heard B&W HTM61 sucks, so what center to get for B&W HT? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 09-08-2012, 08:43 PM - Thread Starter
prefetch's Avatar
i've been reading that the HTM61 is crappy. i dont know if this is true or not, and my local dealer doesnt have one to demo, but it's got me spooked.
i'm looking to buy 684s for right/left front, and DS3s for surrounds and the ASW610 for sub.
so, what should i be looking to get for a center that won't screw up the rest of my system?
or should i bail on B&W and go for something comparable? budget is $3-5K for a 5.1 speakers.
prefetch is offline
post #2 of 7 Old 09-08-2012, 10:52 PM
Brian B's Avatar
Quoted: 233 Post(s)
Liked: 101
Of course you should bail. You have better options even in the B&W line! CM9 + CMC2 + CM1.
B.
Brian B is offline
post #3 of 7 Old 09-09-2012, 02:46 AM
ShaQBlogs's Avatar
Quoted: 27 Post(s)
out of curiosity...with that wonderful a budget, why step anywhere near the overpriced B&W's.
You have so many better choices....way way better that what u have picked
around the same price, the PSB T6.....Dali Icon 6 are any day a hands down choice over the B&W 684.
and for subwoofer dont see anyreason to look at anything apart from the likes of rythmik, hsu, svs, outlaw
suggest you keep around 1000 - 1500 for fronts. Get its matching center as recommended. Get a pair of subs.
A decent pair of surrounds would do. Put most of your money into fronts and subs.
my choice would be PBS synchrony series and a pair of sealed rythmik or hus subs.
here are some terrific speakers for the money
Floor standers...
http://www.crutchfield.com/S-nfYph2t4Zqa/p_760SYN2C/PSB-Synchrony-Two-Dark-Cherry.html
http://www.emptek.com/towers.php
paradigm has a few good towers
Subs:
http://www.rythmikaudio.com/F12.html
http://www.rythmikaudio.com/F15.html
http://www.hsuresearch.com/products/vtf-3mk4.html
http://www.hsuresearch.com/products/vtf-15h.html
ShaQBlogs is offline
post #4 of 7 Old 09-09-2012, 08:09 AM - Thread Starter
prefetch's Avatar
oh yeah, forgot about hsu subs. i owned one like 10 years ago, and i liked it.
on the fronts - so many choices it makes my head hurt. i own a pair of B&W bookshelf speakers and i really like them, which is why i thought B&W would be good for the HT setup.
i listened to some paradigm bookshelf speakers and compared them with the B&W, and the B&W sounded noticeably better to me. didnt listen to the paradigm towers.
btw, the PSB two looks like it's been discontinued.
prefetch is offline
post #5 of 7 Old 09-09-2012, 10:44 AM
ShaQBlogs's Avatar
Quoted: 27 Post(s)
its just that the price you would pay for B&W models like 684, the same price would fetch you better speakers. The EMP tek is a wonderful speaker for the money.
nope. it looks like they are just not available currently at crutchfield.
http://www.psbspeakers.com/products/synchrony/Synchrony-Two
post #6 of 7 Old 09-09-2012, 03:41 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3074
It's not that the HTM61 sucks it just seems to have a narrower sweet spot. It may not even be noticeable to you. That being said, a single 685 would be superior. Also, if you do decide on the 600 series I would go with the 683s rather than 684s. In fact, I would prefer the 685s with a nice subwoofer to the 684s.
You have a decent budget. I agree with Brian. The CM series would be a better bet and you could pair your 5.0 with a Rythmik, HSU, or SVS research subwoofer.
There are also a lot of other great choices out there. If I had that budget I'd go with the Sierra Towers from Ascend Acoustics but that's just me. The aforementioned PSB T6 towers are a good choice. You might consider the KEF Q900s, Monitor series, or Salk Sound Towers as well just to name a few. You'd definitely save some cash in the process too.
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is offline
post #7 of 7 Old 09-09-2012, 05:45 PM
jaymalya's Avatar
You can also get aperion verus grand towers ( minus their sub) - their center channel is great. If you don;t like them, return them back - no money lost
http://www.aperionaudio.com/speakers/verus-family
Thx
Jay
jaymalya is offline
Reply Speakers
