Upgrading from Polk monitor 70 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-06-2012, 02:24 PM - Thread Starter
bigtime22's Avatar
I'm in the market to upgrade from my Polk monitor 70, cs2, and rti bookshelf rears. I would keep my onkyo 809. I'd like to start by upgrading my rw12d to an svs model (hopefully pb13). If I did that what would be a good match speaker wise? I was kind of thinking rti equivelants all the way around. What brands should I look into. I need some ideas of what to go listen for. Budget being under $2000ish for left/right and I'd match the center then finally the rears later on. I don't have room specs because we are still looking at houses. Also, best places to buy? Thanks.
bigtime22 is offline
post #2 of 3 Old 09-06-2012, 09:56 PM
postrokfan's Avatar
Quoted: 602 Post(s)
Liked: 3648
Are you set on Polk? There are many good tower speakers in the $2000 range including the Ascend Acoustics Sierra towers as well as the KEF Q900s (to name a few).
Eastern Shore Audio Collective-E.S.A.C. Member, www.esac.club
postrokfan is offline
post #3 of 3 Old 09-07-2012, 01:37 AM
kemetblk's Avatar
Quoted: 16 Post(s)
Polk RTi A9's are great choice. I have them and love them. If you are willing to spend up to $2k then I'd seriously look at the Aperion Versus Grand towers. I also demoed the Martin Logan Motion 40, B&W 683 and DefTech BP-8040 and each of them had their strong points, but the ML's sounded best overall to me. Aperion would be my first choice though.
AVR: Denon X3300
F/C/R: Polk RTi A9's / CSi A6 / Speakercraft AIMWIDE 3 / Sub: SVS PB12-NSD
Sony XBR-75X940D, Toshiba HD-A30, Nvidia Shield TV (2015), Xbox One S, PS3
PC: Core i7, 16GB RAM, 512GB ssd + 4TB hdd, GTX 970 SSC
kemetblk is offline
Reply Speakers
