Please help me choose my first bookshelf's :) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 65 Old 09-07-2012, 10:39 AM - Thread Starter
hay112's Avatar
So I'm very to the audio scene so excuse my newbness but I've made a wish list on Amazon of speakers I've read about online and reviewed. The problem is there is sooo many good bookshelf speakers under $200. I've listened to some AudioEngine A5+ in person and really liked them but they are above my price range. You'll see that I have some active and some passive speakers on here, I really don't mind purchasing a separate amp if it means better quality. I'll be using these in a 12x12 room for music most likely without a sub. Let me know which one you'd choose or if you have any better suggestions
Wish list http://amzn.com/w/5Z5ZOHPJT2WO
Also I could buy used off craigslist, I just found these which I've heard are good
http://seattle.craigslist.org/see/ele/3243476188.html
hay112 is offline
post #2 of 65 Old 09-07-2012, 11:11 AM
ShaQBlogs's Avatar
Quoted: 27 Post(s)
if you can up your budget..
http://www.crutchfield.com/S-9yhOvKRuHzK/p_760IMGB4C/PSB-Image-B4-Dark-Cherry.html
pretty good speakers. I have the PSB B5 though...not the b4
With low budgets you will have to compromise somewhere or the other. And with bookshelves dont expect much bass.
if you can up your budget around 400 there are quite a few really good choices. Suggest you save up and buy. Also have a look at NHT. They make some pretty good bookshelves.
Do be aware that the NHT site prices are for one speaker and not for two
http://www.nhthifi.com/
ShaQBlogs is offline
post #3 of 65 Old 09-07-2012, 11:32 AM - Thread Starter
hay112's Avatar
Yeah I really don't want to get into the 400s but I did have the NHT SuperZero 2.0s on my list. I've heard they lack the low end though so are better paired with a sub but I've never heard any of these so I don't know for certain.
hay112 is offline
post #4 of 65 Old 09-07-2012, 12:18 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1351
You can get ok bass with bookshelf speakers, just not small ones with dinky 4 or 5 inch woofers. Those PSB speakers will have no bass. Check these out: Behringer 2031p monitors. They are fairly large and heavy, but with 8.75" woofers, they have good bass all the way down to the 50 hz region. A good bookshelf speaker which is smaller and also has decent bass is the Hsu HB-1 mk2. Those don't lose any steam till they get to 60 hz, that is very good for bookshelf speakers with 6.5" woofers. These HTD Threes ought to have decent bass as well, although I have not personally heard those. These Arx A1b should have decent bass as well, with it's high excursion bass driver. I realize all these speakers are a bit over your $200 budget, but the fact is it is hard to get good bass from a smaller speaker. If you are going without a sub, you will want as much bass extension from your speakers as possible.
shadyJ is offline
post #5 of 65 Old 09-07-2012, 12:37 PM - Thread Starter
hay112's Avatar
awesome, thanks man
any amp suggestions that won't break the bank?
hay112 is offline
post #6 of 65 Old 09-07-2012, 12:41 PM - Thread Starter
hay112's Avatar
are the previous model Behringer 2030Ps any good? Because for 99$ they would be a good deal
http://www.sweetwater.com/store/detail/B2030P/
hay112 is offline
post #7 of 65 Old 09-07-2012, 12:45 PM
Elihawk's Avatar
Quoted: 1313 Post(s)
Liked: 1144
the Def Tech SM 350/450s have been on and off sale at New Egg. When on sale, they can be had for around 200...but they are passive, so you will need a AVR or amp...those play the low end about as well as any bookshelf in that price range!
Five28 likes this.
Set up #1: EMP e5Ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, SVS NSD SB12 sub, Marantz Slimeline 1504 AV receiver
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and EMPtek10i10i sub, Denon 1910 AV receiver
Set up #3: Philharmonics- BMR in a 2.0 system, music only, Yamaha RXV-363 AV receiver
Elihawk is offline
post #8 of 65 Old 09-07-2012, 01:00 PM - Thread Starter
hay112's Avatar
wow haven't heard of those, they seem very enticing. I'm not bass head or anything though just wanted to let you guys know i won't be pairing with a sub. I mostly to alternative, jazz, and classical. So mostly looking for good balance.
hay112 is offline
post #9 of 65 Old 09-07-2012, 01:11 PM
swallan's Avatar
Quoted: 12 Post(s)
Liked: 27
the def techs are real good speakers for the money.
Five28 likes this.
swallan is offline
post #10 of 65 Old 09-07-2012, 01:55 PM
cschang's Avatar
Quoted: 134 Post(s)
Liked: 171
The Audioengine A5+ is a powered speaker.
Most of what has been recommended are passive speakers, which will need some kind of amplification.
Does your budget include some kind of a receiver to power your speakers?
-curtis
Owner of Wavecrest Audio
Volunteer Mod at the Ascend Acoustics Forum
Like all things on the Internet, do your research, as forums have a good amount of misinformation.
Help beat breast cancer!
cschang is offline
post #11 of 65 Old 09-07-2012, 01:57 PM
Elihawk's Avatar
Liked: 1144
Well there is bass heavy and then there are balanced speakers. If you don't have bass, your speaker will not be balanced! The Def Tech are a pretty good choice for music if you aren't going to have a sub!
http://www.newegg.com/Product/Product.aspx?Item=N82E16882325059
229 and 30 dollar off promo code if you orde before 9/12/12
Five28 likes this.
Elihawk is offline
post #12 of 65 Old 09-07-2012, 02:00 PM
cschang's Avatar
Quoted: 134 Post(s)
Liked: 171
How much bass do you need to have to be balanced?
-curtis
cschang is offline
post #13 of 65 Old 09-07-2012, 02:03 PM - Thread Starter
hay112's Avatar
Yeah I understand I'll need to purchase a separate amp or receiver. I haven't really picked one out yet but I figured if I want to upgrade speakers down the line it would be easier and more flexible if I went with passive speakers now. The combination and convenience of active speakers is tempting though.
hay112 is offline
post #14 of 65 Old 09-07-2012, 02:04 PM
Elihawk's Avatar
Liked: 1144
I would assume a db level that matches its output at midrange and high freq (ie flat freq reponse).
Elihawk is offline
post #15 of 65 Old 09-07-2012, 02:14 PM
cschang's Avatar
Quoted: 134 Post(s)
Liked: 171
So what is the bass frequency you want to match to the mids and the highs?
-curtis
cschang is offline
post #16 of 65 Old 09-07-2012, 02:22 PM
shadyJ's Avatar
Liked: 1351
Those 2030p are good bookshelf speakers and that is a good deal, the problem is those do not have great bass at all, they have been measured to start rolling off at 90 hz, so they really need a sub. If you are running without a sub, it is well worth the extra 60 to get the 2031 speakers.
As for amps, what kind of connectivity do you need? If you need digital inputs, then the amp to get is the Harmon/Kardon 3490, which can be had for $300 shipped (do that email thingy at J&R for the 300 offer). If you just need an amp without a DAC or any receiver features, this AudioSource AMP 100 ought to do nicely. If you want the features of a receiver but do not need digital connectivity, this Onkyo 8255 receiver will do fine.
shadyJ is offline
post #17 of 65 Old 09-07-2012, 02:29 PM - Thread Starter
hay112's Avatar
I'm really not sure, I'm guessing down to 50 hz should be fine
hay112 is offline
post #18 of 65 Old 09-07-2012, 03:23 PM
Dave1027's Avatar
Quoted: 12 Post(s)
That deal isn't so good. It says $99 EACH. That's per speaker. The other Beringer with the big woofers says $259 a Pair.
BIC DV62si speaker mod for warm musical sound. PM me for info.
Dave1027 is offline
post #19 of 65 Old 09-07-2012, 03:46 PM - Thread Starter
hay112's Avatar
Oh gotchya
hay112 is offline
post #20 of 65 Old 09-07-2012, 03:47 PM - Thread Starter
hay112's Avatar
So any good Active speakers you guys would recommend under $300? Just in case I decide to go that route
hay112 is offline
post #21 of 65 Old 09-07-2012, 04:10 PM
cschang's Avatar
Quoted: 134 Post(s)
Liked: 171
Gotcha...but I was asking Elihawk.
Basically want to know what balanced meant to him. He says "flat frequency response"....but I was wondering how deep he thinks a speaker needs to play to be balanced.
-curtis
cschang is offline
post #22 of 65 Old 09-07-2012, 04:15 PM - Thread Starter
hay112's Avatar
I've also added these 3 as possible choices, all active
Swan D1080 IV
M-Audio BX5 D2
KRK RP5G2
hay112 is offline
post #23 of 65 Old 09-07-2012, 04:28 PM
shadyJ's Avatar
Liked: 1351
There are active versions of the Behringer 2031p, which is the 2031a, those aren't under 300 though. You will have a hard time finding some decent active bookshelf speakers with reasonable bass extension for 300 new. There ought to be plenty of those on ebay though. Some other good active monitors with good bass extension would be the KRK Rokit 8 and the JBL LSR 2328P studio monitors. New, they are out of your budget, but you might find some used within your means. They have larger woofers and much better bass, but as a consequence, they are larger and heavier than average bookshelf speakers.
shadyJ is offline
post #24 of 65 Old 09-07-2012, 11:50 PM
BarnacleBill's Avatar
Liked: 39
There is a newer version of the SWAN D1080 IV for $179 at http://www.theaudioinsider.com/product_info.php?loudspeakers=swan-active-desktop-sound&p=swan-d1080-iv-active-desktop-loudspeaker-system&cPath=21_24&products_id=200&
The next step up is the Swan M200MkII for $279 at http://www.theaudioinsider.com/product_info.php?loudspeakers=swan-active-desktop-sound&p=swan-m200mkii-active-desktop-loudspeaker-system&cPath=21_24&products_id=184&
BarnacleBill is offline
post #25 of 65 Old 09-08-2012, 12:00 AM
YearZer0's Avatar
Do you have tools? Can you work with wood? With that budget you would get a lot more for your money if you build your own. You can even get the cabinets already built, or you can get someone to do the cutting and ship you a flat pack, or do it completely yourself and cut the wood out and assemble it.
Denon AVR-4311CI, AudioControl Savoy G3||| Axiom Audio M80v3, M22v3, VP180, & QS8's||| Zaph|Audio ZA5.5tt, ZA5.3t's||| SVS PB12-NSD Sub, DIY PWK Designed TC-Sounds 18 Aperiodic Sub|||= 11.2 Surround
YearZer0 is offline
post #26 of 65 Old 09-09-2012, 10:05 PM - Thread Starter
hay112's Avatar
OK, so after thinking about it a little more I think I'd rather go with active speakers although the Def Tech 350s are still tempting. I've been looking on Craigslist and found some deals on speakers locally too.
What do you guys think between the following?
Used:
KRK V6
JBL LSR 2325P
M-Audio BX5a or BX5 D2
NHT SuperZero
New:
SWAN D1080 IV
Alesis Monitor1 MKII
Def Tech SM 350
Energy RC-10
Tannoy Reveal 501A
AHHHH SO MANY GOOD OPTIONS!
hay112 is offline
post #27 of 65 Old 09-10-2012, 07:41 AM
Elihawk's Avatar
Liked: 1144
How deep do you want? how deep can you hear? You would hope that a speaker could play as deep as possible, but for the money you want the speaker that can do the best possible in that price range. For $300/pr, maybe that is asking too much.
I have the Polk m40s and while I know they are advertised to go pretty low (47hz ) I have never really care for the bass from them. The Def Tech SM450 definately hit lower and have more defined bass, and still do the highs and mids pretty well (the def Tech are advertised to go to 24 hz, but I wouldn't know as I cannot hear that:))
Elihawk is offline
post #28 of 65 Old 09-10-2012, 07:51 AM
Hookedonc4's Avatar
Quoted: 26 Post(s)
I told him I have a great set of DefTech Pro Cinema 600 with Sub and wall brackets for $400 and shipping was on me... These are a great set looks like they are going in my sitting or wife's craft room...
I thought that was a great deal???
If you have time to wait BB has great sales on polk speakers.
We use the T15 in Kids room and then I have a set in kitchen and bath hidden in cabinets they sound good.
Denon X4000, SC-91, VSX-51,VSX-81 Pioneer Elites and Denon 1611
James loudspeaker inwalls main and future theater
Control4
Other speaker zones DefTech, Polk, Russound, Boston Acoustics
Hookedonc4 is offline
post #29 of 65 Old 09-10-2012, 08:26 AM - Thread Starter
hay112's Avatar
Sorry bud, they are a great deal I just didn't want to spend $400 and really just wanted a 2 speaker setup.
Thanks for the heads up on the T15s though, very good deal
hay112 is offline
post #30 of 65 Old 09-10-2012, 08:29 AM - Thread Starter
hay112's Avatar
I'm really digging the Def Techs
Five28 likes this.
hay112 is offline
Reply Speakers
Krk Systems Rp5g2 Generation 2 Rokit 5 Studio Monitor
