bring the towers, center, and bookshelves for the surrounds down to $270 for the set. Avoid the Pioneer SW-8 sub though. I recommend waiting until you can afford a BIC F12.
Also, be sure to match your front L/R & center with the same speaker brand/series.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #4 of 10 Old 09-03-2012, 08:17 AM - Thread Starter
awcamaro's Avatar
Why would you say they're better? They only have 85db while even the Dayton's have 87db and they're more than half the price.
awcamaro is offline
post #5 of 10 Old 09-03-2012, 08:23 AM
zieglj01's Avatar
Quoted: 1713 Post(s)
Liked: 1630
The Dayton's are not real good - you can search North, South, East and West, and you
will not find much treble with these speakers - and they are somewhat thin sounding >
Look at that dip in the frequency response, starting around 4khz
http://www.soundandvisionmag.com/blog/2011/07/06/world-s-cheapest-speaker?page=0,3
I have owned the Newegg Pioneers and some Dayton clones, the Pioneers are all around
better speakers.
I would check with Tigerdirect.com and look at the better and improved BS22 Pioneer
speakers for $99 and the new C22 center, then save up for some surround speakers.
http://www.tigerdirect.com/applications/SearchTools/search.asp?keywords=pioneer+speakers
__________________________________________
Who AM I
Speakers -- Canton GLS 2 > Boston VS240
Receiver -- Integra 50.2
zieglj01 is offline
post #6 of 10 Old 09-03-2012, 09:30 AM
afrogt's Avatar
Quoted: 1437 Post(s)
Liked: 982
The sensitivity has nothing to do with what sounds better, it just means one plays louder than the other at the same volume level. They sound better than the Dayton because they use better drivers and crossovers and are built better.
The Pioneers are a bargain for $270. Then add an inexpensive subwoofer for $130 or so. The Dayton subs are decent for the price.
http://www.parts-express.com/pe/showdetl.cfm?partnumber=300-629
Afro GT
afrogt is offline
post #7 of 10 Old 09-03-2012, 03:37 PM
bradymartin's Avatar
Quoted: 33 Post(s)
i got newegg sale prices for two 51s, one c21 and two bs21s all for $220 (plus tax since i live in cali)
got the bic f12 with promo code for $166
total = $386 plus tax
i am very happy with this setup
bradymartin is offline
post #8 of 10 Old 09-03-2012, 04:07 PM
Quoted: 33 Post(s)
i assume you quoted the surrounds as the 41s?
out of curiosity what if he went with two 21s instead, saving $50 and putting that towards a bic f12
post #9 of 10 Old 09-03-2012, 07:03 PM
afrogt's Avatar
Liked: 982
That probably would be a better move if it enabled him to get the Bic F12 over a lesser subwoofer.
Afro GT
afrogt is offline
post #10 of 10 Old 09-03-2012, 08:23 PM
cel4145's Avatar
Liked: 3002
Agreed.
But if he can afford to get the BIC F12 (or better), or hold off to get the subwoofer, seems worth it to go with the 41s.
cel4145 is offline
Reply Speakers
